Lowering Ur C6...?
Old Jun 18, 2009 | 05:05 PM
St.Char's Avatar
St.Char
Originally Posted by jpuli28
2" all the way around?
2" drop in the back. I installed these only in the back because you get more drop in the front with turning the bolts all the way down, i'm already low enough in the front.
Old Jun 18, 2009 | 05:06 PM
jpuli28's Avatar
jpuli28
Originally Posted by mcandrew67
it's old codgers like you that can't take the bone jarring when you hit a hump.
David
Is the ride stiffer?
Old Jun 18, 2009 | 05:12 PM
Atomic-Vette's Avatar
Atomic-Vette
it's not "stiffer" but it will bottom out the suspension more which is pretty jarring depending on how bad the bump / hole and your speed.
Old Jun 18, 2009 | 05:13 PM
St.Char's Avatar
St.Char
Yes...but feels tighter to the road, especially when cornering. You need to do this mod. Go to Eklers website for more info. on the pads.
Good Luck!
Old Jun 18, 2009 | 05:59 PM
jpuli28's Avatar
jpuli28
Good Luck!
Ummm...
Old Jun 18, 2009 | 06:01 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
lol, that was more as a sarcastic response to the dinosaur. Not stiffer, but better on corners and off ramps.... no curves per se in south FL other than off ramps. I've never bottomed out, never had bone jarring.
David
Old Jun 18, 2009 | 06:23 PM
cmonkey713's Avatar
cmonkey713
What floors me is that the stealership quoted him $400+ to do it. Even with and alignment that's outrageous.
Old Jun 18, 2009 | 07:51 PM
Capt.vette's Avatar
Capt.vette
I paid $140 last weekend to have my lowered and it wasnt worth it, do it yourself. just like everyone is saying the front im happy with but the rear didnt hardly move. It was so little I jacked the car up myself on both rear sides just to double check their work. And the screws where bottomed out. So I ordered a set of the pads fom ecklers and already got them in so im just going to try them on the back to see how that looks. First I gotta wait til next wed. to take it to the dealership to check out the driver side rear because im hearing a slight knocking sound coming from by the tire when at a slow roll. Im worried if I install the pads they will try to give me some crap about my warranty for whatever they find making the noise. But all in all I should have done it myself bucause it was easy as hell when I did it to double check their work.
Old Jun 18, 2009 | 08:03 PM
shopdog's Avatar
shopdog
Lowering, or raising, the trim height doesn't change the spring rate, but it sure changes the amount of suspension travel before the car hits the end of travel with a bang.
Old Jun 18, 2009 | 08:10 PM
txbikerdude's Avatar
txbikerdude
i would scrape to much
Old Jun 19, 2009 | 12:40 PM
jpuli28's Avatar
jpuli28
Well Im not gonna try to do this myself, besides, I dont have jacks or the tools on hand.
Any place in Broward recommended for mod?
I noticed the bolts from some vendors dont have a bushing around the head of the bolt while C6 performance (C5Racer) bolts do, any opinions?
HPSales in Pomp says a $125 with stock bolts leaving me about an inch of clearance. They said an alignment is needed. (PS They dont do the alignment)
Old Jun 19, 2009 | 04:20 PM
The Popo's Avatar
The Popo
It's done. Lowered the rear all the way. Turned out to be 1/2" with the bolts all the way out. The fronts 1/4". Looks a lot better. It's rainy today, so will post pics tomorrow.
BTW, it was very easy. I used a roll on lift with undercarriage jacks. The instructions from Vetteweb were right on.
Old Jun 19, 2009 | 04:22 PM
  #33
The Popo's Avatar
The Popo
I don't know about Broward. But if you go to Hialeah, about 20min depending where in Broward your at, I would recomend MAK Performance. It's were I get all my work done.
Old Jun 19, 2009 | 04:34 PM
  #34
jpuli28's Avatar
jpuli28
Im assuming you left the bushings alone...?
Old Jun 19, 2009 | 04:45 PM
  #35
The Popo's Avatar
The Popo
Yes. All I did was loosen the bolts. Drove it. Checked it and adjusted it. If i had to do it again, i'd do it in 10 min. If i used the same lift. BTW, no sqweeks.
Old Jun 19, 2009 | 05:38 PM
  #36
Mark Ducati's Avatar
Mark Ducati
Anybody have pics under the car of where to turn what bolt?
Old Jun 19, 2009 | 07:28 PM
  #37
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
It's the bolt at the end of each leaf spring, 4 total
http://www.westcoastcorvette.com/p-4...it-c6-z06.aspx
To Lowering Ur C6...?
Old Jun 24, 2009 | 03:50 PM
  #38
jpuli28's Avatar
jpuli28
Well got it lowered today... Looks awesome!
Cut the bushings 75% and turned up the stock bolts. But it sounds like there is a mouse in the back. I was told if some of the bushings are left no squeaks...
The squeaks come only when driving level and straight. I dont hear anything going over humps and driveways, or hard turns, hmmmm.
Also for those of you who said "no alignment needed" well, my car was straight as an arrow prior to dropping it. Took straight to an alignment shop and the print out was off the charts! Get an alignment!
[IMG][/IMG]
Old Jun 24, 2009 | 03:55 PM
  #39
NiborGnissom's Avatar
NiborGnissom
I arranged lowering with custom bolts ordered before even taking possession of my C6.
Do it do it do it.........she is so much more pleasing lowered. Trust me. And slowing down and approaching the Tim Hortons at a 45 degree angle slowly is not ambarrasing, it is fun.
Old Jun 24, 2009 | 04:17 PM
  #40
Snake Slayer's Avatar
Snake Slayer
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Also for those of you who said "no alignment needed" well, my car was striaght as an arrow prior to dropping it. Took straight to an alignment shop and the print out was off the charts! Get an alignment!
My rears squeaked right after. The rubber need time to settle, I also sprayed the he'll out of both rears with WD 40 and not one squeak 3000 miles later. As for olddog he need to stop pissing on ever thread that deals with lowering a c6. The guy has stated the he would purchase bolts to raise his car if they were available.
