Regular gas?
Old Nov 17, 2007 | 06:31 PM
14 Red Z51 Vette's Avatar
14 Red Z51 Vette
Default Regular gas?
I saw in Motor Trend that the new 08 Vette runs on regular unleaded. I have been putting premium unleaded in. Does it run on regular and if so does premium run any better?
Old Nov 17, 2007 | 06:39 PM
rdm1465's Avatar
rdm1465
I don't know if it's true or not. Check your manual. With Technology today it is possible. If it is true, then the premium fuel does not effect the performance (ok maybe a little), nor will it hurt it.
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
All C6 Corvettes will run on regular gasoline. The computer will retard performance to accomodate. You should find a similar note in your owners manual:
Fuel
Use of the recommended fuel is an important part of the
proper maintenance of your vehicle.
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If this occurs,
use a gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you might damage your engine.
Old Nov 17, 2007 | 06:56 PM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Why spend big money on a 400hp+ car, then try to save on gas cost?
Old Nov 17, 2007 | 07:30 PM
14 Red Z51 Vette
I don't mind spending money on gas, heck, even my motorcycle requires premium. I was just surprised that MT said it ran on regular. I just filled up with premium and plan on continuing to do that.
Old Nov 17, 2007 | 07:34 PM
johnodrake's Avatar
johnodrake
Moderator
MT often will make inaccurate statements....
Sativa's Avatar
Sativa
Old Nov 17, 2007 | 07:47 PM
Vettin08's Avatar
Vettin08
It will run fine on Regular. It will run GREAT w/ premium.
Old Nov 17, 2007 | 07:56 PM
LB001's Avatar
LB001
MT also has a reputation of giving the best automobile awards money can buy.
Old Nov 17, 2007 | 07:59 PM
Sven's Avatar
Sven
St. Jude Donor '08-'09
I think I'd rely on the owner's manual ...
Old Nov 17, 2007 | 08:07 PM
chet b's Avatar
chet b
Motor Trend is full of it.
Old Nov 17, 2007 | 08:25 PM
Jason.ServiceSpecialist's Avatar
0Jason.ServiceSpecialist
Former Vendor
Supreme is reccomended, but you can use regular. If you do use regular, make sure you listen for any pinging noises from the motor. I wouldn't reccomend regular in a Corvettes though. We actually keep a gas can here with supreme in it for our Corvettes just in case we run out of gas.
Old Nov 17, 2007 | 09:16 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I agree 100%! It's kind of like those people who buy oil filters from walmart! Come on!
Old Nov 17, 2007 | 10:11 PM
GaussianMist's Avatar
GaussianMist
I'm too lazy to go down and get my 2008 manual but the 2007 manual pdf on the forum if I remember correctly states that 93 octane is recommended for the coupe and vert and a must for the Z06.
Old Nov 17, 2007 | 10:25 PM
03 Z-oh-6's Avatar
03 Z-oh-6
No, not all of us have 93 octane. 91 is recommended.
Old Nov 17, 2007 | 10:51 PM
rws.1's Avatar
rws.1
My manual says I need 93 Octane....
'08 Z
Old Nov 17, 2007 | 11:06 PM
WMark's Avatar
WMark
St. Jude Donor '11
Stopped subscribing years ago.
My C6 gets such great mileage (considering it's performance), I'm better off driving it than my Jeep Grand Cherokee hemi. Even pumping premium into the Corvette.
Any new car will run on regular, but you will not realize the performance if a higher grade is recommended. And if it starts to ping, then get back up there.
As many other posts have indicated, I have a $50k+ car. Twenty to forty cents per gallon more for premium is not an issue.
To Regular gas?
Old Nov 18, 2007 | 05:57 AM
lvjetboy's Avatar
lvjetboy
Supreme, Premium, Ethel, Super, Top Dog, Who's your Daddy, this or that brand name for the latest alledged "high octane" pump gas, market BS aside...91 Octane rating is "recommended" for the 07.
Yet even with 91 octane I still get pinging = detonation. Not sure how that could be since 91's recommended and I use it exclusively, but I guess from my experience, crap gas regular's out of the question since my knock retarded computer can't even handle 91...or whatever BS name gas stations call it these days.
jer
Old Nov 18, 2007 | 07:05 AM
talon90's Avatar
talon90
NCM Ambassador
Here is the section from the '07 manual on octane:
Gasoline Octane
If your vehicle has the 6.0L V8 engine (VIN
Code U), use premium unleaded gasoline with a
posted octane rating of 91 or higher. You may also
use regular unleaded gasoline rated at 87 octane
be slightly reduced, and you may notice a slight
audible knocking noise, commonly referred to
as spark knock. If the octane is less than 87, you
may notice a heavy knocking noise when you
drive. If this occurs, use a gasoline rated at
87 octane or higher as soon as possible.
Otherwise, you might damage your engine. If you
are using gasoline rated at 87 octane or higher
and you hear heavy knocking, your engine needs
service.
If your vehicle has the 7.0L V8 engine (VIN
Code E), use premium unleaded gasoline with a
posted octane rating of 91 or higher. For best
performance, use premium unleaded gasoline with
a posted octane rating of 93.
320
Old Nov 18, 2007 | 07:09 AM
VettinFan's Avatar
VettinFan
Unless your shooting for better ET times at the strip, you really won't notice a performance difference driving around the city. The car will adjust for the fuel. However, you need to listen for pinging.
I always run premium in the Vette, but on one occasion, due to habit, I pressed the 87 octane button and filled the Vette with regular. Didn't notice any thing different.
~AL~
