Weird noise........
Old Oct 20, 2006 | 09:23 PM
us2bsrt's Avatar
us2bsrt
Default Weird noise........
for just a brief second when I start my 06 C6. When I start the car for just a split second I think i hear the radio or some kind of radio sounding static. The problem is .... The radio IS NOT ON!! I thought I was losing my mind... bit.. it happens EVERYTIME I start the car,and I always turn off the radio before I shut off the car. Anyone else have this happen. or is mental illness creeping in. P.S ... Just went outside to check this phenomenon again.... I started the car and it happened again. Then (while the car was running) I turned the radio on. Then I turned the radio off and shut off the car. I started it again and I swear for a second I heard radio static. WTF????????
Old Oct 20, 2006 | 09:29 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I really don't have a clue on this but can you replicate the exact noise (you hear at startup) with the radio? Do you have OnStar or NAV? Could those be the source of the noise?
Old Oct 20, 2006 | 09:36 PM
us2bsrt's Avatar
us2bsrt
Good ques. Going to work now and I will listen for that. I do not have either Nav or ONSTAR. Very strange.
Old Oct 20, 2006 | 10:58 PM
Vet's Avatar
Vet
That's normal. I hear that all the time too. There have been threads about this in the past as well. Apparently when you start the car, the electronics "boot up" and you hear some sounds from the speakers momentarily... almost like a strange high pitched static noise as well as a hiss.. but just for a split second or so. Don't worry about it. As some say, the C6 is a "laptop on wheels"... when you think of it that way, the "boot up" noise will not bother you.
Old Oct 21, 2006 | 05:19 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Could be the amp or the chime module just getting initialized.
Old Oct 21, 2006 | 07:14 AM
us2bsrt's Avatar
us2bsrt
Thanks fellas.You saved me the trouble of dragging the wife out of bed to listen for the"WHITE NOISE".
Old Oct 21, 2006 | 08:35 AM
beaversstonehaven's Avatar
beaversstonehaven
Yep. Mine does this too.
Old Oct 21, 2006 | 09:05 AM
robertpel9's Avatar
robertpel9
Mine too, its normal
To Weird noise........
