Looking at purchasing an '07 Z06.........are there any inherent problems/issues(major and minor) that the Z's have or to look for?
Thanks in advance.........
I hope this problem has been solved, but some cars have a strong, noxious odor of resin or solvent. It was even mentioned when one of the car rags tested a Z06.
The resin odor was reported in a few of the 2008s.
A few '07s with January '07 -June '07 engine build dates have had the needle bearing and rocker arm issue.
All of the LS7 engines for the Z06 are hand built at the Wixom Performance Build Center. A few of the actual engine builders post in this thread and are very helpful.
I would suggest that you make sure that it is stock and NEVER had the PCM flashed with an aftermarket tune. Even if it has been reflashed back to stock, they can tell and void your warrantee.
The build date is on the driver's door. Mine was built December 06 and no needle bearing problems.
I thought that only some of the 08's have the odor issue.
But would only add that the inside of the driver's door will tell you the car's build date, not the engine build date.
Still glad to hear that you have no needle bearing issues.
