regular gas
Old Apr 22, 2008 | 07:57 PM
photoguy's Avatar
photoguy
Default regular gas
I have been running 87 octane in my vette for the last 3 tank fulls and have not noticed a difference in performance. Do you think this is a bad idea?? The manual says 92+ is recommended but not necessary.
Old Apr 22, 2008 | 07:59 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Your car. Your money. Only you can decide if it feels right to you. The car will retard the performance to match the reduced octane until it can't reduce it anymore. Once that happens you will get knocking and pinging. That can damage your engine. Pay attention to what the car is telling you.
I can't imagine that they put that in the manual just for kicks.
The manual states the following:
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If this occurs,
use a gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you might damage your engine.
Old Apr 22, 2008 | 08:00 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Yes, I think that is a bad idea.
Old Apr 22, 2008 | 08:07 PM
maxp's Avatar
maxp
Gasoline Octane
why cheap out on a performance car?
Old Apr 22, 2008 | 08:08 PM
bestvette's Avatar
bestvette
It is a stupid idea, you shouldn't be buying a high performance,$60,000 car if you can't afford to pay for 93 octane. You will get ping eventually, which is when your engine will actually create a ping sound, you will hear, this is because your engine needs better gas. Just put 93 in!
BigButtLover's Avatar
BigButtLover
St. Jude Donor '08
Old Apr 22, 2008 | 08:12 PM
photoguy's Avatar
photoguy
OK Guys. You beat me up enough!!! I'll go back to the 93!
Die2Win's Avatar
Die2Win
I dunno, I've used 87 in my C6 for most of the winter, can't use the power anyway in stop and go so it isn't a problem. If Washington's Pacific NW ever gets a summer I'll fill her up with the "good stuff" so I can play lead foot with the estimated $5.00 + a gallon juice.
Old Apr 22, 2008 | 08:13 PM
PAmotorman's Avatar
PAmotorman
you will also loose MPG as i have seen this on a road trip with a fellow corvette owner who used regular and i used hi test. he alway took more gallons than i did at a fillup and he had a 6 speed manual and i had a 4 speed auto with a 3.15 rear gear
Old Apr 22, 2008 | 08:16 PM
photoguy's Avatar
photoguy
So really not saving if MPG is less. I guess no real reason to use it!
Old Apr 22, 2008 | 08:23 PM
Die2Win's Avatar
Die2Win
Less MPG might balance out with the difference in cost, in town I never have seen much difference in any of the grades or brands that I've tried. On the highway, I agree, Premium gas rules for MPG and power.
Old Apr 22, 2008 | 08:49 PM
RogerC6's Avatar
RogerC6
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
We may have save your butt from an expensive repair, please send us all a nice bottle of wine.....is the least you can do
Old Apr 22, 2008 | 09:36 PM
Modshack's Avatar
Modshack
Originally Posted by RogerC6
We may have save your butt from an expensive repair, :
errr...well, not really. The ECU has both a High octane, and Low octane timing map. When low octane fuel is detected (through the knock sensors) it will pull back to the low octane tables. These primarily involve reduced timing which is why mileage goes down a bit...
Old Apr 22, 2008 | 09:40 PM
RogerC6's Avatar
RogerC6
You had to get technical, (he doesn't know that)you just lost me a bottle of wine.
Actually you're absolutly right, you just lose a little performance.
Old Apr 22, 2008 | 09:45 PM
Braciole's Avatar
Braciole
St. Jude Donor '08
Plain stupid sorry Higher octane gas burns at a slower rate evening it out. Your injectors will get clogged and lead to other problems
Its your car if you dont like it sell it. dont treat it like crap
lol
Old Apr 22, 2008 | 09:59 PM
biggums's Avatar
biggums
My Vette gets better mileage than my 04 Ford Ranger V-6 by 5 to 8 mpg. I think I can run faster in the 1/4 mile than the Ranger. I'm more than happy to treat that special Vette to some good fuel any day for what rewards she gives me!
Old Apr 22, 2008 | 10:51 PM
BlueTx's Avatar
BlueTx
Its not worth the risk of gumming up the injectors to buy cheap gas. I was wondering which brand of gas was the best? I have been using Texaco, but am open to switching to something better.
To regular gas
Old Apr 22, 2008 | 11:10 PM
phileaglesfan's Avatar
phileaglesfan
Really there is no top gas out there as far as brand goes. Gas is gas, it is just some companies add more additives to their gas after it is shipped from the refinery.
However, since I'm most likely to put more strain on the Vette then other cars I would probably stick with Chevron/Exxon/Mobil 1/Shell/etc.
I was worried about breaking in my car right since the dealer probably put the cheapest 85 octane (lowest here in Utah) gas in the car when I picked it up. I put 91 Exxon in it after driving it all weekend. I'm almost up to 500 miles now and if I'm not I sure will be after my trip Saturday since we are cruising around some National Parks in Utah.
Old Apr 22, 2008 | 11:29 PM
TMyers's Avatar
TMyers
How much are you really saving by running regular? Say $.30 a gallon difference in price you save about $5 a tank. Not really worth it IMO unless you are running a few tanks a week.
Old Apr 23, 2008 | 12:48 AM
PAmotorman's Avatar
PAmotorman
google "top tier gasoline" to see if the stuff GM recommends to use to prevent injector problems is in your area.
