Help!!! Emergency!!!
Old May 14, 2006 | 10:30 AM
coolcat's Avatar
coolcat
Default Help!!! Emergency!!!
Just got home from visiting my mom. Backed into my parking spot put it in park and all hell broke lose. The dashboard lit up like a Christmas tree. All the warnimg lights came on like when you start it up but they stayed on. Turned the car off thinking that maybe the electrical system would clear itself on a restart. Well she doesn't start! Put my foot on the brake and pushed the start button...NOTHING!!! The radio continues to play and won't shut off. WTF!!! Now the doors don't open and I'am trapped inside. So I pull on the emergency handle and the door opened. Closed the door and now it won't open from the outside! In the meantime the radio continues to play and the doors still don't open...an hour later! I'am afraid I'll be looking at a dead battery if the radio doesn't turn off. What should I do???
Old May 14, 2006 | 10:42 AM
dashotgun's Avatar
dashotgun
disconnect the battery under the hood to avoid a dead battery have towed to dealer.
Old May 14, 2006 | 10:46 AM
coolcat's Avatar
coolcat
Can't open the hood because the doors won't open!
Old May 14, 2006 | 10:48 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Old May 14, 2006 | 10:49 AM
joel_prahl@budweiser's Avatar
Use your only key to open hatch.
Pull door release.
Open hood
Disconnect battery
Old May 14, 2006 | 10:51 AM
Lightning Coyote's Avatar
Lightning Coyote
Pull door release.
Open hood
Disconnect battery
That should do it.
Old May 14, 2006 | 10:54 AM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
Microsoft blue screen of death. Disconnect battery , wait three minutes, reconnect and reboot.
Old May 14, 2006 | 10:57 AM
FastMover's Avatar
FastMover
From: Tellico Plains, Tn "Wolf" Official Corvette Guard Dog
Cruise-In II Veteran
Cruise-In III Veteran
when In Doubt "reboot"
Old May 14, 2006 | 11:08 AM
coolcat's Avatar
coolcat
Do I need special tools to disconnect the battery?
Old May 14, 2006 | 11:11 AM
Craigster05's Avatar
Craigster05
St. Jude Donor '07-'08-'09-'11-'12
Just disconnect the negative terminal wire off of the battery. Probably just a small 3/8 wrench or so.
JaminJ's Avatar
JaminJ
No, Basic Hand tools.
Old May 14, 2006 | 11:14 AM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Old May 14, 2006 | 11:18 AM
su8pack1's Avatar
su8pack1
Keep us posted.
Old May 14, 2006 | 11:20 AM
ProfMoriarty's Avatar
ProfMoriarty
10mm socket, extension, and wrench... and you can do without the extension.
Old May 14, 2006 | 11:22 AM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
If it's the same connection that GM has used for years, you will need a 5/16 boxed end wrench. Sometimes those will slip and you'll just need to use a pair of pliers. Grab the round part that's just "outside" of the 5/16 hex part. Nothing to it.
And it you can't get to it, just let the battery die. The dealer can charge it.
Old May 14, 2006 | 11:27 AM
coolcat's Avatar
coolcat
I don't have those tools so I called AAA. They have dispatched a unit to assist me. I'll keep you guys posted on what happens. Thanks everyone!
Old May 14, 2006 | 11:32 AM
Thinker's Avatar
Thinker
Let us know what happens. That's astounding....
Is this car an MN or Automatic? Just DBS curious.
At least you made it to see your Mom first!!
To Help!!! Emergency!!!
Old May 14, 2006 | 11:34 AM
need-for-speed
CI 1-4-5-8-9-10 Vet
Excellent point
Old May 14, 2006 | 11:35 AM
coolcat's Avatar
coolcat
My 05 C6 coupe is an automatic. Built early October 04 took delivery on November 1st, 04.
Old May 14, 2006 | 11:44 AM
C7Z51's Avatar
C7Z51
From: Never take a girl out for a cup of coffee, the last thing you want her to be is alert and focused. Tampa, FL
St. Jude Donor '05
No tools!!!!!
