computer reprogram for DBS??
Old Oct 17, 2006 | 05:44 PM
6speedC6's Avatar
6speedC6
Default computer reprogram for DBS??
After sitting for 7 day my C6 6speed was dead as a door nail. Third time since I have owned it. Charged the Battery and took it in to local dealer. They checked the obvious and reprogramed the computer per the TSB.
Anyone had this done and it cured the DBS????
Old Oct 17, 2006 | 08:20 PM
JSTMYSPD's Avatar
JSTMYSPD
I begged mine to do it.10/14,They went and changed the battery.We'll see what happens. 05/mn6
Old Oct 17, 2006 | 08:34 PM
Hoonose's Avatar
Hoonose
My dealer was clueless...
Old Oct 17, 2006 | 08:42 PM
VET4LES's Avatar
VET4LES
Why? Did you need a new battery? I hope it was free under warranty. Did they not know about the new flash?
Old Oct 17, 2006 | 08:47 PM
JSTMYSPD's Avatar
JSTMYSPD
I've had 2 dbs's in 18mo. Battery wouldn't hold a charge at all.I brought flash number and they could have cared less.Battery was free under warr.Maybe it was just a "bad battery" but I would have been happier if they did the flash since they had the car.
Old Oct 17, 2006 | 08:49 PM
VET4LES's Avatar
VET4LES
The good news is you have a free new battery and if it happen's again you will get the flash.
Old Oct 17, 2006 | 09:38 PM
MN_Corvette's Avatar
MN_Corvette
I don't understand why they don't just reprogram the flash regardless of any other issues. Are they afraid that it might break something? Doesn't make too much sense to me.
Old Oct 17, 2006 | 10:35 PM
mjscorvette's Avatar
mjscorvette
I had my 05 MN6 BCM reflashed last week based on the PIC for draining batteries. After 3 DBS incidents, the dealership also changed the battery since the overall battery condition was not up to specs. Even with the reflash, I am keeping the car on a battery tender if not used for a few days.
Mark
Old Oct 17, 2006 | 11:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Although my 2005 has never failed to start (even after having it parked for up to a couple weeks) and I wouldn't let anyone reflash the PCM after the edit tune for the LPE 403 motor....I'm curious about the DBS computer 'cure.' Does anyone know what is specifically changed with the reflash?
Old Oct 18, 2006 | 12:00 AM
Hoonose's Avatar
Hoonose
All I know is what I read here, and apparently the reflash causes the BCM to ignore certain shut down anomalies and let the darn thing go to sleep anyway. The flash is not recommended unless you've had DBS.
Your tune is in the ECU, the reflash concerns the BCM.
Old Oct 18, 2006 | 10:41 AM
6speedC6's Avatar
6speedC6
My dealer didn't know about the reflash, but they made the effort to find out.
Old Oct 18, 2006 | 11:03 AM
Hoonose's Avatar
Hoonose
My dealer remains clueless...
Old Oct 18, 2006 | 11:07 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
mine also.
Soon to be put away for winter. (3 weeks+ -) Possibly better luck next year
Old Oct 18, 2006 | 11:28 AM
Hoonose's Avatar
Hoonose
We don't do winter here....
Old Oct 18, 2006 | 11:39 AM
6spdC6's Avatar
6spdC6
Understand that. Went to see the Dam on a Vagas trip. Saw temps of 115 when we stoped at a large Marina about a hour up Lake Mead.
Old Oct 18, 2006 | 11:40 AM
mjscorvette
I learned the hard way that if the dealer is clueless, go to another dealer that is not. All they need to do is look up PIC 4188 or PIC 4188A and, if they can read English, the answer is within.
I recently switched dealers and my service experience went from horrible to excellent. Do not put up with it.
Mark
Old Oct 18, 2006 | 12:06 PM
Hoonose's Avatar
Hoonose
Originally Posted by mjscorvette
I learned the hard way that if the dealer is clueless, go to another dealer that is not. All they need to do is look up PIC 4188 or PIC 4188A and, if they can read English, the answer is within. I recently switched dealers and my service experience went from horrible to excellent. Do not put up with it. Mark
I GAVE him the 4188 sheet!!!
Still no joy.
I'll hit him up again next month, when I bring it in for the 'rocking seat'...
To computer reprogram for DBS??
Old Oct 18, 2006 | 12:25 PM
timd38's Avatar
timd38
I have seen nothing that says the reflash works. Just another "fix" that doesn't work.
My dealer says my roof is OK on both 2006s because they are not on the list of problem VINs. One was build in Aug 2005 and the other in Dec 2005........ If they can't get a simple thing like this straight, why do you think they can fix an electrical system issue.
Old Oct 18, 2006 | 12:53 PM
Hoonose's Avatar
Hoonose
It's still too soon to say much about the 'fix'.
Only for the simple reason that GM is finally in agreement with my own theory.
Old Oct 30, 2006 | 03:47 PM
JSTMYSPD's Avatar
JSTMYSPD
Today makes 3 times......maybe wed. they will do flash....or maybe they will blow smoke up my azz again....we'll see...
