TPMS Reading Problem
Old Jun 24, 2007 | 08:14 PM
S2K's Avatar
S2K
Default TPMS Reading Problem
I took on the caliper painting DIY project this weekend. Of course this called for removing the tires. One of the tires I removed turned out to have a nail in the tread. I loaded that tire into the SUV and had the wife take it to Goodyear for repair.
When I got the tire back, I mounted it in the same spot. I took a manual tire pressure reading and found it at 39 psi. I let out 9 psi to get it back to 30. When I fired up the car and used the DIC to see all pressures, that tire kept reading 39 psi (the other tires were correct). I did a manual check again and the pressure is indeed 30 psi. I could not find anything in the manual about resetting it, if that would even be the correct course of action.
What do you think the issue is?
Old Jun 24, 2007 | 08:31 PM
CQRT's Avatar
CQRT
Remember that the car has to travel a few miles for the TPS to update the DIC . . . to the best of my understanding, it doesn't update while the car is turned off or at idle.
Glad you caught the nail before it caused a greater problem!
Old Jun 24, 2007 | 08:35 PM
MySea6's Avatar
MySea6
I would take it for a short drive to see if it begins to read properly, it probably will. If not, run it by your dealer for a reset.
Old Jun 24, 2007 | 08:36 PM
S2K's Avatar
S2K
A bit of a false alarm, it is fine now. When I saw the issue, I drove for about a 1/2 mile. Came back and the issue remained. Turned the car off and back on, and it was still wrong. Let the car sit for 10-15 minutes, and started it again. The TPMS was correct. Guess I should have given it more time, but I'd still like to know under what conditions it resets.
Old Jun 24, 2007 | 08:41 PM
MySea6's Avatar
MySea6
VET4LES's Avatar
VET4LES
It's my understanding it updates approximately every 15 minuets while sitting with the ignition off.
Old Jun 24, 2007 | 08:53 PM
Wayne O's Avatar
Wayne O
CF Senior Member
I'm glad it worked itself out. FYI...you can go to most any Discount Tire outlet and they'll re-set your sensors without charge.
At least that was my experience...I recently bought a re-set tool (through our resident TPS expert beezeye) but before the tool arrived, I needed to 'register' my new TPS's...Discount Tire did it gratis.
Old Jun 24, 2007 | 09:23 PM
BEZ06's Avatar
BEZ06
When you park the car and it remains motionless for 15 minutes the sensors go into a "sleep" mode to save the batteries - the sensors only transmit once every 60 minutes.
When you start driving the car, centrifugal switches in the sensors detect wheel rotation when you get up to about 20 mph and the sensors start transmitting once per minute (although I've also read that it's once every 15 seconds - and I think if they detect a certain change in pressure like a tire going flat, they'll transmit immediately).
So......like other posts have said, after the car sits still for a while you'll need to drive it up over 20 mph for a short while to get the sensors transmitting the proper tire pressures to the TPMS and the DIC display.
Bob
Old Jun 24, 2007 | 09:28 PM
BEZ06's Avatar
BEZ06
Hi Wayne
Yeah, it will be nice to have your own tool!
Did the Discount guys know how to do the procedure, or did you have to help them out getting it into the learn mode?
I've got a couple tools ($160 shipped) if anybody else needs their own.
Bob
Old Jun 25, 2007 | 03:15 PM
adlerm01's Avatar
adlerm01
Hi. I'm interested in getting one of those tools. Where did you get one for $160, and does it work on other model cars?
Thanks.
Mitch
Old Jun 26, 2007 | 03:26 PM
carjon's Avatar
carjon
Had a similar problem and pressed the reset button at the bottom of the displays and it seemed to cause the update to happen. It could have been just good timing but this seemed to cause an immediate read of the pressures.
Old Jun 26, 2007 | 03:53 PM
S2K's Avatar
S2K
Actually I tried that as well when I was thinking there might be a "reset" feature. It didn't work. I think it might have been good timing for you.
To TPMS Reading Problem
