Dbs?
Old Aug 8, 2008 | 03:06 PM
citoriplus's Avatar
citoriplus
Default Dbs?
Went to Myrtle Beach for a week . Came back, not enough juice to start car. Not even 2 weeks. Oh well.
Old Aug 8, 2008 | 03:08 PM
MNVette's Avatar
MNVette
The 2007 A6 (at least early production) was subject to the DBS issue. Did you ever get the reflash done or verify that you didn't need to do so?
Old Aug 8, 2008 | 03:09 PM
User 020720's Avatar
User 020720
I haven't heard of a DBS issue on an 07? Sounds to me like your battery simply ran out of juice.
If I'm going to be gone for an extended period of time, on the cteq 3300 goes for additional peace of mind.
Old Aug 8, 2008 | 03:30 PM
MNVette's Avatar
MNVette
Some early 2007's had the DBS issue - it wasn't resolved until December, 2006 - well into the 2007 run. That doesn't mean DBS is the problem here, but it can't hurt to check his VIN to see if it's in the affected range.
As for DBS itself, I reject the notion that leaving a car sitting for 7 days should cause the battery to totally discharge. That's . If the Vette is so damn sensitive that it has to be put on life support after a few days, there is something very wrong. And, there is no reason to tolerate that kind of idiotic engineering just because it's a "Vette."
Old Aug 8, 2008 | 03:33 PM
danl72's Avatar
danl72
Sorry to hear that.
Old Aug 8, 2008 | 04:12 PM
djpatrick35's Avatar
djpatrick35
My '07 Covertible had that problem. A reflash ought to fix it up.
Old Aug 9, 2008 | 10:03 AM
Beezvette's Avatar
Beezvette
I monitored the voltage with a digital meter for several weeks and I figured the car could sit for about 4 weeks without the battery needing charging. I often leave my 07 parked for 7 days and so far, no problem. Mine is a March 07 build.
Old Aug 9, 2008 | 11:18 AM
Wayne O's Avatar
Wayne O
CF Senior Member
I wouldn't assume you have the so-called DBS. Have your battery checked and replaced if necessary. Batteries are maintenance items that need replacement periodically. I wouldn't worry about battery tenders or priority starters at this point. Have the dealership perform the 're-flash' the next time you're there.
If you're still worried when you leave town for an extended period, just disconnect the battery terminal while you're gone.
I've let my 2005 MN6 (the one's supposedly notorious for DBS) sit on many occasions for periods in excess of 2 weeks...no battery tender...no priority start and never a problem. After 3 years of problem free use, I did recently replace my original OEM battery. They do wear out.
Old Aug 9, 2008 | 06:45 PM
Eritosthenes's Avatar
Eritosthenes
Is there a service bulletin you can cite for this? My '07 A6 was built in early Aug '06. This is the first I've heard of DBS in anything but the '05 model year.
Old Aug 9, 2008 | 07:09 PM
Hoonose's Avatar
Hoonose
DBS was almost exclusively '05 MN6, with very few early '06's included that had battery drainings from different causes than the '05's. No '07's were ever affected by DBS. DBS is not a catch-all phrase, but that doesn't mean an '07 couldn't have all sorts of other reasons for a sudden battery drainage.
To Dbs?
