Window Dots..... Why??
Old Mar 8, 2007 | 10:40 AM
mickeykelley's Avatar
mickeykelley
Originally Posted by C-INRED
It's a Communist dot.
Now that is humor!!!!!!!
But the real answer is that originally the dots covered the entire window, but they recieved too many customer complaints about not being able to see out the of window, so they took off the bottom portion.
I know the ones around the front window edges are there to protect the gasket/sealer used to install the glass from the UV eventually causing deterioration and ultimately failure. That is according to a glass guy who replaced a front window on the Suburban.
Old Mar 8, 2007 | 10:45 AM
07C6NTX's Avatar
07C6NTX
Originally Posted by Wayne O
I think this is true. I believe the radio antennae is behind the rear fascia but my service advisor (at my local dealership) told me tinting the window could adversely affect radio reception. FWIW, most C6 owners I asked did not experience degraded radio reception after tinting their rear window.
I found my old post....I believe calemasters called it a "diversity antenna."
I find it hard to believe it has ANYTHING to do with the radio antenna. My wife's Cobalt SS has the dots and a fixed antenna so it makes no sense to think it has anything to do with the radio since her car has both.
Just my 2 cents...........
Old Mar 8, 2007 | 11:35 AM
C6VetteRocks's Avatar
C6VetteRocks
Default Not Dot Antenna
While I don’t have a clue what they do do, I do know they have nothing to do with the antenna system on the C6. XM has their wart. The AM and FM antennas are, as mentioned above, located ageist the outside of the trunk, behind the fascia. The antenna is, as stated above, a diversity type. It used a left side antenna and a side right antenna. The magic Antenna Control Module is inside on the left side of the latch mechanism and combines the two inputs and sends it to a single cable to the head unit. The ACM also powers the antennas and switches between AM and FM reception. As long as you don’t metal tint your fascia, tinting should not matter to AM, FM, or XM. In fact when I changed my NAV head unit for a Pioneer AVIC-Z1 and added its XM-Traffic and Sirius receivers I mounted the warts to the outside trunk wall between the break lights behind the fascia. They work just fine with strong reception. I plan to mount the TV module antennas to the inside of the fascia.
Old Mar 8, 2007 | 11:52 AM
Vette_DD's Avatar
Vette_DD
They are also to help block out the sun in the area around the rear view mirror where the sun visor doesn't reach.
Old Mar 8, 2007 | 02:30 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by xtacy187
These dots act as radio signal receptors as opposed to the antennas used on older vehicles..
Originally Posted by UTVOL06
probably built in radio antenna.
None of that is correct. I had the "dots" on the rear hatch of my '83 Trans Am...which had a regular, "plain old" antenna on the front, right fender. I'm pretty sure that the dots in the rear hatch had nothing to do w/the radio antenna mounted on the front fender. Same goes for an '88 Caravan my parents had.
Old Mar 8, 2007 | 02:52 PM
BLU-BY-U's Avatar
BLU-BY-U
i think this is probably the right answer. They're most likely on the rear window to eliminate glare when using the rearview and/or turnig your head to look out back. and it's not just gm. ford does it too
Old Mar 8, 2007 | 03:07 PM
larrysb's Avatar
larrysb
The dots are part of the silkscreened pattern of primer applied to the edges of the window. The windows on most modern cars are flush mounted and glued in with polyurethane sealant. To assure good sealing, a priming material is printed onto the periphery of the window. This material adheres better to the sealant than bare glass.
The dots serve to form a gradual transition from the opaque sealing area to the transparent glass. The margins are wide, which allows for production variance - aka slop - in the application and mounting of the flush mounted, glued in glass.
Old Mar 8, 2007 | 03:11 PM
GQMGT's Avatar
GQMGT
Are you looking at the glass with sunglasses on? I've found that they are more pronounced with polarized sunglasses on. Take the galsses off and the dots go away.
Old Mar 8, 2007 | 03:17 PM
shaunsexton's Avatar
shaunsexton
well i know they have nothing to do with radio anything. so we can drop that. I'm pretty sure there just a way to reduce glare and still be able to see through it. I cant possibly think of any other purpose they would serve.
Old Mar 8, 2007 | 03:32 PM
armyyellow05's Avatar
armyyellow05
The black dots, or matrix patterns, as well as the lines at the top of some windows are made of a Teflon type of material that is applied at the factory. Purely cosmetic, they hide trim lines and edges on different styles of autos. The thickness of these Teflon type areas make them a nightmare when applying window tinting. Window tint is designed to adhere directly to the glass. The black lines across the top of some windows can prevent window tinting from sticking and cannot be covered. When black dots are encountered, the window tint sticks to the slightly raised dot. This can give, depending on the thickness of the material, a lighter or different look in the area of the black matrix dots. This poses no risk for peeling. In some cases, the dot pattern or lines usually put at the top of some windows are so thick that it makes it impossible for the tint to stick at all.
Old Mar 8, 2007 | 03:36 PM
yn1bennett's Avatar
yn1bennett
Default The Dots are....
The Dots are a way for the heat to dissipate from the window.
Old Mar 8, 2007 | 03:37 PM
BLU-BY-U's Avatar
BLU-BY-U
just had my Z tinted with formula 1 ceramic tint about 3 weeks ago. The dots are a nightmare...but I took my installers advice and rubbed them with the back of my finger (not nail) repeatedly for several days. And I left the car in the sun. It actually looks much better today than after initial install. I can't complain.
Old Mar 8, 2007 | 04:35 PM
  #33
hulksdaddy's Avatar
hulksdaddy
So new cars have them, but older cars don't? It's obvious then.....
ACNE!
Old Mar 8, 2007 | 05:09 PM
  #34
liberty's Avatar
liberty
Who's messing with my dots? You messing with my dots?
Old Mar 8, 2007 | 06:21 PM
  #35
SheLovesBlue's Avatar
SheLovesBlue
If windows were clear, we'd all be buying those "hot new dot patterned vinyl speed graphics" for our back glass.
Old Mar 8, 2007 | 07:31 PM
  #36
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
I believe larrysb is 100% correct. As best that I recall, the first vehicle I ever had with the window dots was a 1986 Taurus, the first car with "flush glass." When the window glass went to flush design, it had to be glued into place, thus the edges of the glass had to be opaque to hide the glue, and the dots are supposed to be a more eye-appealing transition than a hard edge. All mfrs do it now, not just GM, and it has nothing to do with antennas.
As another poster noted, tint installers will tell you to warm the tint in the sun and press the tint to the dots with your fingers for the first few weeks and this will help keep the tint from standing off the glass in the tops of the dots. I've done this on my last two Vettes and it has helped a lot.
Old Mar 8, 2007 | 07:37 PM
  #37
PAVette's Avatar
PAVette
They provide sun protection...they are often heaviest around the rearview mirror where the sun visors don't cover.
To Window Dots..... Why??
Old Mar 8, 2007 | 07:49 PM
  #38
Sunnyvale Dave's Avatar
Sunnyvale Dave
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
I thought it was the result of a poor quality tint job.
Old Mar 8, 2007 | 07:54 PM
  #39
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
they are there to **** of the tinters..
Old Mar 8, 2007 | 08:17 PM
  #40
LJD51's Avatar
LJD51
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
Developed by the CIA and NSA at the Area 51 Skunkworks, the dots have no useful purpose other than to drive you .
