For a small nominal fee. 1 Hundred Million Dollars!!!!!!!!1 BWAHHAHAHAHA I can stand there and go Beep, Beep Beep, Beep Beep Beep!!!!!!!! Although accuracy is not guarantted.
AVM- Around View Monitor uses cameras on every side to “see” objects or vehicles around you. Then it presents your surrounding environment in a composite bird’s-eye perspective on the central screen.
Gotta buy an import for this....see ya.... pun intended
I use my mirror. Just tilt it down and you'll see your rear tire area and how close it is to the curb. Been doing this for years on all vehicles with adjustable mirrors. Works great.
just program the settings into your #2 memory button on the door!
just need to figure a way to light the curb area at night!
I found a method that works every time. It is a little hard to explain and may work differently for others depending on their height, seat position, and line of sight. When parking I look a the V that is made where the driver side mirror base and door meet. When the bottom of the curb, or concrete tire stop reaches the bottom of the V I know the tip of the nose is about 6 inches away from the curb.
Crazy I know but it works 100% of the time for me. So my advice would be to park the car with someone guiding you until you are at the spot you want. Notice where the curb is in relation to the V that was mentioned above. Practice a few times with your helper to confirm that you are doing it right.
This method is very hard to explain. Basically, find a landmark on the car that you can use in relation to the curb, or concrete tire stop.
The Vette is the easiest car I've driven to tell where the wheels are. I'm not really sure why, but I scratched the rims of my old Lexus GS on a regular basis but I haven't even had one brush with a curb in the year I've owned my Vette
Trying to figure out where the back end of this car is is a whole other issue though, I often back into a parking space, get out of the car and realize the back end is about 3 feet forward of where I thought it was
Big problem parking between cars when I have to for the front and rear
Also the curb how do you keep from getting curb rash on your wheels
I set the driver#2 button to set my passenger mirror to see the curb.Works like a charm.
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
