Windshield Replacement
Old Jul 20, 2009 | 06:58 PM
  #41
fchafey's Avatar
fchafey
How long did you have to wait for your windshield? Mine was ordered on the 29th of June and it might be here this Friday the 24th of July. Nice huh?
Old Jul 21, 2009 | 12:44 PM
  #42
danielc6's Avatar
danielc6
one week instead of three days ;the dealership sent the wrong one first
Old Jul 24, 2009 | 04:07 PM
  #43
JJC1's Avatar
JJC1
Do the dealerships replace windshields or do we have to take it to a glass repair shop?
Old Aug 25, 2009 | 10:24 AM
  #44
Tree1985's Avatar
Tree1985
My dealer uses a glass sub contractor so I recommend going direct to the sub...
Old Aug 25, 2009 | 10:26 AM
  #45
Tree1985's Avatar
Tree1985
Took 5 days to get it. 7 days total wait time
Old Aug 25, 2009 | 03:13 PM
  #46
E7_USAF_RET's Avatar
E7_USAF_RET
Had some of the same issues when the windshield cracked on my 2003 Jag S-type. Got some pretty low quotes for replacement until more in depth research was done on the windshield needed. Could only be ordered from Jaguar because of the electronics built into the glass. They used my VIN to get the correct glass. Covered by insurance.
Old Aug 25, 2009 | 08:38 PM
  #47
RobVette's Avatar
RobVette
I received a small chip on the driver side; the glass repairman said it had to be replaced. Since it hasn't spread; I'm taking my time to get it replaced.
Any thoughts?
Old Aug 26, 2009 | 09:05 PM
  #48
Tree1985's Avatar
Tree1985
Any thoughts?
Should be covered by insurance whenever you claim it. Mine was right in the line of sight and pretty big so I had it done right away.
Old Aug 26, 2009 | 09:18 PM
  #49
LMB-Z's Avatar
LMB-Z
I got a chip in mine a few days ago, right in the line of sight, but only a small chip. Took it to a local windshield repair dealer. He repaired it. He told me a new windshield was $1400 plus labor to install. Only cost me $35 to repair. I think I'll go check my insurance to make sure I have glass replacement.
Old Aug 26, 2009 | 10:11 PM
  #50
Vettlldo's Avatar
Vettlldo
Originally Posted by Tree1985
I automatically assumed they would take that into consideration, but assumptions are at the root of all major screw ups.
Thanks!
Be sure that they order the correct windshield - especially w/HUD. Also, check your rearview mirror once the windshield is installed since they can loosen up with a new mirror mount glued to the windshield. I had this problem when I had my windshield replaced last year.
Old Aug 27, 2009 | 07:34 AM
  #51
Scruff Vette's Avatar
Scruff Vette
How did the repair come out? Is it visible now?
Old Aug 27, 2009 | 08:11 AM
  #52
John Mclain's Avatar
John Mclain
Took him about 3 hours and cost my insurance company $1,142 plus my $100 deductible. Man, and I thought the tires were expensive :-)
I had the windshield replaced by the dealer on my 09 under warranty with under 100 miles on the clock.
The dealership gave me a loaner, and would not let me pick up the car for 24 hours after the job was complete.
They had claimed that the sealant around the windshield, needed at least 16-24 hours to fully cure.
I'm not sure if its truth or tale, but this is what I was told.
Old Aug 27, 2009 | 12:38 PM
  #53
cherylandcliff's Avatar
cherylandcliff
I have two repaired rock hits.
I tried to get a replacement windshield, but gave up and had the repair.
I used the insurance recommended co and they tried to get the windshield and got two that were bad. One was cracked and the other had distortions.
Next I called the dealer and found out who they used. I was home when they came and he was about to start to remove the old one and checked the new one and it was not the right one. I don't have nav and it was for one with nav.
I'm just going to wait until I really have to replace it. Too many people out there who don't know what they're doing.
Old Aug 27, 2009 | 01:04 PM
  #54
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
When we had the W/S replaced on our C5, the shop didn't keep it quite that long but did hold it for most of the day even with quick curing sealant. He showed me literature about the cure time and also that many windshields today are considered a structural part. You need the bond to have strength, not just water tightness.
Old Feb 11, 2011 | 04:55 AM
  #55
super v's Avatar
super v
Can anyone tell me the correct procedure to fit a screen to a c6 z06 as the new one i have had fitted is sitting too low, ie the rubber trim on the roof line is not under compression leaving high edges on the side 'A' Posts. You can also push a thin plastic object like a credit card under the roof panel... The fitter said the glass can only fit one way as it sits in clips on the body and cant move up.. The screen came from a main dealer and has the GM stamped on it. Can anyone please advise as the car has sat in the body shop for 2 months now
