C6 Non Bose: I want to replace the 3.5" door speakers. Whats the procedure?
C6 Non Bose 2LT hatchback: I want to replace the 3.5" door speakers. Whats the procedure?
I was thinking of these POLKS:
http://www.crutchfield.com/p_107DB35...107db351&tp=96
I replaced the head unit with OEM but kept the amp. I just want to add more highs up front and a little more bass wouldn't hurt. I don't want to make any other changes.
CF Senior Member
Here's a couple threads that may help:
http://forums.corvetteforum.com/show...1633971&page=7
http://forums.corvetteforum.com/show...&highlight=s35
Possibly this one as well:
http://forums.corvetteforum.com/show....php?t=1490531
Speakers are terrible in these cars. I will be replacing the entire system in my 06. Good luck with yours. I haven't done it yet and don't know the exact procedure, but it can't be too hard.
I wouldn't reccommend just changining out the 3.5" without a whole system redo. The OEM systems are pretty well sonically balanced using the supplied speakers. You might get lucky, but just swapping out to aftermarket drivers, is a crap shoot. Usually OEM's are much more efficient and probably 2 ohm. Aftermarkets usually need more power to drive and mostly 4 ohm, giving you another volume level hit. If it's more treble your after, look into a small tweeter add on kit from places like Parts Express. I put some of these in my C5, front and rear. The Bose system was still awful, but at least it had some treble.
Guess I just got educated a bit. Knowing what you guy's are having good result's with and 4 ohm, may just try the swap myself. My system has the dash mounted center channel driver and usaully like them in past installs. Curious why to disconnect it.
Big improvement, give it a go!
