I've had a 1/2 drive Sears Craftsman for 28 years and yes I check its calibration every couple years. Click type torque wrenchs are 4% C.W./ 6% C.C.W. accuracy and if you don't abuse it most will stay in tolerance. Don't throw it, drop it, or let it roll around in the bed of your pick up and you're pretty good...
There are other good wrenches but for the money and home use Sears puts out a good wrench.
If you are planning on ocassional use.... mods and repairs then you can't beat Harbor Freight.
NO CORVETTE TAX ! and a Lifetime Warranty...
I have had mine for 4 years now and they still work perfectly and remain accurately calibrated.
Click-stop type accurate within +/- 4%. Heavy duty cam & pawl mechanism. Reversible. Includes carrying case.
Manufacturer:Pittsburgh
Drive: 1/4''
Torque range: 20 to 200 in. lbs.
Length: 10''
Weight: 1 lb.
ITEM 2696-3VGA
$28.99
3/8'' DRIVE CLICKER TORQUE WRENCH
Click-stop type, accurate within +/- 4%. Heavy duty cam & pawl mechanism.
Drive: 3/8''
Torque range: 0 to 80 ft. lbs.
Length: 14-3/4''
Weight: 2 lbs.
ITEM 807-6VGA
$19.99
1/2" CLICKER TORQUE WRENCH
Click-stop type accurate within +/- 4%. Heavy duty cam & pawl mechanism.Reversible.
Carrying case. Lifetime Warranty.
Drive: 1/2''
Torque range: 10 to 150 ft. lbs
Length: 18"
Shipping weight: 4 lbs.
i have the snapon tech angle 3/8 toque wrench its about 500 bucks but then again im a tech by trade. the crafts man are decent so i would go with that as a weekend warrior
I had a Craftsman torque wrench di on me 2x. The first time they replaced it, no problem, next time I was told torque wrenches are not lifetime warranty. I ordered a 1/4 and 3/8 SK wrenches from Tooltopia.com. Not too pricy, and seem well made. They have fast service and shipping.
Not true, I have seen many out of tolerance. Again if you do not abuse it it does last longer.
was the pointer off center or did you put them on a torque tester? the pointer beam can be recentered, just bend it, without detriment to the lever beam. keep in mind, the handle has to float on the pivot pin for accuracy.
To me, the most important feature of a tool like this is to make sure it is made in the USA. Most of the remaining manufacturers here are great...the cheap stuff comes from overseas...
A craftsman 3/8 drive torque wrench is an excellent choice. I have repaired and tested older Craftsman torque wrenches and they maintain their calibration within a few percent but....
When your done using your torque wrench you must unload the internal spring and set the torque reading back to "0". If you don't do this the spring remains loaded and your calibration will become less accurate over time.
True... but I've seen cheap beam wrenchs OOT out of the blister wrap.
Yes, we test them on torque testers.
PMEL trained, 30+ years in calibration.
For our use a clicker is much easier to use so you don't have to look at what it's reading while you use it.
definitely a clicker is easier to use, no need to look after setting. there are beam types with audible signals out of austria but, $200 is steep...
i have a mac(?-75#) clicker and will shortly buy a snap-on 50-250# clicker for $270+/-...some of my stuff needs torqueing to 150+#.
as to storing, yes, use the box, treat it like gold AND, you should store it with a load on the spring...about 20%. setting it to zero takes the pressure off the mechanism and this may cause internal parts to move out of place if jarred. it also keeps the spring from relaxing, losing your calibration.
I've had my Craftsman from Sears for more years than I can remember. If it's still made decently, then it's a good choice for an occassional user. If you are going to be using it professinally, then you can't beat Snap-On products.
hmmmm the majority go for the 'chevette' of torque wrenches (crapsman,harbor freight,husky-WTF? ) to work on a Corvette....or i like this one "Snap-ON" is to pricey but i have a 50k car. How GHETTO can you go? This one is my favorite..."I've had this torque wrench for 28yrs", please dont touch anything of mine.
I've used these Precision Instruments torque wrenches for years now, and they are a good compromise between imported crap and Snap-On or MAC. US made, they don't need to be reset to zero torque for storage, reasonably priced, and each wrench comes with a calibration sheet.
I have two Precision Instruments split beam torque wrenches and would never use anything else.
After I got mine, I did a side-by side comparison with my buddies Snap-On versions and they were identical except info plates. The info plates were different: company names and color (Snap-On is red, Precision Instruments blue).
I don't know if this is still true but as far as I know, Precision Instruments makes Snap-On's torque wrenches.
Bought an S&K model several years ago. It's the 1/2 drive model and you twist the handle to dial in the torque setting you need. Just remember to return the setting to zero when you're done using it. It will stay accurate longer that way.
Precision Instruments certainly manufactured Snap-On's dial-type wrenches. I ordered a 1% Torquemeter from Snap-On once (2% is standard) and was told it would take two weeks because they had to special-order them from Precision.
And, of course, when you inspect them side-by-side it's clear they are identical, except for the printing on the dial. It's a pity the Precision Instruments-branded dials don't have prettier graphic design, but they are a good deal cheaper than Snap-On.
I've heard that Snap-On has a new OEM for their new-look torque wrenches.
