Launch Control
Old Jun 7, 2009 | 08:48 AM
Mark Ducati's Avatar
Mark Ducati
Default Launch Control
Here's a dumb question...
The button on my console allows me to turn off TC, Active Handling, and has a setting for Competition Driving.
I don't ever plan on using "Competitive Mode".... so can the PCM be reprogrammed somehow to simulate Launch Control?
Old Jun 7, 2009 | 08:52 AM
KVA_Dave's Avatar
KVA_Dave
IDK
Old Jun 7, 2009 | 09:18 AM
dvilin's Avatar
dvilin
No.
Old Jun 7, 2009 | 09:19 AM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
Competetive driving mode is my favorite
Old Jun 7, 2009 | 09:26 AM
not08crmanymore's Avatar
not08crmanymore
I asked this a week ago.It's more then the pcm.It's the setup out back with the shocks/springs and some other stuff too.
Old Jun 7, 2009 | 10:01 AM
Wayne O's Avatar
Wayne O
CF Senior Member
The 'computer' system is integrated with the controlled, MR suspension. The launch control system automatically limits engine torque to keep the rear tires hooked up. It allows some wheel spin and progressively feeds in power to the wheels while adjusting the MR dampers. It recognizes a hard launch and completely softens the rear shocks on compression with full stiffening on rebound keeping the rubber on the road. The car will squat and go, rather than bounce. Some further info of interest:
Exclusive to the Corvette ZR1 is Performance Traction Management, the system integrates the Selective Ride, Traction Control and Active Handling systems and manages the vehicle's acceleration based on the conditions and driver's selection.
The Corvette Team re-engineered the ride control switch on the center console. The normal mode continues to give you the tour and sport adjustments on the shock absorbers, but switching into Competition Mode then brings up the Performance Traction Management. The ride control switch than illuminates to PTM Traction. Turning the switch then allows the driver to select the Traction mode.
PTM Mode #1 - Wet
This is the mode intended for use during damp or wet track conditions by drivers of all skill levels.
Engine torque is management based on the given track conditions.
Active Handling is enabled.
PTM Mode #2 - Dry
This is the mode intended for use on dry track conditions by less experienced drivers or those learning a new track.
Engine torque is slightly managed based on the given track conditions.
PTM Mode #3 - Sport
This is the mode intended for use on dry track conditions by drivers who are familiar with the track they are driving. This mode requires more driver skill than PTM Mode #2.
More engine torque is available than in Mode #2.
PTM Mode #4 - Sport
This is the mode intended for use on dry track conditions by drivers who are familiar with the track they are driving. This mode requires more driver skill than PTM Mode #3.
The same level of engine torque is available as in Mode #3.
Active Handling is disabled.
PTM Mode #5 - Race
This is the mode intended for use on dry track conditions by experienced drivers who are familiar with the track they are driving. This mode will require more driver skill than all the other modes.
Available engine torque is maximized for cornering speed.
To Launch Control
