Regular gas?
Old Nov 30, 2007 | 11:09 AM
  #41
crabman's Avatar
crabman
We need that oil engineer to check in here again. Since he has yet to do so I'll try recap as much as I remember.
Gas is a commodity and sold in bulk. Everybody gets and uses the same stuff. It is possible to go to a refinery owned by any brand and see trucks from all the others filling up. They then add the brand appropriate package which was reported as being an incredibly small amount of whatever the hell it is.
Doesnt matter what octane you use, economy remains the same. Higher octanes do not add power and have no more energy in them per gallon than lower octane fuels.
Higher octane fuels are more resistant to detonation. This allows for adding compression and or timing before getting into detonation increasing power output of any engines that do take advantage of it.
A summation is that unless your car has the compression and or timing that makes higher octane fuels necessary then you gain nothing by running a higher octane fuel in it.
Our cars do require high test to run at maximum performance. If knock is detected (and it will be if you go WOT on low octane gas) the car is put on the low octane tables and a great deal of power is lost at WOT.
Any mistakes in this post were mine, the oil field chemist was the legitimate article and knew his stuff. I believe however I have the basics right.
Old Nov 30, 2007 | 11:31 AM
  #42
quickride's Avatar
quickride
I've experimented with both regular and premium to see if there is any difference in gas mileage and performance. I get the same MPG with both octane levels, no difference at all.
My general rule of thumb is that since I can drive my car year round, I will run regular during the winter and cold months. Cold months for me might get down to 40 degrees and I have no snow to deal with. When summertime rolls arounds I start using premium because the possibility of pinging is greater when the temperatures go up. Also during the summer with nice whether, I'm more likely to drive the car more aggressively than on a cold winter day when the streets are cold and damp. Why do I need premium (top performance) on days like this? That's just asking for trouble.
I say if you can save a few bucks on gas, why not do it. It leaves more for other mods you might want to do.
Finally I'll tell you that the highest octane I can get in my area is 91 so there's not a big jump from the 87 octane of regular. Perhaps if I could actually get 93 octane, I would see some differences.
Old Nov 30, 2007 | 12:13 PM
  #43
mwct's Avatar
mwct
Originally Posted by 08 Red Vette
I saw in Motor Trend that the new 08 Vette runs on regular unleaded. I have been putting premium unleaded in. Does it run on regular and if so does premium run any better?
It will get better performance and mpg with premium, and you are better off just using that imo.
Old Nov 30, 2007 | 04:16 PM
  #44
JmpnJckFlsh's Avatar
JmpnJckFlsh
Originally Posted by lvjetboy
...So for me, this is not wondering if I should use mid (89) or low (87) grade gas. Never used either. This is about I'm using top grade 91 and I still get detonation...on a 07 vette with no carbon instead pinging under certain conditions since it had 3 miles on it...
If you're concerned, and you have good dealer technicians, you might have your dealer look at it. Like you, our premium octane is 91 octane, and I have noticed no pinging at all on my 2006. You might also try another brand of gasoline, preferably a Top Tier brand...I have good luck with Chevron (hate the company; love the gasoline).
Your PCM should be adjusting timing to minimize pinging if the sensors are operating properly. A very light ping (much like injector noise) only means the PCM is keeping the timing on the razor's edge to maximize power. Actually, the usual pinging heard is pre-ignition and not detonation...Detonation is a much louder, heavier, and more destructive process than pre-ignition.
Old Nov 30, 2007 | 07:37 PM
  #45
drummingman's Avatar
drummingman
25,000 Miles @ 18MPG == 1389 Gallons @ .20 difference for premium = $277.00. For that small a differential over that number of miles, why worry about it? Stick with premium and enjoy the ride!
Old Nov 30, 2007 | 11:37 PM
  #46
goatts's Avatar
goatts
The engine was designed to run on high test. In the rare instance where only regular is available you can get by. If you run regular all the time then you risk engine damage on a $50k car. When running regular you rely on the computer to retard the timing properly and the knock sensor to function flawlessly.
Old Dec 1, 2007 | 12:03 AM
  #47
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Originally Posted by DitchTehFish
I agree 100%! It's kind of like those people who buy oil filters from walmart! Come on!
Bull S*it ! What's next ? I shouldn't buy my oil at Wal Mart because it'll be in a Wal Mart bag ?
Old Dec 1, 2007 | 12:04 AM
  #48
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Originally Posted by CHASLS2
Why spend big money on a 400hp+ car, then try to save on gas cost?
So he will have the down stroke saved for his next Vette.
Old Dec 1, 2007 | 12:06 AM
  #49
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Supreme, Premium, Ethel, Super, Top Dog, Who's your Daddy, this or that brand name for the latest alledged "high octane" pump gas, market BS aside...91 Octane rating is "recommended" for the 07.
Yet even with 91 octane I still get pinging = detonation. Not sure how that could be since 91's recommended and I use it exclusively, but I guess from my experience, crap gas regular's out of the question since my knock retarded computer can't even handle 91...or whatever BS name gas stations call it these days.
jer
Are you sure it's not your teeth chattering ?
Old Dec 1, 2007 | 12:07 AM
  #50
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Originally Posted by z51vett
On reg gas mileage suffers I know from exp.
z51vett
Old Dec 1, 2007 | 12:12 AM
  #51
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Originally Posted by Leprkon
this one is pretty simple math. If regular costs $3 a gallon and premium $3.20, and you assume 30 mpg, then losing two mpg with cheaper fuel costs basically the same. If you get less than 30 mpg, it actually costs more. So why mistreat the engine ?
With winter coming on, I think you'd want the best gas you could put in the car, just to make sure it doesn't freeze up or vapor lock.
Freeze up ? Vapor lock ? You've met my former g f I gather.
Old Dec 1, 2007 | 12:15 AM
  #52
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Wonder if I'd ping with 93.
jer
Depends, Jack Daniels or Jim Beam ?
Old Dec 1, 2007 | 07:04 AM
  #53
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Originally Posted by Blue Stream
Don't listen to them. It can be done in an emergency but NEVER use it on a "regular" basis.
And you have an engineering degree to back up that statement ?
