regular gas
Old May 22, 2008 | 03:28 PM
  #121
Racer86's Avatar
Racer86
[QUOTE=cclive;1565577090]If you can find 130 octane gas, your C6 will put out 100 more horsepower and you can fly! The higher the octane, the more power it puts out! Has nothing to do with resistance to detonation...more money and more octane means FASTER and BETTER...........
Not true at all, with 130 it might make less horsepower. All gas has the same energy in btu per gallon. higher octane fuel has a higher resistance to preignition or "ping" as some would say. You would have to remap the ECM and raise the compression ratio to gain hp.
Old May 22, 2008 | 05:57 PM
  #122
cclive's Avatar
cclive
There was a after my last post... which one is the sarcasm smilie?
Old May 22, 2008 | 06:08 PM
  #123
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Now does this sound silly to anyone?
If that was the case i would buy 500 octane and fly to the moon.
Old May 22, 2008 | 06:49 PM
  #124
azcanuk's Avatar
azcanuk
Originally Posted by photoguy
I have been running 87 octane in my vette for the last 3 tank fulls and have not noticed a difference in performance. Do you think this is a bad idea?? The manual says 92+ is recommended but not necessary.
For every day street use.. waste of $ to run 91+ or higher but wouln't go below 89 (is in LS2 right?)
Usually run 89 in my LS3 and no knock, have mostly used 87 grade in my LS1 and never knocked. Both have lots of get-up-go but do notice an improvement in LS1 when use 89 or 91.. and can put down a nice patch of rubber in LS3 with 89..
2 cents worth
Old May 22, 2008 | 07:05 PM
  #125
goatts's Avatar
goatts
Originally Posted by cinamin
New member, first post so be gentle when you beat me up! I spoke with the corvette mechanic at the dealership. He said let your car dictate. If it runs fine on the cheap gas...use it! Listen for pings and such though. And a couple of time per year put in a bottle of fuel injector cleaner. I ran my 99 for 2.5 years with no problem. Now have an 06, run cheap gas and so far no problems. My normal driving is 5 miles per day in the city going to and from work.
Problem is, with windows up, ac and radio on, it may have to get pretty bad before you notice it. GM says you can use regular but at the same time they tell you that you can damage your engine. Talking out of both sides of their mouth it seems.
Old May 22, 2008 | 07:09 PM
  #126
Walt White Coupe's Avatar
Walt White Coupe
Have you actually read the GM recommendation? What part of it that says that 87 octane, that is regular isn't it, is ok that you don't understand.
  #127
danl72's Avatar
danl72
Go for it.
Old May 17, 2010 | 11:52 AM
  #128
kfdeken's Avatar
kfdeken
Default Regular fuel for 66K miles in C5 . . .
2002 C5 Coupe now has 66K miles. I have used regular fuel almost since new except when I take my car on the track. The engine is so lightly loaded that 87 octane works fine under everyday conditions -- only using 15-20% of engine power! The track is a different story. High engine temps and repeated full-throttle operation make premium a must. My car gets 24 MPG in mixed freeway/city driving in 60-80F weather. Worse when the weather is colder. Oil changes once per year at about 8,000 miles with synthetic. I know some people will say this is not conservative enough, but I expect to drive my Corvette another ten years with no engine problems.
Old May 17, 2010 | 01:15 PM
  #129
SRQStingray's Avatar
SRQStingray
Originally Posted by Michrider
...engine needs a serious top engine cleaning to get the pistons to stop hitting the heads.
And, why, might I ask, would the pistons hit the heads if the injectors were dirty?
Old May 17, 2010 | 04:20 PM
  #130
bearman95's Avatar
bearman95
Originally Posted by djfullshred
Every knowledgable bit of info I have read about my LS2 is that it is a pretty hardy engine, and regular 87 will not harm it at all.
However, I did buy this car for fun & not a commute vehicle, so I always put in premium unless faced with no other alternative. I do notice the performance & fuel mileage drop off with 87 the few times I had to run it, so for me it isn't worth saving a few bucks on a tank of gas to run regular.
Old May 17, 2010 | 04:43 PM
  #131
C8-Vette's Avatar
C8-Vette
I drive my Vette about 6200 miles per year. (one of 3 cars). If I was to use 87 vs. 93 it would save me $.25 cents a gallon. Assuming 17MPH,that would be 365 gal per year times $.25 per or $91. It's not worth it!
Old May 17, 2010 | 05:14 PM
  #132
Vette Suspension's Avatar
Vette Suspension
Originally Posted by talon90
Your car. Your money. Only you can decide if it feels right to you. The car will retard the performance to match the reduced octane until it can't reduce it anymore. Once that happens you will get knocking and pinging. That can damage your engine. Pay attention to what the car is telling you.
I can't imagine that they put that in the manual just for kicks.The manual states the following:
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If this occurs,
use a gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you might damage your engine.
Well stated Paul.
Old May 17, 2010 | 06:07 PM
  #133
kfdeken's Avatar
kfdeken
Originally Posted by bearman95
Many may not agree, but I think one advantage of the Corvette is that it's not a "wimpy" BMW or Mercedes that must be coddled, serviced in a certain way. Corvettes are built to be driven and handle the situations we face in the USA without a lot of special handling -- and to me that means running on regular fuel or premium fuel without complaint! Thanks for your answer!
Old May 17, 2010 | 08:26 PM
  #134
phileaglesfan's Avatar
phileaglesfan
Dang, a two year old thread. It also started when gas prices seemed to be at it's highest before the market and gas prices dropped like crazy.
If you buy an expensive car that even recommends premium then maybe you shouldn't have bought it in the first place, especially a sports car which is usually bought for max performance. 20-30 cents difference per tank is about $5 a tank at the mostI really love it when people say they use regular and they have a $300-500 CAI installed.
Old May 17, 2010 | 08:32 PM
  #135
Vette Suspension
Back from the dead.
Old May 17, 2010 | 10:10 PM
  #136
JoesC5's Avatar
JoesC5
Filled up today with Phillips 66 Top Teir 94 octane without ethanol for $2.89/gal. My 505 horses says "thanks Joe".
Old May 17, 2010 | 10:13 PM
  #137
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
http://forums.corvetteforum.com/foru...s-or-more.html
