problem
Old Jan 13, 2008 | 04:53 PM
photoguy's Avatar
photoguy
Default problem
What does it mean when my check gas cap light comes on? I checked it and it is tight. I restarted the car and it still comes on. Any ideas?
Old Jan 13, 2008 | 04:58 PM
BigJoe's Avatar
BigJoe
Could actually be a bad cap, or a bad sensor. If it doesn't go away after a few cycles it should be an easy fix for the dealer.
Old Jan 13, 2008 | 05:01 PM
photoguy's Avatar
photoguy
This is the very first thing that has ever gone wrong with my 05. Good thing the warranty doesn't expire till June.
Old Jan 13, 2008 | 05:12 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
normally its just because is wasn't seated properly. Before you buy a new cap, remove/replace and turn it until it "clicks" a few times. Then its probably going to take about 10-cranks of the motor (maybe a couple more) before it typically clears the code. You should be able to drive it and just about the time you've got yourself trained to ignore the dic code...the problem has gone away. If this fails, you may have to replace your cap.
Old Jan 13, 2008 | 05:21 PM
Wayne O's Avatar
Wayne O
CF Senior Member
This may sound strange but it worked for me....try screwing your gas cap on 'loosely.' I mean the gas cap is on but just don't try to screw it down tight as you might do normally. Someone suggested this when I had a check gas cap warning and I've never had another problem.
Prior to trying this 'fix' I talked to my service advisor about the check gas cap warning. They would not just give me or install another gas cap without performing a complete check of the fuel system...looking specifically for some sort of venting problem.
FWIW it worked for me.
To problem
