Wheels and Performance
I have noticed here that there is very little discussion on how much wheels can affect performance and I have yet to see weight figures for after market wheels.
Is this because the vette is such a hulking beast that it doesn't really matter?? Are after market wheels just better than the OEM wheels and anything is better than GM?? Or am I just in the wrong section of the forum??
My recommendation is CCW.
One of the main gripes about the stock wheels is not just the weight, but the space for big brake kits. It limits what we can use.
My CCW wheels came from them powder coated Comp Grey.
The concerns are very different when you're working on a 2400lb car with a power to weight ratio of 15 lbs/hp vs. a 3200 lb car at 7/1.
Less weight is always good, but it's less of an issue when you start off with overkill.
I'm not sure what you mean by hulking beast, but in stock trim the Corvette is a pretty light car compared to most. Of course, they are heavy compared to a Miata. On second thought, compared to a Miata maybe a Corvette is a hulking beast, but a very good one
My impression is similar to some of the above statements: in the General section, most are concerned with looks, increase in wheel sizes for looks, and/or more traction with wider tires/wheels. Weight is not much of a concern here. And it doesn't have to be to overcome an added, say, 5 lbs. per wheel, with over 400 hp and same for torque.
That said, as above mentioned, the stock base wheels are cast and not exactly heavy. The stock, but optional forged wheels are lighter and stronger but only come in one or two finishes (and only one style).
Unless you/we actually search for, or ask the question, it isn't always easy to find weights for aftermarket wheels that fit the C6. And that is also part of the issue: there aren't a whole lot of different wheels for the C6 in repro land.
I think it's generally understood that lighter (to a point) is better for many reasons. That said, there are some other reasons to go the other way, and there is even a downside to a lighter wheel that can't (potentially) stand up to the rigors of today's roads and streets. Esp. when you combine a super-light wheel with an even lower profile tire that affords very little "tire" separation from the imperfections in road surfaces.
That's my take on it and that's why I have the option wheels originally offered by Corvette. They work for me.
HUH??
CCW specifically does not offer chrome wheels.
They will, however, sell you their polished, forged aluminum wheels ready for plating, but you must get them chromed elsewhere and assume the risk.
Do some more research.
We are currently looking into Hyper black also.
Melissa
CCW
Generally, there are 2 ways to look at rims - regular and expensive. The vast majority of reproductions, etc. are "regular" - they are cast and slightly heavier than stock polished or chrome rims from the factory. If looks are what you want, this is the way to go because a set of 4 will run less than $1k. The weight penalty really isn't an issue since (a) our cars are quite light to begin with, and (b) they have way more power than a Miata. Think about it - a stock LS3 has about triple the horsepower of a Miata, but it only weighs about 700 pounds more.
If true performance and lighter weight are what you want, it is available from several sources, but you will pay through the nose for it - $4k for a set, easily. I ran across a set of carbon fiber rims from Germany at over $8k for a set. There is no such thing as a lighter yet cheaper rim in Vette world.
Personally, I'd never pay for a set of rims that expensive on a Vette. But, to each his/her own.
