Fender Bender...
Old Sep 2, 2008 | 09:36 PM
user051728's Avatar
user051728
Default Fender Bender...
So I've had the Corvette for 4 months and 5700 miles and today it officially became mine. I managed to rear end someone at low speed (one of those you thought they made the right turn but they just moved up around the corner about 10 feet and stopped again). My fault so no one to get mad at but myself.
Anyway I am taking it into the shop on Thursday, so hopefully the shop makes it good as new. My AW will be put to the test as far as paint matching goes.
Old Sep 2, 2008 | 09:42 PM
NYC6's Avatar
NYC6
Thats not bad, a couple hundred and It'll be good as new.
Old Sep 2, 2008 | 09:44 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Too bad about the accident but stuff like this happens to the best of us. It should be fine. Good luck!
Old Sep 2, 2008 | 09:45 PM
Tzzird's Avatar
Tzzird
Not sure about that. I have a buddy who's an adjustor at a shop. He quoted me close to $800 for the rear end to be repainted. I'm no adjustor, but I would venture to guess that the nose piece costs just as much to repaint and color much as the rear.
Old Sep 2, 2008 | 09:55 PM
NYC6's Avatar
NYC6
Just a laymans guesstimate on my part.
Old Sep 2, 2008 | 11:00 PM
St.Char's Avatar
St.Char
$750.00 to clear my front bumper from a few light rock scratches. Plan on doing this over the winter, seeing that I can't wax it for 90 days after repair.
Old Sep 3, 2008 | 09:27 AM
JVM225's Avatar
JVM225
St. Jude Donor '06
That should be an easy fix.
Do you think that a clear bra might have reduced the damage a bit?
Old Sep 3, 2008 | 10:09 AM
Texas_Venom's Avatar
Texas_Venom
All of the black marks would be on the bra and not on the car. All you would have had to do would be replace the clear bra and it would have been good.
Old Sep 3, 2008 | 10:13 AM
bagwell's Avatar
bagwell
not that bad....I did the same thing before...now I make sure the person in front is completely gone before I move at all.
if this is the worst accident you have in the vette, consider yourself lucky.
Old Sep 3, 2008 | 10:45 AM
cclive's Avatar
cclive
AW is one of the easiest colors to match!
Old Sep 3, 2008 | 11:42 AM
rjwoerheide's Avatar
rjwoerheide
Ouch. Fortunately it will be easy to fix and will be just like new.
Good luck and consider it a learning experience
Old Sep 3, 2008 | 11:51 AM
moolys's Avatar
moolys
St. Jude Donor '09
Old Sep 3, 2008 | 12:04 PM
user051728's Avatar
user051728
Depends, the bumper did have two dents in it (The deep gray blotch is a dent on top of the paint being scrapped off). I'd assume that those would still be there even with a bra.
Old Sep 3, 2008 | 12:09 PM
Red Cell's Avatar
Red Cell
Question;
That lip (edge) by the right front light has come up...is that an easy fix because what holds it back in place?
Also, I would think a clear-bra would have saved the scuff marks.
Sorry for your minor damage but hopefully this won't be expensive.
Red Cell.
Old Sep 3, 2008 | 12:37 PM
dvilin's Avatar
dvilin
Good luck with the repairs and paint match.
Old Sep 3, 2008 | 01:50 PM
TRR's Avatar
TRR
Sorry to see that happen. It should be fixed up just like new. Just be glad no one was hurt. Good luck.
PS: It's good to see someone admit fault without blaming something or someone else.
TRR
Old Sep 3, 2008 | 02:29 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Sorry about your dent.
If you needed to get that ticket punched, you did it cheaply and smartly. You can now check off that box - let's see, dent car, check!
I only hope I am as lucky or smart when I ding mine the first time!
To Fender Bender...
Old Sep 11, 2008 | 03:48 PM
user051728's Avatar
user051728
The car is back from the shop, looks good as new. Although they put on a 2008 emblem when I told them I had swapped in 2009's....
So I guess I have to get them to swap it out.
Old Sep 11, 2008 | 03:49 PM
Pocket Aces's Avatar
Pocket Aces
Originally Posted by Red Cell
Question;
Red Cell.
That lip just snaps down in place. Very easy to fix.
Old Sep 11, 2008 | 03:50 PM
beav626's Avatar
beav626
the 09's are different?????
