Winterizing Tips
Old Aug 28, 2009 | 05:48 PM
Vette 06's Avatar
Vette 06
Cruising
Default Winterizing Tips
Juist wanted some feed back on how to winterizing the car.
I have a 2006 Coupe. The Corvette has been a dream since my teenage years. (30 years ago)
Thanks, and look forward in supporting others.
Old Aug 28, 2009 | 06:06 PM
-CM-'s Avatar
-CM-
Where will it be stored? Will it be in the cold? Will you have access to it? How often? Will you be able to drive it at all?
Old Aug 28, 2009 | 06:08 PM
dvilin's Avatar
dvilin
You should get plenty of feedback on this, some suggesting change the oil, inflate the tires, as for me I just hook-up a battery tender and put the cover on the car. In the Spring I check to see if the tire pressure is okay and that is about it. So far no issues.
Old Aug 28, 2009 | 06:10 PM
TexasC6's Avatar
TexasC6
live in texas
Old Aug 28, 2009 | 06:16 PM
laconiajack's Avatar
laconiajack
Old Aug 28, 2009 | 06:27 PM
IDSRVIT's Avatar
IDSRVIT
Thanks for bringing this up as I live in South Dakota and will soon be storing my C6 as well...... sigh!! :o(
For me it will be in a heated garage so I believe I will just keep the battery tender on, put some carpet squares under the wheels and put a whole bunch of mouse deterant products around it and call it good.
This method seem to work good for my wife '66 mustang GT for the past 10 years but thought I'd check.
Thoughts?
Old Aug 28, 2009 | 06:29 PM
thechief's Avatar
thechief
Stabil.
Old Aug 28, 2009 | 06:52 PM
Wayne O's Avatar
Wayne O
CF Senior Member
Originally Posted by TexasC6
live in texas
Great minds think alike...winter in Arizona!
(sorry I couldn't resist)
Old Aug 28, 2009 | 08:06 PM
Larry/car's Avatar
Larry/car
Not already, it's eighty plus degrees outside. Lets enjoy the summer and not worry about winter yet.
Old Aug 28, 2009 | 09:50 PM
RicK T's Avatar
RicK T
Here's the to-do list for winter storage that has been around here a long time. You can pick and choose what you want to do but it's a good start.
Fill gas tank and add Sta-Bil; be sure to run long enough to distribute through fuel lines.
Change oil and filter.
Park on moisture barrier
Inflate tires to 40 psi cold.
Hook up Battery Tender.
Apply sealant, wax, etc. to exterior paint.
Apply leather dressing to seat panel.
Apply vinyl dressing to interior; and to exterior black trim pieces.
Old Aug 28, 2009 | 09:57 PM
Swiftrider08's Avatar
Swiftrider08
Stabil is another one of those "snake oil" products that you get scared into thinking you need. Modern gasoline will can be stored for 6-8 months with zero issues. Not going to hurt a thing if you use it, but it is really not necessary when you store your car, or anything that uses gasoline, for the winter.
Battery tender, 5-10 psi of extra air in the tires, rubber pads under the tires and a car cover is all I use.
Old Aug 28, 2009 | 10:15 PM
Cypher's Avatar
Cypher
Will I run into problems if I have to remove the battery for the winter? I know about the window re-indexing, but will there be any major issues if the C6 has no power for 5 months?
I may have to put my C6 in storage this winter with no access to power for a charger. I’m in the process of building a new 4-car garage, but I’m hung up in a damn zoning variation and I don’t think it will be resolved in time to get it built before winter.
Currently have 4 vehicles and a 2-car garage.
Old Aug 29, 2009 | 08:41 PM
walker3's Avatar
walker3
Same here - spend winter in Louisiana -
My winter plan is like in the past, keep top off and drive car (may have 3 or 4 days you can't due to cold) but then turn on heater - refreshing
Old Aug 29, 2009 | 08:44 PM
agrumpyguy's Avatar
agrumpyguy
I usually just put the top down for the winter
Old Aug 29, 2009 | 08:58 PM
johnodrake's Avatar
johnodrake
Moderator
I agree - but I do put a bottle of Techron in when I put it away and a bottle of gas dryer in in the spring. I also put in a second bottle of Techron after the winter tank is used. I maintain the air at 30 cold all winter (gives me a reason to monkey with the car ) I will also "wax" the car two or three times - just for practice
Old Aug 29, 2009 | 10:30 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Got a spare room and some garage space?
Old Aug 29, 2009 | 10:33 PM
ohmy's Avatar
ohmy
u mean no Vette in winter?! oh the horror!
To Winterizing Tips
Old Aug 29, 2009 | 11:38 PM
CO Lightfoot's Avatar
CO Lightfoot
Loosely plug the exhaust tips with rags or paper towels... keeps bugs & mice from homesteading.
Old Aug 30, 2009 | 10:20 AM
Dethfyre's Avatar
Dethfyre
My winterization tips....
Buy snow tires
That's what I did this year, we'll see how that turns out heh.
Dan
Old Aug 30, 2009 | 10:14 PM
Vette 06's Avatar
Vette 06
Cruising
The car will be stored in garage, cold 32 f, and I will have access everyday.
I figured on changing the oil before storage, adding gas stabilizer, covering the car and plugging up the intake and exhaust.
About every month I will charge the battery and then start the car for 20 minutes.
