Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why is My Corvette Stuck in Park?
Guide to diagnose trouble with recommended solutions.
Anybody's automatic get stuck in prk?
I've experienced a similar issue but have always been able to correct it within moments. I read in the manual that when the shifter sticks, release the shifter button on top, push the shifter forward to make sure it's in park, then retry. That has always corrected the problem for me. (knockin on wood here). Anyway, if that doesn't do it then I think you have a dealership issue. Good luck with it.
LS Won..I think you should take it in to a dealer before you get really stuck someplace. Your issue doesn't sound like anything anyone else has posted here. It could very well be the same issue but it sure doesn't sound like it. If you have it in Park and you still get a warning then some type of relay or contact switch or something isn't working correctly. The gist of what these guys are getting at, and me too, is that AFTER it's in Park, we can't move the shifter without going thru some type of rain dance on the roof and kissing the shifter etc etc etc. You are saying that yours goes into Park and then the car says Hey, put me in Park. Something else is wrong there. Just my .02 worth. Good Luck
Hopefully not but just a thought we could have the same related sensor or contact going out.
Thanks for the input. I did take it in dealearship before but problem returned shortly thereafter. Thus far this is what I have been doing when this happens. I thought it could be related in some way since it involved the shifter and if the problem gets worse
I took mine to the dealer and they could not make it lock up again so they sent me home. The next time it locked up I had it towed to the dealer, the tow truck driver tried to get it out of park but could not. When he got to the dealer the shifter worked fine again but the dealer replaced it.
It seems to me that if it is the solenoid switch that goes bad, you would think that GM would get as replacement solenoid in their parts list...but wait...that would make too much sense..hopefully they will resolve this recuring problem with the shifter assembly. Knock on wood..I have a 2006 and no issues to date...how's that for jinxing myself...
STUCK SHIFT LEVER 2005 C6 Coupe
My 2005 Coupe does this regularly, except when I take it to the dealer! This is more of a solenoid / electrical or computer problem than the one described by the people taliking about using the hand brake or pushing the car forward as when the weight of the car prevent the parking pawl from releaseing. Question, do most of you have the memory package that automatically adjusts the seats when you get in? I have notices that SOMTIMES but not always, the things locks up when I try to move it out of park before the seats and telescopic steering whel reset. This seems like a common enough problem that Chevy ought to have a bulletin on it. How do we go about making them aware of our frustration?
#34
hi guys i know this is a few months late about 12 = P but i have bought me a crovette c6 damage How do i get the gear out of P and in to N do i need to turn on the engien. can i get in N with no power? so I can push around the car in the workshop. has no ***** to put in a battery. Yet for want to check out cables, etc. before I do it. btw anyone have a good dealer for parts with good prices and a fine spinal That ships Internationally. Sincerely, The Swede
#35
#38
It has not happen to my 07 Vette but it did happen to my 07 Charger. The wifey and I were going out for dinner one evening. Get in, start it up, press the brake and tried to shift out of park and nothing. This went of for approximately 15 min without any success. I give my local dodge dealer's service manager a call on his cell phone, to find out his at Disney with his family. He takes out time to walks me through a temporary fix, which included opening the center console. To make a long story short, the safety switch that connects brake pedal and the shifter had broke. When I pressed the brake the cable would pull but the switch would not release the shifter. Why, Dodge has no clue but told me that my car was not the first one. Repaired under warranty.
#39
Replacing the shifter is not a permanent fix...
In the Chrysler/Dodge world the shifter breaks a little tab inside the housing that holds the end of the spring that allows the part to come out of park. The Dodge crowd fixed this by having a new aftermarket piece made of aluminum instead of plastic, thus never to break again.
Replacing the shifter only means the same thing will happen again later as Mopar did not fix the problem, meaning they just throw on another shifter with the same weak part that ends up breaking again down the road.
Prior to having the plastic piece duplicated in aluminum they simply drilled a small hole in the existing broken plastic piece and reattached the spring and it worked fine.
I am very surprised that as much detail on so many things we do to our cars that no one has yet opened up a Corvette shifter to find out what the problem is and found a fix for it.
#40
micro switch
I have opened it up. The problem for me was the microswitch at the top of the shifter stop. The Metal arm was misaligned/worn. Bent the arm a bit and it worked and has worked from then on.
Just removed the shifter, then removed the boot, then adjusted the microswitch arms.
It doesn't look like a very sturdy design and looks to be easily fubared.
I'll be replacing my boot tonight and I'll take some pics.
