Paint Code?
Old May 17, 2007 | 06:12 AM
Stingray55's Avatar
Stingray55
Default Paint Code?
I want to do the ZO6 rear fenders on my 06 C6, does anyone know the paint code for Machine Silver,or where to look for it on the car?
Old May 17, 2007 | 08:16 AM
karguy6's Avatar
karguy6
67U ~ machine silver
Old May 17, 2007 | 08:21 AM
MN CHOPPER's Avatar
MN CHOPPER
right on the $$$
Old May 17, 2007 | 10:41 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Ask for 67U down at the paint store, and they'll stare back at you like you just landed from outer space.
Use the "WA" paint code off the paper sticker on the back of the glove box door. You'll find it down toward the bottom of the equipment code list; it may start with a U or a W, or not. The paint plant could have accidentally dumped an extra five gallons of black into that batch of Machine Silver on your car, and, Wahlah!!!, new Machine Silver paint code.
Old May 17, 2007 | 11:04 AM
Stingray55's Avatar
Stingray55
Thanks for the tip, this forum is " FANTASTIC. "
Old May 17, 2007 | 11:14 AM
JmpnJckFlsh
Be sure to take your VIN number with you down to the paint store if you're buying the paint.
Even though you tell them a perfectly accurate paint code right off your car, the DuPont seller will be negligent if he doesn't confirm your code by asking the year, make, model, VIN, and GM color name to run the info through his computer. The computer then will confirm the code, and show him the EXACT proportions of components to mix...how well the guy doing the mixing can measure will determine how well the paint matches.
Old May 17, 2007 | 03:48 PM
Zymurgy's Avatar
Zymurgy
Moderator
Paint code is WA994L.
See the attached PDF that I created from the GM Color Compatibility Guide:
To Paint Code?
