Wrong gas
Old Feb 18, 2008 | 08:02 PM
ROD BROWN's Avatar
ROD BROWN
Default Wrong gas
Last week I accidently put regular gas in my car.I had about 3 gals. in the tank when I filled up.Well,much to my surprise my car ran just as good on the regular as it does on Ethyl.I thought the power would suffer,but it didn't.It didn't ping either.Has anyone else put regular in their car and had similar results?Oh,I filled my car up this week with Ethyl and it runs trhe same.
Old Feb 18, 2008 | 08:09 PM
BigJoe's Avatar
BigJoe
No problem. I've run a few tanks of regular as a test and didn't notice any difference in normal road driving. If you are racing it could be a problem under hard acceleration. Just take it easy for a while to avoid any pinging. GM says it is OK to run 87 all the time, it just runs at a lower power.
Old Feb 18, 2008 | 08:10 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
The computer is suppose to adjust for this. You loose some horse power. I accidently put regular in the C5 I use to own and every light on the dash came on until 3 tanks full later
I also put regular in my "66" 427, 515 hp L-88 Vette and it sounded like a diesel. Had to drain the tank
Old Feb 18, 2008 | 08:13 PM
vettesmith02's Avatar
vettesmith02
Old Feb 18, 2008 | 08:52 PM
Range_Rat's Avatar
Range_Rat
No problem --- your ECM will derate engine control performance parameters to account for lower octane level. That is unless you have a C6 Z06 --- then it's bad news and you need to get the lower octane gas out of the system before driving.
Old Feb 18, 2008 | 08:54 PM
Vettin08's Avatar
Vettin08
If you're just putting around town, you wont notice any difference.
Old Feb 18, 2008 | 08:56 PM
dvilin's Avatar
dvilin
Old Feb 18, 2008 | 09:06 PM
miami08VETTE's Avatar
miami08VETTE
Ethyl! Wow you must be ancient.........
Oh wait, how do I know what you mean.......... nevermind
Old Feb 18, 2008 | 09:17 PM
ROD BROWN's Avatar
ROD BROWN
Default Ancient
Yep,you are right.I passed elderly and now I am ancient. i guess the next level is dead
Old Feb 18, 2008 | 09:19 PM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
10,000 miles using reg grade no probs,
Old Feb 18, 2008 | 09:21 PM
CaBhaal's Avatar
CaBhaal
I filled up at a station last week and the pump selected regular gas even though I hit the supreme button. I did not realize it until I had put 10 gallons in. I stopped and tried it again, making sure I hit the correct button and it still gave me regular.
I ran it through and the car did not seem to mind.
Old Feb 18, 2008 | 09:26 PM
Irv's Avatar
Irv
Hertz filled our '08 rental vette with 87, and it pinged until I put 3/4 tank of 91 in it. You guys filling with regular must be deaf. The car was brand new (2 miles on the clock, so no carbon in the combustion chambers) and we were pretty gentle with it for the first 500 miles. Temps were about 55F.
I can't imagine how one car pings on 87 and the others don't. I also can't imagine how folks can spend so much money on a car and then skimp by $5 on a fill-up. Y'all must be leasing.
Old Feb 18, 2008 | 09:36 PM
slacker1201's Avatar
slacker1201
Lifetime NCM Member #2497
Cruise-In 9-10-11-12 Veteran
Only the best for my baby.
Old Feb 18, 2008 | 09:43 PM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
From the 2006 Owner's Manual:
Old Feb 18, 2008 | 10:32 PM
Purdue's Avatar
Purdue
Originally Posted by Irv
I can't imagine how one car pings on 87 and the others don't. I also can't imagine how folks can spend so much money on a car and then skimp by $5 on fill-up. Y'all must be leasing.
Hey I lease and only use premium (91 octane in AZ).
Old Feb 18, 2008 | 10:48 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Feb 18, 2008 | 10:54 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
I use 91 in CA.
Chervon most of the time.
Putting in 87 may not be the best but will work and harm.
Go with Factory Recom>
Made in USA the C-6
To Wrong gas
Old Feb 19, 2008 | 08:59 AM
nmerhaut's Avatar
nmerhaut
Dealer filled mine with 87 or 89 in KC and I averaged 27mpg back home to Cleveland--no pinging. I use 89-93 usually.
Old Feb 19, 2008 | 09:05 AM
lault's Avatar
lault
Old Ethyl has always been good.
Old Feb 19, 2008 | 09:31 AM
tls630's Avatar
tls630
My wife filled ours with 87 octane with 10% ETHANOL.I thought it would be a nightmare, but I can't see a bit of differance. Am I going to trust her to fuel up again? NO!
