Factory Alignment
Old Aug 16, 2007 | 06:02 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Default Factory Alignment
Just got back from my aligner and had them set the car.
Old (Original)
LF..............RF
cmb -0.3.....-1.1
cst 8.5......7.7
toe .22......23
LR...............RR
cmb -0.2......-0.3
toe 0.3......-0.18
New per my request.
LF..............RF
cmb -0.1...-0.1
cst 8.2.....8.2
toe 0.1.....0.1
LR.............RR
cmb -0.1...-0.1
toe 0.03..-0.03
Let's see if that wears the rubber off those tires in an even manner now.
Elmer
Old Aug 17, 2007 | 06:55 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
Did alignment to these specs require an additional shim pack or was it done just by mechanical adjustment?
Old Aug 17, 2007 | 07:05 PM
eboggs_jkvl
Moderator emeritus
Mechanical adjustment.
Old Aug 18, 2007 | 11:28 AM
carpe dm's Avatar
carpe dm
Looks good. I had to wear out two sets of front tires before I caught on...... Now I like mine just about as you have them set.
Old Aug 18, 2007 | 11:33 AM
eboggs_jkvl
Moderator emeritus
Dayem! That put a hickey in your wallet!
I figured I didn't race the car and it was just classy transportation and the tires needed to roll flat to keep the tires from scrubbing off. We'll see. This setting makes perfect sense to me to obtain maximum tire wear.
Elmer
Old Aug 18, 2007 | 11:56 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Hopefully the new specs will work better for you. I recently had help from a man I know setting-up my car for the track. When we setup the car using his home lift we noticed some minor, abnormal wear on one of my front tires. He recommended I have the car aligned and said the dealership actually does good alignment work.
I took my car to the dealership last week and had it aligned to the specs he suggested. My dealership has a special alignment 'team' that seemed to take pride in what they do. I like the computer printout showing the precise before and after alignment specs so you can verify they did it the way you want.
Old Aug 18, 2007 | 12:18 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
Old (Original)
LF..............RF
cmb -0.3.....-1.1
cst 8.5......7.7
toe .22......23
LR...............RR
cmb -0.2......-0.3
toe 0.3......-0.18
New per my request.
LF..............RF
cmb -0.1...-0.1
cst 8.2.....8.2
toe 0.1.....0.1
LR.............RR
cmb -0.1...-0.1
toe 0.03..-0.03
Elmer
Hey, just want to verify that the [0.03] toe setting for the rear is positive on LR and negative on RR.
Old Aug 18, 2007 | 12:55 PM
eboggs_jkvl
Moderator emeritus
That's what's on the chart but it is actually for all intents and purposes a "0" for the rear toe. I asked for a 0 and that is as close as he could get with the settings. The "total toe" = 0
Old Aug 18, 2007 | 01:43 PM
John's '07's Avatar
John's '07
From: I don't deserve this car, but I have arthritis and I don't deserve that either. Bay Point, FL
St. Jude Donor '06-'07
That's all Greek to me. Are you saying the alignment is not set properly at the factory? I have 11K on my '07 and the wear looks okay, but I haven't really looked at it closely. Is this something I should be concerned about?
Old Aug 18, 2007 | 01:50 PM
eboggs_jkvl
Moderator emeritus
From all I've read, it is best to check the alignment. IF IT IS PERFECT, then you will tend to wear out the inside edge of the tire before the middle or outer edge. One guy posted pictures of good tread middle and outside but cords showing on the inside edge. The camber is the culprit. The higher the camber the more it tries to ride on the inside of the tire. I wanted that down to -0.1 from the -0.45 that the factory setting calls for. The toe at 0.1 and the caster was fine as long as it was matched. My caster is 8.2 on both sides.
Old Aug 18, 2007 | 01:58 PM
eboggs_jkvl
Moderator emeritus
What were the specs you requested?
Elmer
Old Jun 17, 2010 | 11:20 AM
Quasar21's Avatar
Quasar21
Old (Original)
LF..............RF
cmb -0.3.....-1.1
cst 8.5......7.7
toe .22......23
LR...............RR
cmb -0.2......-0.3
toe 0.3......-0.18
New per my request.
LF..............RF
cmb -0.1...-0.1
cst 8.2.....8.2
toe 0.1.....0.1
LR.............RR
cmb -0.1...-0.1
toe 0.03..-0.03
Elmer
Elmer, is that last set of numbers on toe for the LR and RR correct? I went to your GY place yesterday and the tech questioned the 0.03 positive toe for the LR and the -0.03 negative for the RR. He said they would just cancel each other out.
Old Jun 17, 2010 | 11:25 AM
eboggs_jkvl
Moderator emeritus
My request was for 0 rear toe. I let that go as he said it was as close as he could get the rear. I'm not experiencing any noticeably wear on the rear.
See post #8
Elmer
Old Jun 17, 2010 | 11:32 AM
Quasar21's Avatar
Quasar21
See post #8
Elmer
Sorry, I overlooked that post. BTW.. Tony, the manager at the GY store, has transferred to another store. They have a little round girl working the counter that isn't much help.
Old Jun 17, 2010 | 11:39 AM
Silverado Desperado's Avatar
Silverado Desperado
Had one set like that when new a 2k miles and it pulled...any thoughts?
Old Jun 17, 2010 | 11:54 AM
eboggs_jkvl
Moderator emeritus
They need to do it again. It should track straight and flat. A pull is an error in alignment.
Elmer
Old Jun 17, 2010 | 11:55 AM
eboggs_jkvl
Moderator emeritus
Crap! Tony was my source! Where's the fart go?
Elmer
To Factory Alignment
Old Jun 17, 2010 | 12:10 PM
Quasar21's Avatar
Quasar21
Elmer
I don't think the little round girl told the guy who asked the exact store he transferred to. Just that he had transferred to another store in town. She would be able to tell you the store.
Old Jun 17, 2010 | 12:57 PM
Racer86's Avatar
Racer86
IF,,,,If their alignment machine and readouts ARE CALIBRATED and accurate.... many are not,, We did a small test a few years back and had a car aligned at 4 shops with "state of the art equipment". Sadly only 2 of the shops got the same numbers
Old Jun 17, 2010 | 02:10 PM
CO Lightfoot's Avatar
CO Lightfoot
Everyone with a new C6 should get the alignment checked.
Seems like pure luck if you have a good alignment from the factory. And it's not just GM vehicles... had bad alignment on a new Camry I bought years ago.
When new, the highway tracking improved a lot after I got my 09 aligned. Tires are wearing evenly 15k miles later. Probably get another year or so with the OEM supercar tires.
