Where should I get an alignment?
Old Mar 29, 2007 | 06:55 AM
cmb13's Avatar
cmb13
Default Where should I get an alignment?
Dealer, Goodyear, or Local Shop???
Old Mar 29, 2007 | 10:35 AM
haljensen's Avatar
haljensen
Local shop, preferably privately owned. If the shop is any good they will ask you your driving style and whatyou want from the alignment. You will get exact specs, no + or - like in the factory specs.
I put around a thousand miles on my car to let the suspension settle then had a 4 wheel alignment done at a local shop for $99.95.
Old Mar 29, 2007 | 11:20 AM
6 speed Sid's Avatar
6 speed Sid
I prefer a local shop where I can watch the guy work and see the changes being made. I hate the dealerships ( not all like this) where your car disappears behind an iron curtain not to be seen again until finished and no contact with any one except the new hire that writes the order.
Old Mar 29, 2007 | 11:30 AM
rothchilds's Avatar
rothchilds
I go to a local shop I have used for a long time. $69.99 for a 4 wheel alignment.
Old Mar 29, 2007 | 11:33 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Is there a reason why you think you need an alignment?
I'd go with a qualified local shop provided they have previous experience working on the C6.
Old Mar 29, 2007 | 12:07 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Personally I would go to a local shop. I think you will get more from a shop that knows more about alignment versus a dealer that has to stay within GM specs.
As an example my street tires require at least -1.5 front camber which is outside of GM specs. I am not sure if I went to GM if they are allowed to go outside their specs.
Old Mar 29, 2007 | 12:27 PM
Lightning Coyote's Avatar
Lightning Coyote
I have a local shop that I've used before with very good results.
Old Mar 29, 2007 | 12:53 PM
cmb13's Avatar
cmb13
Uneven tire wear. The outside of the R front tire is down to wear bars, but the inside and the other 3 are not yet there. I've got nearly 12k on the car.
When you say local shop, what kind? Is that a tire dealer, or are there places that specialize in alignments?
Anyone know of one by me?
Old Mar 29, 2007 | 01:16 PM
dark_phantom's Avatar
dark_phantom
From: Central Florida. Black Sheep Squadron Member. 465 rwhp & 477 rwtq
Cruise-In VIII Veteran
St. Jude Donor '07
Craig,
I took mine to a Firestone Complete Auto Care shop. It was recommended by a few people. You might want to ask around in the SE area so that you get a place where they've done vettes before.
Old Mar 29, 2007 | 01:53 PM
shopdog's Avatar
shopdog
More important than who owns the shop is who is actually doing the work. I take my cars to a local shop where the guy doing the work has many years of experience with performance car alignment. He wants to talk to you about how you drive the car, what you want the car to do, etc before doing the alignment. Then he sets it up just the way you want it to be. The factory specs are quite loose. Most shops will just set the car to fall inside the specs and call it done. My guy won't. He wants it just right for what you do with the car.
Old Mar 29, 2007 | 02:01 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
Ask around for local shop recommendations among other enthusiats in your area.
Old Mar 29, 2007 | 02:49 PM
greenie99's Avatar
greenie99
[QUOTE=cmb13;1559585996]Dealer, Goodyear, or Local Shop???[/QUOTE
Probably at all 4 wheels!!!
To Where should I get an alignment?
