Torque Wrench Recommendations
Old Nov 3, 2007 | 11:37 PM
wudturner's Avatar
wudturner
Default Torque Wrench Recommendations
I own a lot of tools but have never had a torque wrench. I know there are many torque wrenches for specific tasks, but if I were to buy just one for general use on the Corvette do you have any recommendations. I have 1/4, 3/8 and 1/2 drive socket sets. I would be interested in suggestions regarding size, brand and where to buy. Thanks.
Old Nov 3, 2007 | 11:39 PM
2bubbas's Avatar
2bubbas
I bought mine at Sears- 1/2 inch drive-
Old Nov 3, 2007 | 11:47 PM
Lead Foot 66's Avatar
Lead Foot 66
I've had my Sears Torque wrench for many years (35?). It takes 1/2" sockets (and I have a converter to 3/8") with a scale of 20' to 150'. I also have a smaller torque wrench which is in torque inches for much lower torque settings.
Whatever you do, get a good one (s), and treat it with kid gloves to preserve the accuracy of it.
Old Nov 4, 2007 | 12:39 AM
humvet's Avatar
humvet
Have same wrench and converter - 20-150 pretty much covers most situations.
Old Nov 4, 2007 | 07:30 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I have a Sears 1/2" drive that is a POS. The locking ring broke and it cost more to repair than it is worth. Snap-On is the premier wrench and worth every penney. Do you see many pro mechanics using Sears?
Old Nov 4, 2007 | 07:46 AM
rws.1's Avatar
rws.1
If you are planning on ocassional use.... mods and repairs then you can't beat Harbor Freight.
NO CORVETTE TAX ! and a Lifetime Warranty...
I have had mine for 4 years now and they still work perfectly and remain accurately calibrated.
www.Harborfreight.com
You can get 3 for $69
1/4'' SQUARE DRIVE TORQUE WRENCH
Click-stop type accurate within +/- 4%. Heavy duty cam & pawl mechanism. Reversible. Includes carrying case.
Manufacturer:Pittsburgh
Drive: 1/4''
Torque range: 20 to 200 in. lbs.
Length: 10''
Weight: 1 lb.
ITEM 2696-3VGA
$28.99
3/8'' DRIVE CLICKER TORQUE WRENCH
Click-stop type, accurate within +/- 4%. Heavy duty cam & pawl mechanism.
Drive: 3/8''
Torque range: 0 to 80 ft. lbs.
Length: 14-3/4''
Weight: 2 lbs.
ITEM 807-6VGA
$19.99
1/2" CLICKER TORQUE WRENCH
Click-stop type accurate within +/- 4%. Heavy duty cam & pawl mechanism.Reversible.
Carrying case. Lifetime Warranty.
Drive: 1/2''
Torque range: 10 to 150 ft. lbs
Length: 18"
Shipping weight: 4 lbs.
ITEM 239-1VGA
$19.99
Old Nov 4, 2007 | 07:52 AM
VET4LES's Avatar
VET4LES
Craftsman 1/2" should cover about everything you will need it for. Lowe's sell one also. I've had my Craftsman for 20 or more years. It's digital and is easy to use.
Old Nov 4, 2007 | 11:48 PM
wudturner's Avatar
wudturner
Thanks for the info!!
Old Nov 5, 2007 | 12:14 AM
torquetube's Avatar
torquetube
Snap-On dial-types are accurate (1% is available) and relatively inexpensive. Their OEM for dial-types is (or was) Precision Instruments. You can buy the Precision Instruments-branded models online for less.
Clickers are more convenient, but always less accurate and they tend to be flakier.
Of course, 1% accuracy is huge overkill outside of a lab environment, because what you're really trying to achieve is a certain amount of fastener elongation (and therefore clamping pressure) to which torque doesn't correlate especially well when the condition of the threads and clamping surfaces is uncontrolled. I've heard error figures on the order of 25% -- so don't sweat the torque readings too much.
Old Nov 5, 2007 | 09:57 AM
Irv's Avatar
Irv
I agree, but Snap-On is awfully pricey for home use. I recommend these:
http://www.torqwrench.com/
I've used these Precision Instruments torque wrenches for years now, and they are a good compromise between imported crap and Snap-On or MAC. US made, they don't need to be reset to zero torque for storage, reasonably priced, and each wrench comes with a calibration sheet.
Old Nov 5, 2007 | 10:26 AM
LawrenceFromTorrance's Avatar
I have 2 torque wrenches, one where you spin the setting and it clicks when the torque hits the setting and the other a dial type that doesn't click. The second is best for finding out what a bolt was torqued at the first is best for setting the torque.
Old Nov 5, 2007 | 12:26 PM
GOLD72's Avatar
GOLD72
My experience EXACTLY. I couldn't even source the part to fix myself. I fixed it with a worm clamp carefully fitted and tensioned to hold the locking ring together and still be functional. Looks like hell but it works.
Old Nov 5, 2007 | 07:12 PM
Lead Foot 66
I had exactly the opposite experience with the Sears click-stop torque wrench.
I bought it in 1973 and last year the ratchet part finally broke. I took it to a local Sears store and one of the sales people searched for and found replacement parts. He then took 45 minutes rebuilding it, all for no charge, as it has a lifetime warranty. I could have exchanged it for a new one, but we both agreed the the old one I had was better.
Then, for one penny each, I bought a couple more ratchet replacement kits. Now that is service. I expect to pass that torque wrench down to one of my grandsons someday.
Old Nov 6, 2007 | 08:58 AM
ProfMoriarty's Avatar
ProfMoriarty
I've owned and used the same Craftsman 3/8" drive torque wrench for about 20 years. Never a problem.
Last year I bought a Home Depot Husky 1/2" drive torque wrench. Seems to be a quality tool as well.
I'm not sure what causes reasonably well made torque wrenches to fail after a short period of time, but I suspect some owners confuse them with breaker bars.
Old Nov 6, 2007 | 09:06 AM
bosco 08's Avatar
bosco 08
do you really trust a torque wrench you have owned for 20-35 years and have never re-calibrated it. bosco
Old Nov 6, 2007 | 09:31 AM
ProfMoriarty
I re-read all the posts and none of the writers stated that they had never tested the accuracy of their wrenches or never had them re-calibrated.
Old Sep 12, 2008 | 08:37 PM
SweetBlueZ51's Avatar
SweetBlueZ51
Originally Posted by ProfMoriarty
…bought a Home Depot Husky 1/2" drive torque wrench. Seems to be a quality tool…
Just picked up a 1/2" Husky torque wrench myself at Hope Depot for $69.96 which I thought was a decent enough price.
Seems like a quality product to me and it performed nicely torquing my lug nuts. I loosened one lug nut at a time and then tightened them using the torque wrench set to 100 lbs for my C6... it clicked letting me know when to stop which seemed straightforward enough. Don't know how perfectly accurate it is (+-/4% ?), but it seems to have performed as advertised and I'm happy.
To Torque Wrench Recommendations
Old Sep 12, 2008 | 09:19 PM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
http://buy1.snapon.com/catalog/item....re&dir=catalog
Buy that one.
Old Sep 12, 2008 | 09:31 PM
patton's Avatar
patton
St. Jude Donor '09
Originally Posted by Frans96ss
when you want the very best snap along
Old Sep 12, 2008 | 09:41 PM
runutzzzzz's Avatar
runutzzzzz
Snap On for me
