Pinging when accelerating
Old Feb 7, 2018 | 08:00 PM
  #41
FGO's Avatar
FGO
Originally Posted by Vette_DD
This is a 9-year old thread and the OP hasn't been on the forum in 3 years. I doubt if your post is really going to help him very much.
That's too bad - this is a real find! You won't believe the sound these things make. Just like mild ping or something tinging against the exhaust.
Old Feb 7, 2018 | 08:50 PM
  #42
LowRyter's Avatar
LowRyter
I would guess the likely problem would be the knock sensor. Sensor should retard the timing due to low octane gas.
Another possibility, given the high mileage, could be carbon build up. There could be so much carbon that the sensor is reading the bottom of the table and the computer can't retard the timing any further.
I would think that you would get a code and a CEL in either event.
Keep us posted with the outcome and good luck.
Old Feb 7, 2018 | 08:57 PM
  #43
LowRyter's Avatar
LowRyter
Originally Posted by FGO
I have a 2006 Z51 to and the noise drove me crazy. I found it by accident when changing the interior lighting to LED. It's the rear cargo lights. Pull them out and shake them and see (like I did) if it's the same sound. It's the heat shield - just use aluminum tape and tape the shield to the fixtrue so it can't move.
wow. good to know
Old Feb 7, 2018 | 08:58 PM
  #44
LowRyter's Avatar
LowRyter
Doh!
Old Feb 7, 2018 | 09:43 PM
  #45
FGO's Avatar
FGO
Originally Posted by LowRyter
wow. good to know
Rattle it in your hand gently to hear the sound before you draw any conclusions. Let me know. Thanks.
