Stripped bolt raising my C5?
Old Jan 24, 2005 | 09:57 PM
d55guy's Avatar
d55guy
Default Stripped bolt raising my C5?
Well my 99 coupe was too low (the PO lowered it 2 inches) so I decided to reverse the directions for lowering the car. I was tightening the rear bolt up with my air ratchet but after about 1/2" it seemed to get easier to turn and the bolt wasn't going anywhere! So I must have stripped the bolt or nut. Did I reach the shank of the bolt? The bummer is I couldn't back it out either. So I guess I should order a new set of bolts and nuts, use a jack to take the pressure off of the spring and sawzall the bolt? Unless anyone else has any ideas?.....
Old Jan 24, 2005 | 10:16 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
First thing you need to do is put the air tools down
Jack the back of the car into the air and then put the jack under the control arm and raise it to take the pressure off of the spring, if the nut can't be loosened from the bolt then you will probably need to cut the bolt off and replace it.
You only need to turn the nut a turn or 2 and it shouldn't be difficult to turn, so if you have to use air tools then something is wrong.
Old Jan 24, 2005 | 10:33 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You don't have nor want to jack on the spring or anything when adjusting the rear.
The rear spring is unloaded when the car is in the air.
If the nut won't loosen up now, you'll probably have to cut the bolt and replace it.
Old Jan 25, 2005 | 12:24 AM
d55guy's Avatar
d55guy
A turn or two? Please correct me if I am wrong but it looks to me that the amount of change in ride height is the same as how much you tighten or loose the bolt? The bolt looked like 5/16 UNF so two turns would only change the height 1/12 of an inch. As for the air ratchet, the one I have is pretty wimpy (which really surprised me that it could strip it). I had started of doing it by hand but got lazy. :o
I think the PO actually put different bolts on because the ones that are on back there don't have any coating on it and are corroded. Do they make shorter bolts for the rear? If that's the case I probably stripped the nut on the bolt shank.
Thanks for the info about the spring being unloaded. That will make it easier. I know how much energy can be stored in spring so I am always cautious...
Well I guess I should add two bolts and nuts to my order from Fred Beans.
Old Jan 25, 2005 | 02:06 AM
Dope's Avatar
Dope
Resident moron
FYI, when playing with my ride height, I discovered that approximately 4 turns == 1/2" height change.
I really don't see how you could have stripped that bolt. You know there's a nut on top right? The bolt is huge, it would have taken a serious impact wrench to injure it. And even then I doubt it. Unless the bolt was defective.
Dope
Old Jan 25, 2005 | 02:15 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Thats right, I forgot you need to raise the front spring off the control arm to unload it but you don't have to do anything in the back
Old Jan 25, 2005 | 04:41 AM
vettenuts's Avatar
vettenuts
Almost sounds like someone used aftermarket bolts from Autozone. See it happen a lot. Get original GM bolts and replace them.
Old Jan 25, 2005 | 09:46 AM
d55guy's Avatar
d55guy
But why would the PO use aftermarket bolts? Did he buy a different length to lower it more? Anyway, I just emailed Gene Culley at Fred Beans to add them to my order.
Thanks for everyone's help,
Kerry
Old Jan 27, 2005 | 06:04 PM
d55guy's Avatar
d55guy
Well I got a pair of new bolts and nuts from the dealer for a whopping $9 and was able to cut the old one out with a fair amount of effort. The old bolt is about 1 inch longer and much finer thread then the GM bolt. The GM is very course thread while the old ones were very fine thread. That at least explains why I was getting a much different change in height compared to what Dope got. The factory bolts have about half the thread pitch! The nut was at the end of the bolt shank so I must have stripped it out that way. So the old bolts go into the trash and the new ones will go on tonight. I hope I can finish up tonight and the roads stay dry tomorrow so I can take it for a spin!
Old Jan 28, 2005 | 04:54 AM
C5 Frederik's Avatar
C5 Frederik
The bolt/nut is 14x2 mm. So 4 turns are about 1/3" (8mm)
Frederik
To Stripped bolt raising my C5?
