Going Bra-less
Old Aug 4, 2008 | 12:44 PM
mbovino's Avatar
mbovino
Default Going Bra-less
After one year I decided to take off the invisible bra on my black C-6. I had full coverage including the hood, fender fronts and bumper. I left the bumper cover in place.
Over the year I sustained a few rock hits on the windshield (and maybe hood on the way to the windshield) with no damage. That's life driving the chronically under repair highways in the NY metro area. My observation is that the slope of the hood, and that of the windshield are so steep that most strikes are glancing. I took it off as I was hating the look of the inevitable wax line formed on the edges, and the dull contrast of the bra against the black paint.
It peeled right off with no damage although it took some elbow grease to get the residual adhesive off. I used Meguire's polish which has solvents, followed by a good wax and the results were excellent.
Maybe the invisible bra would be more invisible on a white or silver car, but on black it was just too noticeable. I will roll the dice - heck, it's only a car!
Old Aug 4, 2008 | 12:52 PM
danl72's Avatar
danl72
Good luck.
Old Aug 4, 2008 | 01:09 PM
dvilin's Avatar
dvilin
I was just looking at some invisible bra's installed on several Vettes yesterday at a local show. Although all of them appeared to be installed correctly, they were not invisible to me. I just can not get over the lines were the bra meets the hood and fenders. I have a VR colored Vette and you are correct on dark colors it is even worse. I just keep it waxed try not to follow to closely on the highway and like you said it is in the end only a car.
Old Aug 4, 2008 | 01:20 PM
Max EPR's Avatar
Max EPR
.Be careful now. Your front bumper will start to droop.
Old Aug 4, 2008 | 01:22 PM
TRR's Avatar
TRR
Old Aug 4, 2008 | 01:26 PM
maxp's Avatar
maxp
it happens as vettes age
Old Aug 4, 2008 | 01:29 PM
maxp's Avatar
maxp
I have only the front bumper area covered on my black C6 and the sealant I use does not leave any residue. I am not too worried about the fenders or hood...I have had on strike on the front and the 3M did its job
rjwoerheide's Avatar
rjwoerheide
Gravity's a b*tch
Old Aug 4, 2008 | 01:36 PM
Dueysan's Avatar
Dueysan
Never understood the clear bra concept. For the price of those things you can get the front end repainted entirely. Just like you I have zero chips on the front end from road debri...I do however have a nick in the window (which I need to repair with one of those 10 dollar kits), passing a truck and it kicked up a rock and wack..chip in the passenger side of the windshield. It's not rocket science and I know it's hard in some congested areas but if you don't tailgate you're far less likely to have road debri hit the car.
Old Aug 4, 2008 | 01:46 PM
JRHAWK9's Avatar
JRHAWK9
I didn't get a clear bra for that reason, as I saw a few in person and I can still see it. I run a SL bra, sure, it doesn't look terrific on but I can take it off when not needed and you don't see anything. Best of both worlds. When you need it you are protected better than just a clear film and then when you don't need it you can completely remove it.
Old Aug 4, 2008 | 01:49 PM
sav426's Avatar
sav426
100%
Old Aug 4, 2008 | 01:51 PM
jdurhan's Avatar
jdurhan
I removed mine from my black coupe as well, for the same reasons. love the bare look much better a nice deep look again.
Old Aug 4, 2008 | 01:58 PM
sranger's Avatar
sranger
I have never really liked the Clear Bra's on cars. To me it is like putting vinyl slip covers on a couch.
I would rather re-paint when and if it is necessary. In the past, I usually repairthe chips my self with a little painting, sanding and buffing. I then have a pro spray a few coats of clear over the entire car then wet sand an buff....
About $1,500-2,000 and it looks BETTER than new....
Old Aug 4, 2008 | 02:00 PM
csun213's Avatar
csun213
Just for your information, clear bra now can cover the entire fender and hood with no lines.
There will be no line half way through the hood and fender like it was before. You can not tell there is a clear bra on your car now since everything is smooth.
I am going to have my old clear bra removed from the hood and fenders, then put on the totla coverage bra and fenders.
Old Aug 4, 2008 | 02:01 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
I don't know my current C6 has a clear bra and when I go on cruises I hear the rocks hitting the windshield it is nice to know there is some protection.
My black C5's always ended up with a peppered front and it always bothered me. Unless your a couple feet from the bra you don't notice it.
Old Aug 4, 2008 | 02:03 PM
Modshack's Avatar
Modshack
Clear Bra's primarily benefit Owner #2....
Old Aug 4, 2008 | 02:32 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
To Going Bra-less
Old Aug 4, 2008 | 03:05 PM
cranky's Avatar
cranky
had the wax around the bra line also. used a soft bristle toothbrush and went around the edge of the bra. no more line you could see. have had a few hits on the bumper that we're really hard and no damage. i'm keepin mine on. 2005 vr vert.
Old Aug 4, 2008 | 03:09 PM
Deja Vu 2 U's Avatar
Deja Vu 2 U
From: Somerset Kentucky... Life's Abundant For Those Who Believe
bra.....less baby
the only way to be
Old Aug 4, 2008 | 06:44 PM
Texas_Venom's Avatar
Texas_Venom
Its pretty simple really. From 5 feet in front of the car you cannot see the bra installed. With traditional bras you can see it from 500 feet away. So no its not totally invisible... unless you wrap the hood and fenders, but it is much better than a leather bra... which will vibrate and rub the paint over time.
Now as far as repainting the car, maybe your right maybe not. You can install a clear bra and not have to worry about getting the car repainted or you can go without. If you don’t and you end up having to repaint the car... you are not going to have your car for a significant amount of time, travel and drop off to the body shop, worrying about the paint being matched perfectly which can not always been done correctly, your car will depreciate due to having it repainted (and likely more rock chips on it by then)... the list goes on and on.
Its really a great investment when buying a new car. Not only will your resale value be higher from having the car's paint in perfect condition, you will get a little extra for the bra being on there itself. To me its easy to see how it is worth it.
