Strange starting problem.....
I just let it up and push it a second time and it always starts right up.
I just thought this was normal since it has happened since new and it is consistent in the manner in which it reacts.
Rob
I had my crank pulley fixed. I'm still waiting to figure out why my car goes into pseudo-neutral in a hard turn. You guys have electrical problems. Are we supposed to just accept the fact that these things are normal???? This is my first American car since my 1992 vette. Every car in between was flawless and now my C6 has plenty to gripe about as did the '92.
What gives??? American quality?
I have seen the following and yes it was placed in to reverse, all ground straps tight, battery takes a charge(loses 5% during the night) for all the helpful waldo suggestions:
Exit memory position does not happen at door opening-no DIC message
No Start-DIC message "Service Column Lock"
No Start-DIC message "Battery voltage 12.2 (Battery read 12.7 volts)
Memory settings for #1 erased X4 times-No DIC Message
Telescopic does not return to memory postion-No DIC
Mirrors (the glass part) reset themselves from a retracted position-NO DIC
Saga Day 3,
All the codes that were thrown were software based, and Bowling Green had a hell of a time clearing the codes. To non-Techies, software codes differ in that they are a response to inputs (normally values out of ranges expected by the software or inputs the software never received,) rather then a failure of an end part such as a water pump or MAF. Right now the dealership and BG are trying to force the car to reproduce the fault condition, but I suspect that is a loser idea since it is likely the error occurs long before the code is thrown and they won't know any more then than now even if they throw a code.
In any case, Black Beauty comes home Friday afternoon fixed or not.
Dealership called saying that Flint and Bowling Green are saying that the condition is probability 99% sure from a bad reverse solenoid. Does anyone have an idea where the thing is located as I can imagine 2 different places, and my hope is that they don't have to crack the case to get to it-am I lucky or what????
Well Black Beauty is back at home now. With 3 engineers, one in California, one in Michigan, and one in Kentucky, and after the one in Michigan with a Z51 6sp on the rack applying the test findings on that mule, they decided that the 2nd Reverse Solenoid switch was not closing all the time (thereby not shutting down the computer/electric systems properly) was the cause. The fix, they feel, is to switch was to change the wiring of switch 2 to switch position 1. The old switch one tells the PCM its' in reverse while old switch 2 told the BCM it was in reverse and to shut the system down. The switches are engaged with a paw/lever and the engineers feel the paw would sometimes fail to fully reach or close old switch 2 thus the system would never shut down or worse, crash the BCM. The two switches are the same so it was a matter of moving wires. While the shop supervisor and I are rather doubtful, we both have to admit the first few codes thrown are coming from the transmission. The only change I will see that if #2 is not closed the DIC will report that I need to place it reverse. In any case I have agreed to share my findings of whether the fixed worked or not to the engineers. Since I make my money in programming and technical support, this request by them doesn't faze me as I rather be part of the solution then just suffering the problem.
The other reason I have gone in to such detail here is that I notice others reporting their problems in the forums, but never really bothering to post what their solution was-assuming a fix was ever found.
Well the fix did not work, if fact it was so bad that I had to disconnect the negative battery cable to reset the system so that it would start. I was not in an area I wanted to be hanging around for a tow truck as the sun set. Main same error "Service Column Lock"-normally I can get the car to start by opening the doors etc etc
The Service Rep called today, stating one or more Bowling Green Electrical Engineer(s) are coming down to look at the car since the wire chase produced no results. Besides experiencing our wonderful spring weather we are currently blessed with, hopefully they can shed some light on what is happening to my baby. As a test mule; however, I must admit that my impatience is beginning to show. Be that as it may, if they don't find the problem, it looks like soon I am going to raise the Lemon Flag. Now before anyone says something bad about the dealership, understand that they have traced 99% of the wiring and are doing all they can from their level-my hat is off to them.
Just so you know, my C6 behaves exactly the same when I go to start it.
Rarely does it start on the first push of the button.
I usually have to let up and depress it a secoend time before it begins turning over.
Please let me know you find!
Rob
