CAI Question
And show me one documented case of hydrolock using it. I've driven in torrential downpours without any problems. I'm sure if you drove through 2 ft of standing water, that would be another story. But then you would be an idiot.
:o
I just find it hard to believe that a $500-600 CAI is worth more than double what another descent CAI that could be had for $200-300. Theyre all going to make about the same hp and give the same throttle response. If not please pm me and show me otherwise
On 10/10/2007, three consecutive passes were made completely stock at 6:31, 6:40 and 6:47 pm. The results were 11.94 to 11.97 sec at 115.8 to 116.2 mph.
Then the pre-installed panel was removed to open the radiator shroud and the Honker was installed. Three more passes were made at 7:20, 7:31 and 8:40 pm - 11.67 to 11.70 sec at 117.9 to 118.3 mph. (We prepared the car in advance so the Honker could be installed in about 30 minutes.
In the preceding chassis dyno test, we made three pulls completely stock, then removed the panel to open the shroud, installed the Honker and made three more passes. The tests were performed on the same day, data is SAE corrected.
OE, 3 Run Avg = 386.4 rwhp/ 383.6 lb-ft;
IAT(°F) - ECT(°F) @ start / finish = 81 / 100 - 210 / 210
Honker, 3 Run Avg = 402.9 rwhp/ 395.9 lb-ft;
IAT(°F) - ECT(°F) @ start / finish = 77 / 79 - 212 / 216
Conclusion: 16.5 rwhp/12.3 lb-ft increase with Honker vs LS3 OEM air cleaner system.
Different intake systems produce different performance.
