Automatic Volume Control
Old Jul 6, 2006 | 11:36 AM
Vette66AirCoupe's Avatar
Vette66AirCoupe
Default Automatic Volume Control
Am I missing something? Is mine not operating properly or is this a useless feature? I get no volume adjustment with increased speed at all which is what I would think the feature is all about. In fact, the only time I've ever noticed it function at all was when I had the radio on and then dropped the top with the car sitting still. The volume went up. How's it supposed to work?
Old Jul 6, 2006 | 11:40 AM
Vette_DD's Avatar
Vette_DD
It works based on interior noise, not speed. However, several here said theirs did not work at all. Mine definitely worked in the 05 coupe, but doesn't seem to work in the 06 coupe. My 06 coupe is quieter at higher speeds than the 05 was. That might have something to do with it.
Old Jul 6, 2006 | 11:46 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
I notice mine working, especially when I drove without the top and had the volume fairly loud to begin with. But it seemed like there were only 3 or 4 volume changes, so every time it got louder or quieter, it was a noticable step. Aren't there a couple settings to choose from? Maybe yours is on the lowest setting. IMO, it's pretty much useless so I turned it off.
Old Jul 6, 2006 | 11:50 AM
EuroRod's Avatar
EuroRod
Can't remember a post saying that the volumn control worked in their C6. There were many that could not notice any difference. Know it never worked in mine.
Old Jul 6, 2006 | 11:56 AM
Dueysan's Avatar
Dueysan
Yeah mine works..06 vert..when I come to a stop it turns the music down ALOT...very noticeable...I just turn it off now...it's more annoying than useful.
Old Jul 6, 2006 | 11:58 AM
LS WON's Avatar
LS WON
Does anyone know if you were to go aftermarket can you get this feature or retain it?
Old Jul 6, 2006 | 12:49 PM
LouG's Avatar
LouG
I have an 06 Vert with navigation. Mine does not work.
Maybe because of the navigation? My C5 had an adjustment on how much decrease or increase the volume while riding. I don't see that adjustment for the C6.
Old Jul 6, 2006 | 12:55 PM
The Squeaky Wheel's Avatar
The Squeaky Wheel
Mine definitely works.
06 coupe with Bose - no Nav.
It's the only thing I like about the Bose system.
Old Jul 6, 2006 | 12:59 PM
vetteluvr452005's Avatar
vetteluvr452005
I HATE volume control so if it works on my C6 or not I have no idea because I wouldn't use it anyway.
Old Jul 6, 2006 | 01:01 PM
bradb's Avatar
bradb
St. Jude Donor '06-'07
My 05 Vert's Non-Nav Boze AL is possessed by demons.
There are times it should work: Top down, lots of traffic noise or road noise.... I would expect a slight increase in volume. Then, as I stop or ambient sound levels decrease, it should gently return to the set volume.
Sounds easy.
My system has a 'feature" that simply raises the volume at odd times. Just yesterday I was cruisng down the freeway, listening to an MP3 filled CD, when I exited and came to the stoplight. The demonic AL spun its head around twice, turned green and RAISED the volume enough that I reached over and turned the vollume down a click.
BWAHAHAHAHAAAaaaaa, I love it! Yep, I'm really happy with the sound system in my car. No bottom, rattling door panels, tinny highs and muddled midrange. A perfect balance of crud. AND, the volume wanders.... yee-haw!
Old Jul 6, 2006 | 01:04 PM
butlermd's Avatar
butlermd
multiple posts on this...many if not most seem to say they hear no discernable difference...that is to say it does not work. On my '06 with nav it doesn't seem to do anything.
Old Jul 6, 2006 | 01:05 PM
CessnaDriver's Avatar
CessnaDriver
Someone here said that it is not really simple volume adjustment but tones being adjusted depending on interior noise.
Old Jul 6, 2006 | 01:41 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I have the same car, but mine has never worked. I wish it has the speed sensitive control from my C5, at least it worked.
Old Jul 6, 2006 | 01:48 PM
Vette_DD's Avatar
Vette_DD
2006 owner's manual, page 3-81.
If your vehicle has the Bose® audio system, it includes
Bose® AudioPilot® noise compensation technology.
When turned on, AudioPilot® continuously adjusts the
audio system to compensate for background noise,
so that your music always sounds the same at the set
volume level. This feature is most effective at lower radio
volume settings where background noise can affect how
well you hear the music being played through your
vehicle’s audio system. At higher volume settings, where
the music is much louder than the background noise,
there may be little or no adjustments by AudioPilot®.
I think some folks here didn't read the last sentence in the above paragraph.
Old Jul 6, 2006 | 02:03 PM
bradb's Avatar
bradb
I seldom turn my volume up past 4 and usually listen to it at 3. The Bose® Audio Pilot® is virtually® a non-feature® and I wish® I had a different Sound System® in my Corvette®™.
Old Jul 6, 2006 | 02:07 PM
dvu's Avatar
dvu
Mine seems to work w/o any problems. I only wish you could conrol by how much it increases (too much of an increase in vol), but then again, maybe the computer is suppose to figure that out for me.
Old Jul 6, 2006 | 02:08 PM
Saba Dane's Avatar
Saba Dane
To Automatic Volume Control
Old Jul 6, 2006 | 02:13 PM
63C663's Avatar
63C663
O5 Coupe with Nav - the piece of crap does nothing in my car - I'm continously adjusting the volume!
Old Jul 6, 2006 | 02:19 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
ditto
Old Jul 6, 2006 | 02:29 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Rumor has it the car has AVC. IF it has it, it does not work near as well as in the other GM products that I have had.
