Interior Smells
Old Jul 16, 2007 | 10:19 PM
Horses & Horse Power's Avatar
Cruising
Default Interior Smells
June 13, 2007 I became the proud owner of my 1st corvette. A 2005 C6. With 1800 miles on this beauty I cannot understand why @ start up there is a strange oder coming from the A/C. Is there a filter I could change?
Old Jul 16, 2007 | 10:23 PM
streetsweeper's Avatar
streetsweeper
i have a brand new 07 and it does the same thing- if i had to describe the smell, i would say it smells like natural gas.
anyone?
Old Jul 16, 2007 | 10:32 PM
twfreightman's Avatar
twfreightman
Did you change your oil recently? Maybe you are just smelling a little oil spill burning off??
Old Jul 16, 2007 | 10:34 PM
armyyellow05's Avatar
armyyellow05
Chances are there is some mold on your in cabin air filter. Replace that and your odors are likely to disappear.
Old Jul 16, 2007 | 11:25 PM
UmCanesZ06's Avatar
UmCanesZ06
I had the same problem. But mine smelled like a urinal. The coils on the evaporator or condenser(cant remember which) had fungus growing in and on it. You need to bring it to the dealer or an a/c shop so they can clean and disinfect it.
Old Jul 16, 2007 | 11:48 PM
User 020720's Avatar
User 020720
If your interior smells like a urinal I'm not about to comment on that one.
Sorry couldn't resist.
Old Jul 16, 2007 | 11:58 PM
UmCanesZ06's Avatar
UmCanesZ06
Well, to be specific, it only smelled like it when you put the air on. I thik its a pretty common thing. If not than maybe somebody was pissing in my car.
Old Jul 17, 2007 | 03:14 AM
CHEVY 23's Avatar
CHEVY 23
Old Jul 17, 2007 | 07:13 AM
Les-10's Avatar
Les-10
Bow-Tie Guy
I would at least try this 1st!
Old Jul 17, 2007 | 10:34 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Open the hood. It sits on the passenger side - 2-3 clips - it inserts horizontally.
If you are in a HOT area, when in AUTO mode, the AC recalculates more. That may cause mold build up. Switch recirc “OFF” more frequently.
1. Take out the cabin air filt.
2. Brush it off.
3. Back blow with air.
4. Spray it with Lysol
5. Ensure you turn recirc “OFF” occasionally in the future
Old Jul 17, 2007 | 10:37 AM
bub's Avatar
bub
I run my blower with the AC compressor off for a little while before shutting down to dry out the evaporator coils to try to minimize this.
It's happened on every C5 & C6 I've had. Even talked to Dave Hiull about it once. Seems like a TSB came out for humid climates that incorporated some relay to run blower post shutdown to dry and also listed procedure for disinfecting coil. Not sure if this TSB still applies to the C6, but assume it does.
Regarding the post above on not using recirc., I think that would actually hurt the situation, as recirc. is relatively dry conditioned air vs. outside air at a higher moisture content.
-CKB
Old Jul 27, 2007 | 01:03 AM
itspapos's Avatar
itspapos
4th Gear
Default pics anyone
Anybody have some pics of where the cabin filter is located... is it easy to find? Its a bit late but I am going to look for t tomorrow! My car, 02 c5 with 12k stinks EVERY morning lately.. Thank you if you can help me locate the filter!
Old Jul 27, 2007 | 04:29 AM
Gundam's Avatar
Gundam
It's near the top of the engine bay on the passenger side, kinda near the battery. This is for the C6, not sure about the C5.
Old Jul 27, 2007 | 04:38 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Look just a few inches below the top of the firewall just slightly inboard of the battery on a C6.
Old Jul 27, 2007 | 06:44 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The cabin air filter that the above posters are describing is on a C6 Corvette (2005-2008). You won't find it there for a 2002 C5.
Old Jul 27, 2007 | 07:46 AM
Mad*Max's Avatar
Mad*Max
That won't make a difference
Old Jul 27, 2007 | 08:17 AM
Chuck Mahnke's Avatar
Chuck Mahnke
I've had the same problem with my '05 (12K miles). Replaced the filter with no change in the odor. Dealer has a disinfectant on order as per a TSB so we'll see if that helps. By the way, an area dealer ran an ad to replace the C6 passenger compartment filter for a "special price" of only $49.95. I bought a Purolator Cabin Air Filter, part no. C25623, from Advance Auto for $12.05 including tax and it took me 5-10 minutes to do the replacement.
To Interior Smells
Old Jul 27, 2007 | 03:33 PM
boiler's Avatar
boiler
My 07 coupe (built 2/07) has the same AC smell plus an epoxy or resin smell. Anybody else?
Old Aug 7, 2007 | 09:00 PM
itspapos's Avatar
itspapos
4th Gear
Default so any help on the C5'S
so can anyone tell me how to get to the cabin filter on the c5's.. my car still stinks when i turn on the ac... then it goes away in 30 seconds or so! thank you for your help.. Jesse
Old Aug 7, 2007 | 09:11 PM
Get-EmC6's Avatar
Get-EmC6
Cruising
I've had the same problem with mine. After hours of water test it turned out to be a small gap in the boding of the area between the cabin air filter area and the body of the car. The only way to fix is to remove the cal cover and and seal it up with rtv silicone. i replace windshields for a living and water leaks are the most common cause of a mold smell. This is very common with GM cars. it can be fixed very easy, but it takes a lot of time to figure out. Also no smell for a good four months now!!
