Shifting problem
Old Jul 17, 2007 | 04:38 PM
rs46246's Avatar
rs46246
5th Gear
Default Shifting problem
I have a '06 Z51 6sp and have had a shifting problem when doing a full throttle upshift to 3rd gear. The shifter appears to have moved into 3rd gear position, but doesn't actually make it into gear. Seems to almost be in-between gears. Someone also noted that when that happens my rear reverse lights came on. Has anyone experienced anything like this??
Old Jul 17, 2007 | 06:37 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Do a search on Ranger's posts for how to shift, how to practice shifting, and how to master the art of shifting the C6 MN6 transmission.
Old Jul 17, 2007 | 06:48 PM
WoodChuck2's Avatar
WoodChuck2
Where Can I Find Ranger's Post?
Old Jul 17, 2007 | 07:16 PM
Pipedreams's Avatar
Pipedreams
St. Jude Donor '06-'07
I will make this very simple. I say simple because it is. When you go to shift to 3rd, just lightly cup the **** in your palm and push straight up to the radio (not left or right) straight up and firmly. The shifter is designed to center on 3rd, your attempts to grip the **** and guide it into 3rd is what causes the problem. Believe me it works, practice with the car off and the clutch pressed in.
Old Jul 17, 2007 | 07:18 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
Originally Posted by Pipedreams
I will make this very simple. I say simple because it is. When you go to shift to 3rd, just lightly cup the **** in you palm and push straight up to the radio (not left or right) straight up and firmly. The shifter is designed to center on 3rd, your attempts to grip the **** and guide it into 3rd is what causes the problem. Believe me it works, practice with the car off and the clutch pressed in.
that'll do it!
Old Jul 17, 2007 | 07:29 PM
baddbilt1's Avatar
baddbilt1
I had the same problemn untill i got a new callway shifter!
Old Jul 17, 2007 | 08:19 PM
Pipedreams's Avatar
Pipedreams
I glad that worked for you. If you installed the shifter yourself you noticed the shifter has no gates so it has almost zero to do with the shifter
Old Jul 17, 2007 | 08:36 PM
Ranger's Avatar
Ranger
No need for an aftermarket shifter. Just need to adjust hand position on the shifter and do some practice to embed the movement in muscle memory. It's an ongoing problem that is easily solved.
I don't miss shifts and my measured shift speed for the 2-3 is slightly faster than the 1-2 and 3-4. The reason is doing these shifting drills. I'll put it in a page on my site when I get a chance.
Ranger
Old Jul 17, 2007 | 09:09 PM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
Take a look at this: Shifting
Old Jul 17, 2007 | 09:22 PM
The Clevite Kid
Default Thanx, Ranger
Thanx for checking in with the link to your post. I have downloaded it to my hard drive. I am VERY disappointed that the moderators have not made this easy to find in the FAQ sticky - it is great information and training for all of us MN6 drivers.
Old Jul 17, 2007 | 11:46 PM
jjohn918's Avatar
jjohn918
I second your frustration.
Old Jul 18, 2007 | 12:13 AM
Wayne O's Avatar
Wayne O
CF Senior Member
When I first got my C6 I 'locked' the 2nd-3rd shift at WOT a couple times. IMO you're likely way too tense and trying to 'force' the shift. Relax! As others mentioned use more of the palm/crotch of your hand and don't try to put the shifter into 3rd....push forward with the slightest 'suggestion' towards 3rd and it will 'find its own way' into gear. Practice.
Old Jul 18, 2007 | 12:15 AM
rs46246's Avatar
rs46246
5th Gear
The reason I didn't attribute it to a poor shift is that the shifter does move forward (north of neutral) as if it is in 3rd but it isn't in any gear - if I let the clutch out I'm not in any gear, but I need to pull the shifter back downward to bring it to a normal neutral position. Is it really possible that it is just a missed shift and not a linkage type problem?
Old Jul 18, 2007 | 06:30 AM
Ranger's Avatar
Ranger
...Is it really possible that it is just a missed shift and not a linkage type problem?
It's a very common problem among drivers that grip the shifter tightly with five fingers, including the thumb. That hand position is sometimes called the "five finger death grip." It causes strong tension in the wrist and forearm that provoke lateral movement when none is intended. That grip is a root cause of missed shifts.
Again, this is a common problem almost always solved by a change in hand position described in these shifting drills.
Ranger
Old Jul 18, 2007 | 09:34 AM
rs46246's Avatar
rs46246
5th Gear
Thanks to Ranger and all on the feedback - time to work on a smoother shift while everything around me is screaming
Old Jul 18, 2007 | 09:57 AM
Ranger's Avatar
Ranger
That's exactly the reason that I do my shifting drills in the garage with the motor off (warm oil and tranny fluid). Embed muscle memory before you attempt it during max acceleration.
As an aside, fast driving is a sport. It requires techniques that can be learned, refined, and embedded through practice. Some of that practice can be done with the engine off to reduce wear-and-tare and lessen driver pressure for initial perfection.
Ranger
Old Jul 18, 2007 | 04:26 PM
Ranger's Avatar
Ranger
Originally Posted by Ranger
...I'll put it in a page on my site when I get a chance....
Done. Improved Shifting
Ranger
Old Jul 18, 2007 | 06:37 PM
427CPE's Avatar
427CPE
Tips for 1-2 and 3-4 shifts: Keep the elbow squared off and not dropped. this allows you to pull straight back.
For 2-3-> I like to almost palm shift allowing the shifter to take its own path, ie a fast but gentle push, keeping elbow squared off as much as poss.
Make sure your clutch is as fast as your are.
To Shifting problem
