Does the C6 require special maintenance?
Old May 7, 2009 | 09:54 AM
danl72's Avatar
danl72
Originally Posted by lander
The C6 is NOTHING like a stang.
Old May 7, 2009 | 09:55 AM
Wayne O's Avatar
Wayne O
CF Senior Member
The average person can handle routine maintenance on the C6 just fine. As Jay Leno said "It's a Chevy...you can fix it with a hammer." As with any car it depends on your level of mechanical ability and having the proper tools to do the job. I think it helps to have the service manuals. Knowing when something is over your head can be important as well...having a mechanically knowledgeable friend with a home lift doesn't hurt either.
Old May 7, 2009 | 10:00 AM
Random84's Avatar
Random84
Manual transmissions ought to have the clutch fluid replaced at every oil change to prevent crud build up, but even still you'll probably get 80,000 miles out of it before you notice leaks.
Old May 7, 2009 | 10:05 AM
6SPDRCR's Avatar
6SPDRCR
Originally Posted by firecop90conv
"normal" maintenance, do it yourself. "Un-normal" maintenance, take it to a professional
Old May 7, 2009 | 10:31 AM
srtclg1007's Avatar
srtclg1007
St. Jude Donor '11
I do all the repairs on every car myself........ I haven't had my C6 running in 5 weeks.... J/k
Old May 7, 2009 | 01:15 PM
mrtoner's Avatar
mrtoner
Originally Posted by Walkthedog
Most of the work done to our cars seems to be changing the oil and adding mods. Also some feel the need to add badges, but that is another thread. The maintanence seems very easy/ minimal. I have a 2005 and had a tire sensor issue once and I change my own oil. Could not be more of a dream.
"B A D G E S !!!!"
Say it isn't so......
Old May 7, 2009 | 02:35 PM
markabc6's Avatar
markabc6
Originally Posted by cmnguye8
I used to have a 2003 Mercedes Benz C-class and I would always have to bring it in to the dealer for maintenance and repairs.
When I had my 2002 ford mustang, all the repairs could have been done by myself, so is the C6 more like the stang or Benz?
It seems like you are asking two different question <maybe I'm trying to read too much into it?>
Depends on your mechanical expertise and your checkbook...
MB has scheduled service intervals (A, B, etc) where they do routine maintenance and have a checklist of other procedures the tech performs. <some> People wouldn't know a ping from a rattle, let alone that a wheel is about to fall off. This is done for safety, warranty reasons, and $$$.
Chevy has scheduled service intervals as well, the tech may also check things like tire wear, brake life, oil leaks, etc. Same reasoning as above.
Chevy will also allow most warranty claims on some sort of documentation of oil changes, etc. And with knowledge of basic hand tools, this is very easy to do.
But if you are having mechanical or electrical problems <and it's still under warranty>, you really should take it back to the dealership for repairs.
I can't really say that the Corvette is bulletproof <seems a few less than stellar units slip by QC> But it is more of DIYer <if that's your thing> than most Mercs.
Good luck
Old May 7, 2009 | 02:41 PM
StoplightWarrior's Avatar
StoplightWarrior
my car has this annoying problem of getting up to speed WAY too fast. Can't seem to figure it out. I hit the gas pedal then like 4 seconds later I'm doing freeway speeds and have to let off the gas.
Other than that, the car is awesome. lol
Old May 7, 2009 | 02:50 PM
buffguy's Avatar
buffguy
You have to change the clutch fluid everytime you do a oil change? That is crazy, I haven't seen any car requiring that.
Old May 7, 2009 | 02:52 PM
buffguy's Avatar
buffguy
Originally Posted by gota07
The biggest difference in service requirements comes with the Corvette models that have a dry sump oil system which requries a modified procedure for the oil change. Since it looks like your interested in the base coupe / convertible, this shouldn't affect you.
You can go to the GM Parts House website and check out the service requirements in the PDF version of the owners manual they have available.
www.gmpartshouse.com
What is difference from the dry slump oil change and regular oil change?
Old May 7, 2009 | 03:01 PM
Dueysan's Avatar
Dueysan
It's super easy to do though. Clutch dust gets into the clutch hydraulic system. A plastic syringe and some Dot4 brake fluid and you can swap out hydraulic fluid every few thousand miles or as necessary. Takes less than 5 minutes to do. Someone has a video describing the issue and how to deal with it.
GotCorvette?'s Avatar
GotCorvette?
If you're getting a black one, 99% of your maintenance time will be keeping it clean.
Enjoy! Black looks great when it's clean.
Old May 7, 2009 | 03:47 PM
  #33
RPHCRMZ51's Avatar
RPHCRMZ51
Originally Posted by PCMusicGuy
There is one particular piece of special maintenance you must perform the the C6. Occasionally, you must fully depress the right-most pedal to ensure everything is in working order.
Old May 7, 2009 | 03:49 PM
  #34
nwc6's Avatar
nwc6
It is a "sticky" at the top of the tech section;
http://forums.corvetteforum.com/c6-t...al-issues.html
Other than that, I really have to LOOK for things to work on..
Old May 7, 2009 | 04:05 PM
  #35
Vette Suspension's Avatar
Vette Suspension
Originally Posted by shopdog
Neither. Treat it like a Silverado. Its a Chevy, no special care required.
Great point. Not as expensive to repair as a Benz or even a Toyota with their new quality issues and very expensive parts.
Old May 7, 2009 | 04:45 PM
  #36
coryvte's Avatar
coryvte
Replace rear tires with every oil change!
Oh, wait. That's the maintenance if you drive it right!!!!!!
Old May 7, 2009 | 04:50 PM
  #37
lander's Avatar
lander
St. Jude Donor '09-'10-'11
My wife gets on me about this as well...I hear her screaming at me every day I leave for work and attain freeway speeds backing out of the driveway.
I think she's being a little over-protective of me to be honest.
To Does the C6 require special maintenance?
Old May 7, 2009 | 04:53 PM
  #38
coryvte's Avatar
coryvte
No, not protective of you. Its getting expensive buying a new dog every night when you back over it. Try backing into the garage, then you can really leave as the forward gearing has a much better ratio.
Old May 7, 2009 | 05:10 PM
  #39
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
In the first 20,000 miles I've had to go to the dealer once. The clip on the floor mat broke and there was no way I could fix it myself. Other than than, I've changed my own oil (twice so far and getting ready for a third), replaced the cabin air filter (not because it was dirty but because I wanted a charcoal filter) and gone to an independent tire shop to have tires mounted, balanced, and get an alignment. In another 5,000 miles I'll be due for crawling under the car to see if there are any exhaust or fuel leaks. I'll probably replace the engine air filters then also whether they need to be replaced or not. That's about it.
Old May 7, 2009 | 07:07 PM
  #40
rdm1465's Avatar
rdm1465
You won't need to worry about that. Just a regular oil change in a standard C-6. Since you said you were getting a 1LT.
But, the dry sump requires alittle more oil.
