Strange starting problem.....
B2515
This sets when the state of the column lock is not correct, since your column didn't lock it is not surprizing to see this
B0005
This sets when the cc computer gets a request from the BCM to lock, but does not detect the reverse switch being closed, it has to occur three times to set
U1096
This is a communication lost between the module it set in and the instrument cluster, you need to know what module these codes set in
A brief outline of the shutdown process:
You push the rocker switch to off
The engine turns off
The FOB computer verfies the fob is still present, if not you get the off
or run DIC message
If the FOB is detected, the BCM checks for one of the two reverse switches, if it is not closed the shift to reverse message displays, if it is detected the clustor and DIC go blank and it sends a message to the CC to lock the column
The CC attempts to lock the column, checking the second reverse switch, if that switch is closed the column locks and everything is good, if not, the column does not lock and on the third occurance, you see the message you've been seeing.
From what you said above, I would guess we could narrow it down to something having to do with the second reverse swich, if the cc never got the command to lock, B0005 should not have set. I would also expect to see some U1064 codes in modules. The other codes could be usefull, especially if they are U codes. The BC does supply the power for the second reverse switch, so that is part of the circuit as well.
When you say that exit recall does not function, do you mean when you push the exit button on the door? I think that the parking brake has to be applied for that, but you said it was applied, both that function and the cc use the same communication line, a problem on that line would take the whole line down, but then I wouldn't think you'd see the B0005 code and would see a ton of U codes in the car...
I hope this helps, the other codes would be very useful, since the BCM should not crash if there is just a problem with the reverse switch, cc, or column lock....
Exit Recall is the process that returns the seat and telescoping column positions pre-programmed for when the drivers door opens(provided the driver first engaged their pre-programmed driving position as required by the MN6)
The BCM crashing seems to be a different event then the normal "Service Column Lock" although, it may have it's roots in the B2515 code. When the BCM event occurs the codes thrown point to just about all the electrical systems the user interfaces with to include the brake lights, hatch release etc etc.
Anyway, Monday's event threw a B2515; however, the Service Tech offered no other codes to me. Apparently, GM is really pressuring the guy to fix this car, after I contacted GM Headquarters about an extended warranty on the electrical system, that when the car fails to start again, he will bring the scanner to where ever the car is to scan the system. I personally doubt this will produce anything meanful, but I am willing to give it a try. The down side of this is that road trips are kinda not in the cards for Black Beauty-there again since the car is so undependable, I have put off a planned trip to the Tail of the Dragon and most one day trips the wife and I wanted to do this spring.
Then there are the Florida Lemon Law requirements- 3 sessions with the service department or 15 continuous days and being unsuccessfully serviced. Then once you notify GM and the State Attorney General, GM gets one more attempt to fix the car. Then if the manufacturer wants to contest, then you have to go in to arbitration. If they don't contest, then you decide whether you want a replacement or a "refund." You can be charged fair usage (mileage) at the rate of "Price of the Car times the actual mileage divided by 120,000"
The circuits I would check are column lock circuits and the reverse signal to the column computer.
Yea, I really hate electrical problems-I would rather have the pully issue-at least even Ray Charles can find that problem!
Well, I have been trying to have the car error out so the Service Rep can come out and scan, but with no success! It is madening! Right now I am ready for them to start replacing everything so I can get this crap over with-thought it was going to error out this morning as the both mirrors were pointed downward and the seats automatically (this is a MN6 so this can't happen by itself) moved back to their furtherest point when I opened the car door to drive to work. But, nix no error!
spectra6.0 Well that is a different error, but don't tied up in wonerdering if its' cell phones & keys-or that a special ritual that needs to be performed for it to work, because the problem is a true random error that some C6's have and when the cause is finally tracked down it will be fixed.
I got into the car as I usually do, put the clutch down as usual, my fob was in my pocket and the starter button had the green light on. I pushed the button and NOTHING happened. Green light still on, and nothing happened a 2nd try either.
I thought that the green light means starting sequence is 100% ??
I put the car back into reverse, opened the door, got out of the car, and locked it with the fob. I then re-entered the car, went through the normal start up precedure and it cranked right up. Same green light, only this time it worked fine.
Anybody else have this issue yet?
my first guess would be that you didnt have the clutch to the floor all the way. ive done this a couple times before, thinking i had the clutch all the way down, but didnt. i lifted my foot from the clutch and re-pressed it to the floor, as far as it could go, and the car started with no problem.
that could be the only logical reason i have for you, although it may not be right
In all the messing around that I've done, the only thing that I have found to interfere was my truck key FOB, a 2001 Silverado. I have tried it with other Corvettes and it always does it, it has to be right next to my FOB. If you have any other FOBs, they may be your cause or some other electronic device.
I have tried all my friends cell phones and nextels and have never cause any interference. Even with 7-8 surrounding my FOB like a ball.
It should be noted that if your FOB is in the vehicle the door may not unlock, when your enter the car it checks for the FOB outside the car.
Also, the car is not supposed to start if the FOB is not in the car, it works well on my car. If I dangle the keys outside the window it will not state and as soon as I bring them in it does start, I'm impressed with how smart it is.
That's exactly where the clicking is coming from.
I have no idea why, but it does happen.
One strange thing occured that I didn't think about until I got home was that I had both FOB's togather on a single key chain and that FOB 2 took over, but not enough to allow the car to start. FOB 1 should have taken control per the owners manual, if both FOB's are present. At any rate, either the FOB didn't pass all that it was suppose to pass or the car did not receive all the FOB's transmission-as to which is the smoking gun remains unclear with the Service Rep to contact BG this morning.
