I need help please....argghhhhh
Old Jan 25, 2005 | 01:48 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Default I need help please....argghhhhh
My left headlamp wasn't going down all the way. I ordered the brass gear and installed it.
Now, for some reason, the headlamp cycles 3 or 4 entire physical revolutions before coming to a stop.
I took the gear right off the motor assy and tried the headlamps. While the pass. side only runs for the brief moment it takes to open the headlamp, the driver's side runs for at least 10 times that amount of time.
What tells the motor how long to run?
Anyone?
Thanks,
Mark
Old Jan 25, 2005 | 02:02 PM
dpd's Avatar
dpd
sounds like it is out of time.i believe there are 2 micro switches [1 open/1 close],but if the unit is out of time,it won't matter.
Old Jan 25, 2005 | 02:54 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
I think the motor is screwed up. Now when I turn the parking lights on, the headlamps open and come on. (except the drivers side is still not stopping)
When I unplug it, the right side works correctly. I just picked up a new motor, we'll see.
Thanks,
Mark
Old Jan 25, 2005 | 03:06 PM
Lemans Blue's Avatar
Lemans Blue
Man you are really screwed it must be all f*^$ up.
but I have some good news, I just save a bunch of money by switching my car insurance to Geico.
Old Jan 25, 2005 | 03:35 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Okay, plugged a new motor up... same thing. WTF am I missing? Are there microswitches?
Mark
Old Jan 25, 2005 | 03:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are no micro switches. The motors are controlled by the headlight motor control module. It is located under the passengers headlight and it is mounted on the front frame bulkhead under the headlight assembly.
Please let me get home from work and dig into the books to give you specifics. There is also a TSB that describes a problem with some plastic limit stops that cause one of the light motors to do what you describe. As soon as I get home i will provide you with the TSB and some electrical info on the problem.
BC
Old Jan 25, 2005 | 03:54 PM
dpd's Avatar
dpd
you can't just plug it in.you have to bolt it up[make sure you have the linkage to motor relationship right].the headlamp control module will then learn open/close.i think there is a tsb on this,but am not sure.
Old Jan 25, 2005 | 03:56 PM
jjcslynn's Avatar
jjcslynn
A friend of mine with a 98 had a similar problem. Drivers motor wouldn't go up and down all the time. He kept using it before I got a chance to look at it. I found the control module had a crack in it and water got inside it and the connector, too. Basically fried it. When it went, it took his drivers motor with it. He ended up replacing both and it worked fint.
Old Jan 25, 2005 | 04:05 PM
dpd's Avatar
dpd
the tech bulletin on the left headlamp is for a 00 car[00-08-42-002].i'm assuming you didn't have the headache until you swapped gears.
Old Jan 25, 2005 | 05:55 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
UPDATE:
Okay, not sure exactly what happened but among the 189 times I've taken the motor assy out of the headlamp assy... it must have sync'd correctly. All of a sudden, it is working like it should.
I honestly don't know what I did wrong but at least I don't have to spend the 200 bucks on a new motor.
THANK YOU to everyone for their help.
Mark
Old Jan 25, 2005 | 06:17 PM
Avanti's Avatar
Avanti
Sounds like a shorted or malfuncting "actuator." Mine was about $350 to replace at the dealer, but covered by warranty.
All the best.
To I need help please....argghhhhh
