Check your Bell Housings
Old Jan 21, 2005 | 09:53 PM
11 Second Momma's Avatar
11 Second Momma
Default Check your Bell Housings
We could find nothing to cause this other then torque
Old Jan 21, 2005 | 11:47 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
How did you discover this?? Do you have extensive Mods with lots of HP/TQ?? Is this the first time that you have had your housing off???
I have an 02 Z06 also!
Thanks for the heads up!
Bill C
Old Jan 21, 2005 | 11:54 PM
1 Nasty Z's Avatar
1 Nasty Z
Watchout for the WHEELHOP. Can do nasty things to the drivetrain including the torque tube and bellhousing. Just my .02
Old Jan 22, 2005 | 12:13 AM
11 Second Momma
Bill C
We heard a metal like rattle. Took in to our repair shop.. They put it on the lift and saw the cracks..
We are running 448 rwhp/ 411 tq with AFR H/C per the last dyno before we replaced the short block.
The housing was been off before when they swapped the short block and also the clutch.
We drive our car hard we have over 500 passes on ET Streets.
I'm just posting just posting this for people to check it out, next time they have their car on a lift.
Old Jan 22, 2005 | 12:15 AM
11 Second Momma
I agree with you on wheel hop. But that is one thing we don't have. Since we have only ran the car on Street tires for 4 passes ever.
Old Jan 22, 2005 | 02:54 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Gees, when are the problems going to end???
By the way, I am watching football finals on Sunday, not r____g!
Old Jan 22, 2005 | 02:59 AM
11 Second Momma
Sure be that way Al
Well I pulled the Exedy clutch at the same time today that we swapped housing. I think it was gripping to hard for our car. I guess we will find out Sunday
Old Jan 22, 2005 | 03:00 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Originally Posted by 11 Second Momma
Sure be that way Al
Good Luck!!
Old Jan 22, 2005 | 03:02 AM
11 Second Momma
Good Luck!!
Thanks I think I need it
Old Jan 22, 2005 | 08:12 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
[IMG]We could find nothing to cause this other then torque
Thanks for the headsup.
Old Jan 22, 2005 | 08:24 AM
Gweedo's Avatar
Gweedo
I'd be asking the shop if they used an impact gun to install the bellhousing bolts. The bellhousing has large dowels that should distribute the forces from the drivetrain evenly. It looks like installer error to me...
Old Jan 22, 2005 | 09:42 AM
RAFTRACER's Avatar
RAFTRACER
I really hope so , or this is going to become more frequent, I've only seen bellhousings look like this after vehicle has been involved in accident. 500 passes on ET streets could be detrimental though. There is alot of movement in drivetrain when launching or loading car heavily, I wonder if better driveline mountings may prevent this????
Old Jan 22, 2005 | 12:01 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Kat,
Thanks for the tip. My bell housing has been off several times now and we haven't noticed any problems, but I'll definitely add this to the list of things to look at more carefully. Glad to see you caught it before major damage occurred.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Check your Bell Housings
