Brake rotor Freezing
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Unless you have a problem like the '99+ Jeep Grand Cherokee's though I can't see the need, especially when NAPA has them for ~$25 as mentioned above. C5's aren't really known for going through rotors, unless they are autocrossed.
Bill
Raybestos at $25 per rotor are the longest lasting track rotor
To help brakes last longer, cooling ducts are the best advice.
But, and it's a big but it makes the rotor more brittle..permanently. Brittle at the surface, which causes cracks and flaking.
Another drawback is that it also reduced the coefficient of friction of that surface.
Which means on a brake rotor you will decrease your brake torque.
The only papers out there I could find on the subject where all written by companies offering cryo treated components. Not the most independent group.
Now I'm not completely read up, but I suspect that the nitrogen has more to do with the hardness than the cold.
There is a well known and proven metal treatment called Nitriding, which is basically enriching the surface of a metal using nitrogen to increase it's surface hardness and improve wear characteristics.
I say suspect, because traditional gas nitriding is done at higher temps not lower. And the nitrogen usually comes from the decomposition of ammonia gas. So, I'm just thinking out loud.
FYI:
Definition of Nitriding:
Because nitriding does not involve heating into the austenite phase field and a subsequent quench to form martensite, nitriding can be accomplished with a minimum of distortion and with excellent dimensional control.
The other problem is that the cold of liquid nitorgen only penitrates a few millimeters as bubbls form around the item. the rest of the item takes hours to cool down if at all.
Even it the a secondary liquid is use ( isopentate ) or submerssed in a vessel that is surrounded by Liquid Nitorgen and the Item is dipped into the almost frozen liquid isopentane to -273* C ( not absolute Zero )
Yes I have work with Liquid Nitrogen for 15 years. and I have also read many articals and non have convinced me. I would love to talk to a metalurgest who is NOT employed by one of these companies to get an unbiases information
So I am also very very sceptical of the process, but open to understand new ideas.
Then I sold the Baers because I'm cheap and but a set of regular factory rotors on and I've warped them. Argh!
