Going Bra-less
Old Aug 5, 2008 | 02:22 PM
  #41
BetterMostC6's Avatar
BetterMostC6
Originally Posted by dvilin
I was just looking at some invisible bra's installed on several Vettes yesterday at a local show. Although all of them appeared to be installed correctly, they were not invisible to me. I just can not get over the lines were the bra meets the hood and fenders. I have a VR colored Vette and you are correct on dark colors it is even worse. I just keep it waxed try not to follow to closely on the highway and like you said it is in the end only a car.
I was going to get it myself until I saw one installed on a silver Z06 in the dealers showroom. It made the paint look dull and accented the Orange peel something fierce.
Old Aug 5, 2008 | 02:24 PM
  #42
Pocket Aces's Avatar
Pocket Aces
Originally Posted by VETTE-NV
Sounds to me like someone isn't very bright.
The ugly clear bra will stop bugs all day long, but any road debris larger than a pebble can easily puncture the tape. Not only is the paint damaged, but the clear bra will need to be replaced.....what a great investment. A vinyl bra will easily stop what the clear bra cannot....and it can be removed at any time and the car will look original, something that NEVER be done with a clear bra, which looks crappier the longer it's on the car.
8-track? What's an 8-track, Grandpa?
So your saying that a big obvious black piece of vinyl draped over the front of the car is better looking than a very unnoticeable clear bra (even if the clear bra has some minor punctures)? :
Old Aug 5, 2008 | 02:28 PM
  #43
BetterMostC6
<<--- This is a bra and not a big ugly piece of black vinyl. I also have the option of removing it when ever I want.
Old Aug 5, 2008 | 02:45 PM
  #44
Pocket Aces
That's still far more noticeable and "uglier" than a clear bra by far. Where's the gloss on the bumper?
Old Aug 5, 2008 | 02:53 PM
  #45
VETTE-NV's Avatar
VETTE-NV
16 Vettes and counting…..
I'm saying I can use it whenever I feel the need (long trips) and remove it whenever I want. I'm not stuck with having a big piece of ugly tape on the car 24/7. I prefer the look of a removable vinyl bra that is not pretending to be invisible over a semi-permanent clear bra that is always an eyesore.
Old Aug 5, 2008 | 02:56 PM
  #46
Pocket Aces
Guess what Ferrari, Lamborghini and Porsche owner's typically use. That's right clear bras. They even make full front end kits that cover the entire hoods and fenders. The big pieces of tape are not ugly and I can't believe people complain about faint lines when all cars have panel gaps. Just consider the faint lines as part of the car as they are way less noticeable than the panel gaps.
Old Aug 5, 2008 | 03:09 PM
  #47
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Some of you guys are pretty ingnorant... Pocket Aces is right... most all high end cars are comming with clear bra, or the dealers are having it installed. Done correctly with the correct material it's nearly invisible.
They also make a special "clear coat" that is painted on, but is super durable, I forget the name, but it works very well.
Old Aug 5, 2008 | 03:23 PM
  #48
BetterMostC6
Its there fully protected with more than a 1/4 inch of felt padding, and anytime I want to see my beautiful factory finish all I do is remove the bra.
Old Aug 5, 2008 | 03:31 PM
  #49
user051728's Avatar
user051728
This is why if you are **** about rock chips and such you get a paint color that matches easily, and you just repaint. All this bra nonsense that can be fixed by choosing certain paints and just driving normally until you want to touch up the front end.
Any car I buy (not lease) and plan on keeping is bought in an easy to paint match color, usually a solid white or black. Metallic and paints with Tintcoat are hard to match.
  #50
Lucky13's Avatar
Lucky13
I'd bet that is a pretty big PITA. Aside from washings, how often do you find yourself actually removing it? I've seen other threads where folks are regretting that type of cover because of the scratches from sand and installation. I've had clear bras on the bumpers on my C6 and Z06. In both cases, they saved me from big chips driving close to my house - not on long trips. They are invisible enough on VY and VR that you have to look hard to find them. This is not some flimsy "tape"...
  #51
Cobra4B's Avatar
Cobra4B
^ And then worry about dust/debris getting behind it and marring your clear coat. Everytime it rains you have to take it off to dry (or at least you're supposed to). Plus, it doesn't let the paint age/fade like the uncovered spots.
I mean speed lingere makes the nicest traditional bras, but after having one I'd never go back.
For road trips I use a nose mask which is made of a lycra material... quick on/off and very easy to use.
Old Aug 5, 2008 | 04:33 PM
  #52
VETTE-NV's Avatar
VETTE-NV
So what? Ugly is ugly.....doesn't matter how expensive the car is.
"Just consider the faint lines as part of the car...." So, pretend the car came that way??? That logic is about as invisible as the clear bra. Hilarious.
Old Aug 5, 2008 | 04:37 PM
  #53
Pocket Aces
How can something you can barely see be as ugly as a big black piece of vinyl which completely blocks what a cars front should look like? Just consider that big vinyl bra as part of the car then if that sets your mind at ease.
Old Aug 5, 2008 | 04:54 PM
  #54
Texas_Venom's Avatar
Texas_Venom
So you really think vinyl is tougher than this film? Have you ever tried to puncture it or tear it with your hands? I have been in the business for years and have never seen film punctured by a rock. In fact thats the reason why the millitary uses it. Maybe before you go talking about something you have zero knowledge on, do some research. And I am sure you know what an 8-track is...
By the way, I can give you the number of a fellow C5 Corvette owner who had a travel trailer backed up over his hood. It scuffed the material to the point that it had to be replaced ($75)... but the paint underneath it was perfect.
Old Aug 5, 2008 | 04:57 PM
  #55
BetterMostC6
I have owned S/L Bras for years now and NEVER had any paint damage from there product. Not a PITA at all and 100% machine washable on delicate setting and you just hang dry. Its only the first few installs that are hard to do because the unit needs to form fit to the nose. Once formed its a piece of cake. The film offers no padding to cushion rock damage. I have seen clear bras removed with paint chips sticking to them from hard rock hits that broke the paint under the film. You might think your paint isnt chipped because the vinyl is keeping the chips in place but if you remove the product you will see it didn't really save your paint at all.
Old Aug 5, 2008 | 04:58 PM
  #56
Texas_Venom
The same faint lines that people cant see from 5 feet away until you point them out??? Yep souds better than having a big piece of vinyl that will scuff your paint up once it gets dirt underneath it... defeating the purpose of a bra. I am suprised that a kid who doesnt know what an 8-track is is still stuck in the 1980s with vinyl bras.
Old Aug 5, 2008 | 05:04 PM
  #57
Pocket Aces
He probably thinks 8-tracks are what you get on your arm from shootin' up heroine too much.
To Going Bra-less
Old Aug 5, 2008 | 05:44 PM
  #58
Lucky13's Avatar
Lucky13
My VentureShield installer had me try to puncture a sample with a screwdriver. Damn near impossible. That stuff is tough as hell...
Old Aug 5, 2008 | 05:54 PM
  #59
Lucky13's Avatar
Lucky13
Taking it off, putting it through the machine, hang drying it, reistalling it. Worrying about sand. Dealing with removal and washing every time it gets wet. Sounds like a PITA to me.
I've had pretty hard rock hits with zero damage. I never remove my clear bra. Wash and wax it as normal. Only someone really looking for it can tell it's there. I dont ever worry about sand or straps scratching my paint. The cost for the bra on my C6 was $400 and it was included with the car from the dealer on my Z06.
But I agree that 1/4" of felt under a thick piece of vinyl may protect better. The colored bras also look much better than the black versions. But the price for that protection is that someone can spot that 1/4" of padding and vinyl from 50 yards. Sure it can be removed when you are not driving or when you want to play the odds with stuff hitting the car.
I'm not saying the colored bra is not a good choice. But it has some downsides over a clear solution. And claims of better protection are questionable given the odds of scratching your paint by using the product incorrectly.
Old Aug 5, 2008 | 09:12 PM
  #60
VETTE-NV's Avatar
VETTE-NV
It doesn't matter to me what people can or can't see from five feet away. It's what I can see that concerns me. The last thing I want to see every day when I walk out into my garage is a giant piece of tape that will never match the gloss of the paint and will only get worse over time.
My car can look showroom new whenever I want....you just can't do that with a clear bra. Period. I've never had one issue with a vinyl bra scratching the paint. If you use common sense, you never will.
