Warped Vette?
Old Aug 1, 2006 | 07:24 AM
franking50's Avatar
franking50
Default Warped Vette?
Strange but possibly true.It reached over 100 degrees here in the Chicago suburbs yesterday and it was miserable.I parked my Black C6 coupe outside my office and when I came out for lunch I went around to the passenger side to get something out.when I tried to close the door it wouldn't!I tried 3 or four times,finally on the 5th it closed but sounded "muffled".This morning,all ok.Could the alignment of the panels have warped?
Old Aug 1, 2006 | 07:31 AM
StanNH's Avatar
StanNH
Are you sure your windows are indexing properly? I've never heard of any issue with the plastic warping due to heat.
Old Aug 1, 2006 | 07:35 AM
SickRick's Avatar
SickRick
Most likely a panel alignment issue. Seen more on black than other colors. My car does it on the drivers door. After sitting in direct sunlight for awhile, it "catches" the front fender down low where it curves out.
Look for telltale paint scratches where the panels are making contact. If it's under warranty, take it to the dealer - though odds are, they'll just mis-align the panel somewhere else to compensate...
Rick
Old Aug 1, 2006 | 08:01 AM
AU N EGL's Avatar
AU N EGL
All the pannels will expand and contract some with heat. Darker pannels a bit more.
Old Aug 1, 2006 | 08:25 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I recall reading previous posts about similar door alignment issues (you might want to do a search for). I think it was an easy warranty fix at the dealership.
Old Aug 1, 2006 | 10:28 AM
TonyC6Go's Avatar
TonyC6Go
Warp??? I live in Texas, and the car sits outside in 95+ heat, 5 days a week for months on end, and no problems in terms of warping.
Old Aug 1, 2006 | 10:30 AM
TonyC6Go's Avatar
TonyC6Go
Originally Posted by franking50
...when I tried to close the door it wouldn't!I tried 3 or four times,finally on the 5th it closed but sounded "muffled".This morning,all ok.Could the alignment of the panels have warped?
Sometimes you have to give it good hard close - you may have been too soft on closing the doors. I've had that happen a few times where I lightly close the door and it won't close, so I give it a good hard push, and all is good.
Old Aug 1, 2006 | 11:43 AM
shopdog's Avatar
shopdog
The panels do grow with increasing heat. This can close up the gaps between panels and cause them to rub.
Old Aug 1, 2006 | 12:06 PM
double eagle's Avatar
double eagle
It's a living, breathing machine.
Old Aug 1, 2006 | 12:16 PM
Landru's Avatar
Landru
Rick, that's [sick[/i].
Old Aug 2, 2006 | 12:10 AM
franking50's Avatar
franking50
Thanks for the feedback.I'll just chalk it up to "unknown causes".Taking it in to the dealer for anything isn't high on my to do list.
To Warped Vette?
