Corvette Problems
Old Jun 27, 2006 | 06:11 PM
Vette5905's Avatar
Vette5905
Almost 11,000 miles, 12.5 months old, been perfect in every way. Much better than I expected from Detriot!
Old Jun 27, 2006 | 06:26 PM
djfullshred's Avatar
djfullshred
You never know what your car will be like until you get it. You either love the car enough to roll the dice & get one despite reading the negative reports here, or you settle for a less desirable car that you feel more assured will not give you grief (no gaurantee on that, no matter what you purchase). Not all C6s will have problems, but there is no denying the "known issues" exist either.
Old Jun 27, 2006 | 06:31 PM
lemans06conv's Avatar
lemans06conv
Originally Posted by su8pack1
No problems here. Get a vert if your worried about the coupe top.
0 problems 1200 miles
Old Jun 27, 2006 | 06:38 PM
blkc6z51's Avatar
blkc6z51
My roof came apart one week ago, so what GM will replace it.
This car is soooooooooooo hot you need to get it now.
Old Jun 27, 2006 | 06:44 PM
ricatthebeach's Avatar
ricatthebeach
Originally Posted by klein
I am wanting to purchase a used C6 and keep hearing about roofs flying off crankbolt issues and etc are alot of drivers seeing issues with their C6's or are these just few and far between.It really makes me mad that GM can't figure this stuff out ahead of time.Input would be appreciated.
Get a Vert. No delaminating problems.
Old Jun 27, 2006 | 07:16 PM
blkvette1's Avatar
blkvette1
06 MS/Blk MN6 Vert (manual)
3 months - 5,000 miles - hasn't been to the dealer for anything; not that I wouldn't take it there - just no need.
Oil changes are done at a place where I know several employees and there is a pit below the car - no lifting (NEVER) and I can inspect the bottom of the car everytime I change the oil. This is the ONLY way to go for an oil change.
Old Jun 28, 2006 | 03:32 PM
06 COUPE's Avatar
06 COUPE
Cruising
Mine was built April 26 '06. Upon picking it up, still with the shipping plastic all over it. I noticed 3 small issues. The driver door contacts the fender at the top by the mirror about 8mm rub. There is a rattle in the drivers door. Radio bass vibrates it. It you bang it with your hand you can here it inside???. The black plastic inside the drivers side front fender vent slot was flapping arround. Looking at it closer, it is just 3M taped to the inside fender. So I got a roll of pro 3m trim tape and re-attached it. Have not messed with the drivers door vibration or rubbing yet. One thing I know..I won't let the dealer touch it unless there is no possible way I can fix it on my own. They have damaged at least 3 of my new cars trying to fix a simple problem. Only making the problem worse.
Old Jun 28, 2006 | 03:50 PM
LS WON's Avatar
LS WON
You may go in there to get 1 problem fixed and end up coming out with 3 new problems
Look inside some of these hood compartments on engine I see just plain back tape wrapped around whatever
