Running without the neck waddle?
Old Jul 13, 2008 | 07:35 PM
call2wolf's Avatar
call2wolf
Originally Posted by Wezel
Have you tried approaching/topping these things slowly at a 45 degree angle? It's not always possible, but if you can, it usually won't scrape. If you have F55, putting it in "Sport" might help a little bit.
You have my attention!!! If you have F55, what will putting it in the "Sport" mode accomplish.
I'm not being a "smart azz" just trying to understand the rationale.
Old Jul 13, 2008 | 08:40 PM
Fuego's Avatar
Fuego
leave it alone and worry about something else. It doesn't hurt it to scrape.
Old Jul 13, 2008 | 10:07 PM
Fawndeuce's Avatar
Fawndeuce
Interesting feedback from everyone. I know that it doesn't hurt for it to scrape, but I find it annoying.
I'm going to just take it off, and if ever that creates a problem, I'll just put it back on.
Paul
PS. Airflow related cooling issues are typically experienced at low speeds or at idle. A spoiler has no effect under these circumstances. If ever I see a noticeable increase in water temp at highway speeds (very highly doubt it), I'll reinstall.
The only potential adverse effect that I can see, might be a very minor reduction in highway MPG, as a bit less airflow will be diverted from under the car. If I lived in Germany, I'd leave it on.
Old Jul 13, 2008 | 10:14 PM
dpigguy's Avatar
dpigguy
Originally Posted by haljensen
The air dam on a C6 is a designed part of the cooling system, it causes negative pressure behind the radiator to assist in pulling air thru the radiator instead of under the car. Might not make a difference on a low mileage car since the cooling system is 100% but it will make a difference under extreme conditions or extended mileage.
It's a cheap replacement part, let it scrape.
however, isn't the term "negative pressure" incorrect? I believe that is called a "vacuum" or a point of lower pressure relative to another
Old Jul 13, 2008 | 11:59 PM
Rocketmanwpb's Avatar
Rocketmanwpb
It is made to scrape, even states so in the manual. No big deal
Old Jul 14, 2008 | 12:02 AM
SpryGeezer's Avatar
SpryGeezer
I see the spoiler assembly as an early warning that I'm much too close to something attached to the earth and immobile. It's like a front-end curb feeler. Remember curb feelers?
Old Jul 14, 2008 | 12:23 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Your air dam can take the scraping but if you can't...take it off. Live life on the edge. Occasionally my air dam scrapes but not enough to bother me. I'll leave mine on.
For the most part, it will emphasize certain algorithms to 'tighten-up' the steering/handling of your car (it's not a ride height adjustment).
Old Jul 14, 2008 | 12:33 AM
LD RUNR's Avatar
LD RUNR
Just turn off the traction control and floor it. The sound of burning rubber will mask the spoiler scrapping.
Old Jul 14, 2008 | 12:43 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Old Jul 14, 2008 | 12:46 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Shhhhhhhhhhhhh Don't tell him that. You'll spoil all the smart a** answers on the thread.
Old Jul 14, 2008 | 12:50 AM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Besides, it won't bother you so much after awhile.
Old Jul 14, 2008 | 08:48 AM
freyke's Avatar
freyke
Every once in a while, I take a piece of 200 grit sandpaper and and knock down the curly-queues and smooth out the deep scrapes on mine. Looks darn near new when done - the hit it with some tire dressing - waaah-laaah!
Old Jul 26, 2008 | 11:59 PM
  #33
Vip3rV333's Avatar
Vip3rV333
Since you removed it have you noticed any problems with temps with high or low speeds so far? I have a C5 that Im fixing up that doesn't have a air dam and I need to know wither I should buy it or not. Don't want any extra costs...
Old Jul 27, 2008 | 12:26 AM
  #34
moolys's Avatar
moolys
St. Jude Donor '09
Old Jul 27, 2008 | 12:28 AM
  #35
Vip3rV333's Avatar
Vip3rV333
$115 "cheapest" I found... Not cheap enough for me.
