fun vette
Old Jun 6, 2009 | 02:10 PM
jerry hardy's Avatar
jerry hardy
1st Gear
Default fun vette
2005 has had two fuel pump failures in 15 months. Is this a common problem?
Old Jun 6, 2009 | 02:13 PM
CQRT's Avatar
CQRT
I have an early 2005 (Sept 2004 in-service date) and have thusfar had no such issues at 25k miles - - -if it's an problem for others, it's rarely hit the forum.
Not sure what might cause such a thing - - -
Old Jun 6, 2009 | 02:28 PM
RicK T's Avatar
RicK T
I don't recall any fuel pump issues here on the Forum.
Old Jun 6, 2009 | 02:41 PM
CudjoeScott's Avatar
CudjoeScott
St. Jude Donor '09-'10-'11-'12
I have heard of this when the ethanol content is high (not with vettes, with other makes). Lexus (wife's DD) actually had a recall regarding fuel system failure and high-content ethanol gas. Any chance your gas has greater than 10% ethanol content? You might try having your gas tested or just switch gas stations.
Old Jun 6, 2009 | 06:17 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Me neither. I haven't had any fuel pump problems with my 2005.
Old Jun 6, 2009 | 06:35 PM
cranky's Avatar
cranky
i have an with zero fuel pump problems. if you are running the fuel level under 1/4 tank a lot, the pump life will go down. the fuel keeps the pumps cool. have seen a lot of cars with fuel pump failure from this. i was a tech for 28 years and changed a lot of late model pumps. just a thought.
Old Jun 6, 2009 | 07:33 PM
danl72's Avatar
danl72
Old Jun 6, 2009 | 08:10 PM
RACN1320's Avatar
RACN1320
I've always heard that the overwhelming majority of fuel pump failures are caused by running out (or at least nearly out) of gas
Old Jun 6, 2009 | 09:18 PM
VET4LES's Avatar
VET4LES
It's an issue for sure.
Old Jun 6, 2009 | 09:21 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Wow, first I've heard of it. October of 2004 built 2005 here with 28,000 miles. No problems for me.
To fun vette
