regular gas
Old May 20, 2008 | 05:58 PM
  #81
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Originally Posted by Walt White Coupe
Gasoline Octane
Use premium unleaded gasoline with a posted octane of
91 or higher for best performance. You may also use
middle grade or regular unleaded gasoline rated at 87
octane or higher, but your vehicle’s acceleration may be
slightly reduced. If the octane is less than 87, you may
get a heavy knocking noise when you drive. If this occurs,
use a gasoline rated at 87 octane or higher as soon as
possible. Otherwise, you might damage your engine.
Would somebody explain where this manufacturer's recommendation says that Regular 87 will harm your engine? IT DOES NOT! The only effect is that "acceleration may be slightly reduced." I think GM engineers know more about this engine and it's operational characteristics than this group of worry warts.
That said, I am looking for top-notched street cruising with no combustion chamber varnishing. So I only use high octane gas.
To the OP: No how, no way!
Old May 20, 2008 | 06:14 PM
  #82
phileaglesfan's Avatar
phileaglesfan
Originally Posted by freyke
I don't think I'd run the 87 octane... the 89, ok, that's what I'm running now.
From Click and Clack:
"Use the grade of gas you need and nothing higher.
Does your owner's manual say "Premium Unleaded Only"? No? Then don't ever use premium fuel. There. We just saved you 40 cents a gallon... or $8 on a 20-gallon fill up. If your engine is designed to run on regular gas, there's absolutely no benefit to putting in "high test." It pollutes more, it costs more, and doesn't give you any benefit in performance or fuel system cleanliness.
Now, what if your car DOES call for minimum 91 octane? Well, next time you buy a car, dumkoff, check what kind of fuel it requires first. We've always said that once you buy the car, you're stuck. You've got to use 91, because your high compression engine will ping if you don't. But now, most cars have "knock sensors," that retard the timing via the engine management computer (effectively lowering the compression) to protect the engine, in the event that you happen to get some bad gas, or have an emergency and can only get regular grade fuel. So we got to thinking, what would be wrong with using the knock sensor all the time? What if you put regular gas in the car all the time and let the knock sensor do its job and retard the timing? You'd have a little less power, but that extra 8 bucks a fill up might be more important to you than power right now. It would be to us.
It's a controversial theory, we admit it. But that's never bothered us before. And we can't think of any long-term effects of driving with the knock sensor retarding the timing. So our position (for the time being) is... use regular. Who cares? Now, if there are any actual automotive engineers in the audience who have worked on knock sensors, who want to tell us why we have our heads up our keisters, feel free to write to us. And if we're convinced that we're wrong, we'll happily change our recommendation."
First paragraph summary. We double the amount of the difference to look good. In reality for most places it costs 20 cents a gallon more for premium. That is about $3 a fill up for the Vette that can get around 500 miles on the highway. Even at city mileage you are looking at $10 per 1000 miles.
Second paragraph summary. Yes knock sensors will retard your timing which affects your gas mileage and performance negatively. You can be a cheapo if you want to but you shouldn't have bought a high performance car in the first place since you are willing to degrade its performance.
Third paragraph summary. They obviously never cruised up Parley's Summit which is a 4000 foot climb in about 10 miles. At 75mph the Vette is turning a relaxed 1700rpm. Just throw the crappy gas in there and let the knock sensors do their job. It'll still survive the warranty.
People need to consider the price of premium when they buy the car, especially a high performance car. The "savings" may buy you lunch every 3-4 weeks.
I wouldn't sweat it if the wife puts in 87 by mistake but I wouldn't do it on purpose unless it is the only gas around.
Old May 20, 2008 | 06:50 PM
  #83
RogerC6's Avatar
RogerC6
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
THis thread should be in the Toyota Camry Forum........
Old May 20, 2008 | 06:56 PM
  #84
phileaglesfan
Old May 20, 2008 | 07:10 PM
  #85
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
Like i said before, why buy a 40k + performance car, and try to save a a buck on gas?
Old May 20, 2008 | 07:14 PM
  #86
Modshack's Avatar
Modshack
Originally Posted by MikeyTX
How the h*ll are his injectors going to get clogged ?
I think the advice from these all knowing advisors is coming from guys who were around before they invented Fuel filters...
Old May 20, 2008 | 07:25 PM
  #87
ufso's Avatar
ufso
Let's see, what are some of the things people want to do without consulting the owners manual...
1) Can I do my oil change at 3K?
2) Can I use another oil?
3) Can I use a lesser octane fuel?
4) Can I inflate my tires to what I want?
And the list goes on and on and on and on...
Old May 20, 2008 | 09:33 PM
  #88
cclive's Avatar
cclive
Or.....because its a $50-$70K car, you must always choose the more expensive option when given a choice.....otherwise someone on the forum will tell you that you should have gone with the more expensive choice...
And yet people here always complain about the Corvette tax. The Corvette tax survives because many people here like to pay more for anything Corvette related. The tax helps them do that and feel good about whatever they bought...because it was more expensive...
Old May 20, 2008 | 09:40 PM
  #89
Vetteoholic's Avatar
Vetteoholic
$4.39 93 Octaine gas only for my Vettes I'm sure 87 won't kill the car but I won't take a chance. Especially in my Z06
Old May 21, 2008 | 12:14 AM
  #90
moolys's Avatar
moolys
St. Jude Donor '09
Originally Posted by maxp
why cheap out on a performance car?
Old May 21, 2008 | 02:32 AM
  #91
CHEVY 23's Avatar
CHEVY 23
you can put the cheap gas and then buy a octane booster and put it after you have pumped gas. Im just saying never tried it and wont
Old May 21, 2008 | 07:08 AM
  #92
PAmotorman's Avatar
PAmotorman
Originally Posted by shopdog
Not a fair comparison, the 4 speed auto is much more efficient than a 6 spd manual.
you have to be kidding as the GM mileage statements show the 6 speed manual with higher MPG than the auto even the 6 speed auto.
Old May 21, 2008 | 07:17 AM
  #93
PAmotorman's Avatar
PAmotorman
Originally Posted by cclive
The only time the timing is being retarded is when the knock sensors are hearing knock, which is usually at lower RPM and lots of throttle. When cruising on the highway at 5% throttle going 80MPH, the sensors will not cause spark retard, therefore no worse gas mileage.
that is not how it works because once the computer detect a spark knock the timing stays retarded till you refill the tank. the computer assumes you have a tank full of bad gas and will retard the ignition timing till you refill the tank.
Old May 21, 2008 | 07:19 AM
  #94
PAmotorman's Avatar
PAmotorman
the injectors plug up from varnish in the gasoline not DIRT
  #95
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Ahhhhhhhhhhh That explains everything. On the other hand, if the injectors get clogged up, wouldn't chunking some Sine-x in the tank solve the problem ? Uh-oh, that might cause excess post tail pipe drip.
Old May 21, 2008 | 07:21 AM
  #96
rws.1's Avatar
rws.1
If you drive like my grandmother did, there will be no issues.
It took here at least a minute to get up to 30 mph....
If you drive like my wife...who has 410's in the rear of her C5, then you will be getting engine knock because the computer can't retard the timing enough...
IT just depends on how you drive...
Old May 21, 2008 | 07:22 AM
  #97
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
And the test data is on line where ?
To regular gas
Old May 21, 2008 | 07:29 AM
  #98
TR Vert's Avatar
TR Vert
I resemble that remark !
Old May 21, 2008 | 07:32 AM
  #99
freyke's Avatar
freyke
What the heck does the octane have to do with "varnish?" The answer is "nothing." Detergents in the gasoline's additives are there to help keep fuel system clean, not the octane level. In some cases you may get more detergents when you increase the grade of fuel.
Old May 21, 2008 | 07:50 AM
  #100
PAmotorman's Avatar
PAmotorman
your last statement is correct and the additives are put in by the local distributor so he could cheat to make more profit so i would stick with a national brand gasoline not a no name. GM one time threatened to list the brands of gasoline with the proper additive in the owners manual of their cars if all brands did not have the proper additives as it was costing GM lots of $$$$ to replace injectors under warranty
