regular gas
Old Apr 23, 2008 | 01:45 AM
humvet's Avatar
humvet
I drove a 30 mile each way hilly commute in my C5 racking up 40K miles in a short period of time. I used 87 about 2/3's of the time. Never had a ping or a knock, never had clogged injectors, never, ever could tell the difference in performance. Got 24MPG. Thus far I have used 91 in my C6 mainly because it is a low mileage driver. I would not hesitate to go back to 87 if I picked up the mileage. The way I see it - no ping or no knock, no reason not to go with 87.
Old Apr 23, 2008 | 02:49 AM
supervette26's Avatar
supervette26
this is how i look at it.... difference in 93 and 87 generally about 20 cents... 15 gallons = $3
If Im spending all this money on this car I can afford another $12 a month to make sure I have no problems and it performs like it should....
Old Apr 23, 2008 | 03:11 AM
shopdog's Avatar
shopdog
Originally Posted by PAmotorman
you will also loose MPG as i have seen this on a road trip with a fellow corvette owner who used regular and i used hi test. he alway took more gallons than i did at a fillup and he had a 6 speed manual and i had a 4 speed auto with a 3.15 rear gear
Not a fair comparison, the 4 speed auto is much more efficient than a 6 spd manual.
Old Apr 23, 2008 | 06:11 AM
eurostyle's Avatar
eurostyle
Originally Posted by photoguy
OK Guys. You beat me up enough!!! I'll go back to the 93!
Try 10 gallons of gas and one ounce of pure acetone.
Old Apr 23, 2008 | 06:44 AM
photoguy's Avatar
photoguy
Originally Posted by RogerC6
You had to get technical, (he doesn't know that)you just lost me a bottle of wine.
Actually you're absolutly right, you just lose a little performance.
I'll still send you the wine!!
Old Apr 23, 2008 | 10:51 AM
Dale_K's Avatar
Dale_K
I tried a tank of 87 the last time too. Didn't seem to have any problems. I don't buy the injectors clogging up theory. The manual says you can use it - good enough for me.
Old Apr 23, 2008 | 11:24 AM
PAmotorman's Avatar
PAmotorman
the "additive package" in the fuel is put in at the local distributor so as long as he does not "cheat" on the additive package to increase his profits you should be OK on keeping your injectors clean.
just to be safe i would add GM injector cleaner to the fuel at every oil change as it is cheap insurance
Old Apr 23, 2008 | 11:25 AM
wormie's Avatar
wormie
Originally Posted by bestvette
It is a stupid idea, you shouldn't be buying a high performance,$60,000 car if you can't afford to pay for 93 octane. You will get ping eventually, which is when your engine will actually create a ping sound, you will hear, this is because your engine needs better gas. Just put 93 in!
i agree
Old Apr 23, 2008 | 11:46 AM
humvet's Avatar
humvet
You can get the margarita with the house brand tequila or the top shelf - they both get you where you want go.
Old Apr 23, 2008 | 12:28 PM
05C6400's Avatar
05C6400
I am looking forward to when gas prices hit about $10.00 per gallon... will have fewer people on the road and, yes I agree with
"Originally Posted by bestvette
It is a stupid idea, you shouldn't be buying a high performance,$60,000 car if you can't afford to pay for 93 octane. You will get ping eventually, which is when your engine will actually create a ping sound, you will hear, this is because your engine needs better gas. Just put 93 in!"
Old Apr 23, 2008 | 01:15 PM
cclive's Avatar
cclive
I like to make sure the injectors are clean no matter what gas I use, and Chevron's Techron is condidered to be the best additive for this. Its available even at WalMart, but the best deal is at Costco (where else!) where you can get a six bottle case for less than half the price. I put one in the tank after winter and then maybe once or twice more every year.
The problem with depending on the gas for this is that now you really don't know what brand of gas is being sold at a particular station anymore.
Old Apr 23, 2008 | 01:18 PM
cclive's Avatar
cclive
Old Apr 23, 2008 | 01:58 PM
  #33
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
You will loose at least one MPG by droping down one grade.
Let's do the math:
EPA estimate MPG City is 18 MPG.
18 MPG * 18 gallon tank = 324 mile range.
17 MPG * 18 gallon tank = 306 mile range.
18 miles difference.
Gas today in Jacksonville, Fl--- 93 oct. $3.51, 89 oct. $3.41
Cost to fill with 93 oct = $63.18
Cost to fill with 89 oct = $61.38
It costs $1.80 less to fill with 89 than it does with 93 octane.
However you can only go 306 miles. To go the same distance, you have to buy 19 gallons.
19 gallons of 89 oct. @ $3.41 = $64.79 or $1.61 more.
It costs $3.41 more to go 324 miles on 89 oct. than it does with 91.
Where's the savings in that.
Old Apr 23, 2008 | 02:08 PM
  #34
goatts's Avatar
goatts
Knocking can damage your engine if the computer doesn't properly adjust timing using 87 octane. It's not the recommended fuel but it will work temporarily if you can't get anything else. Hey, you guys using regular gas in your $60k sports car can save even MORE money buy using recycled oil from the dollar store in your engine! Why bother with synthetic!
Old Apr 23, 2008 | 04:25 PM
  #35
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
You omitted re-treads...tires.
Then we don't need all those "Kumho, Michelin, KDWs, Wide Oval, Badyear" threads...just Bandag!!!!
Old Apr 23, 2008 | 04:39 PM
  #36
headhunter1975's Avatar
headhunter1975
I'm in the Pacific NW also, I always run regular Monday through Thursday for my commute, then on Friday I fill up with super for the weekend. I'm pumping over $150 a week in gas since I commute from Everett to Whidbey Island. I really don't notice a difference in mileage or perfomance. Although I haven't really done a from empty mpg verification. But since I drive the I-5 regularly, i'm sure I could do a 60mph run on both tanks just for kicks to see if it makes a difference.
Old Apr 23, 2008 | 05:57 PM
  #37
humvet's Avatar
humvet
Using this logic, it is best not to do the following with our $60K sports car:
1) Never track it or do a burn out - bad for the drive train
2) Never drive it on the freeway - might get a chipped windshield or a paint chip.
3) Never park near a curb - might get curb rash
4) Never sit on the seats and fart - it might scorch the leather.
5) Etc. Etc.
To regular gas
Old Apr 23, 2008 | 06:03 PM
  #38
djfullshred's Avatar
djfullshred
Every knowledgable bit of info I have read about my LS2 is that it is a pretty hardy engine, and regular 87 will not harm it at all.
However, I did buy this car for fun & not a commute vehicle, so I always put in premium unless faced with no other alternative. I do notice the performance & fuel mileage drop off with 87 the few times I had to run it, so for me it isn't worth saving a few bucks on a tank of gas to run regular.
Old Apr 23, 2008 | 09:17 PM
  #39
moolys's Avatar
moolys
St. Jude Donor '09
Originally Posted by maxp
why cheap out on a performance car?
Old Apr 23, 2008 | 10:24 PM
  #40
NappysVette's Avatar
NappysVette
I have been running 87 octane in my vette for the last 3 tank fulls and have not noticed a difference in performance. Do you think this is a bad idea?? The manual says 92+ is recommended but not necessary.
Mmmmm... I feel badly for the guy who buys your used Vette... R U planning to try regular Motor Oil next ?
