Turning Navigation and Clock "ON"
I just upgraded from my 2005 C-6 to a 2007 Z-06. Both have navigation systems. Never had any problems with the 2005.
On my 2007, the navigation system shows it to be "OFF". I set the region but the current location is approximately 60 miles off. The "GPS" icon on the screen has a slash through it. There is an indicator showing the navigation is "OFF at the top-left of the screen.
Also, the box in the upper-right corner is blank. No clock display. I have held the digital clock display button in until it went to the clock set-up screen. The set-up clock display box on this screen is also blank. None of the buttons make the clock display on the set-up screen or the main screen.
Uhhhh . . . help.
Uhhhh . . . help.
Uhhhh . . . help.
Uhhhh . . . help.
From the Main Menu, touch the Navigation Setup Menu, press the Calibration button.
The Calibration screen, allows the adjustment of your
vehicle’s position or the vehicle speed signal.
To correct the position of your vehicle on the map
(for example, if your vehicle has been shipped) or to
change to the current position.
1. Select the Position/Direction screen button.
The map screen will display with your vehicle’s
current position.
2. To change your vehicle’s position, touch the map
screen.
Use the zoom in/out function to view the direction of
the desired area.
Pressing/holding and dragging on the map will
activate fast scrolling. Press/touch once on the area
to which you would like to move the current
position mark.
3. Touch the OK screen button once your vehicle is in
If a route had already been set, the map screen will
display, select Guide to change your route to your
vehicle’s new position.
Once the process of changing your vehicle’s current
position is complete, the map screen will display with
rotate arrow screen buttons around your vehicle.
4. To change the direction of your vehicle, press either
arrow screen button to rotate your vehicle to the
correct direction.
5. Once your vehicle is facing the correct direction,
select the OK screen button.
See Problems with Route Guidance on page 2-62 for more information.
If your car is not receiving a GPS signal (the slash throught the GPS indicates this, this is the problem and this problem will come back however.).
It is not uncommon for a car that has been transported to have this issue. Is the car in an area where the GPS antenna can get a clear view to the sky? If you are in a garage for example, with the position off the GPS signal will not reaquire the GPS satellites.
I followed your instructions . . . THANKS.
The navigation system works. Well, it still has the slash through the GPS icon, but it still allows me to start traveling to a specific location. The clock still does not show in the display window or on the clock setting page or on the main navigation page. The box is there, but it is empty.
Again, the navigation appears to work, but something is still wrong.
I was thinking that it might need more time to track more satellites, but I stayed with it for almost 30 minutes and the slash never disappeared.
As I mentioned, the GPS seems to work. I have not gone on a long trip, but testing it around town shows it is tracking OK, but still the clock is not working and the GPS icon is still slashed through.
If you have the slash, it doesn't have a signal.
Just hook it up...I had the same problem from the previous owner who returned the factory system when he sold the car.
Red Cell.
I would agree with what you have been told to this point. Unlike portable navigation systems, the factory navigation unit is tied in to several vehicle systems and has the ability to navigate using a dead reckoning capability. It uses input from the steering wheel position sensor and vehicle speed sensor to follow the map. If you still have a slash through the "GPS" icon, you are not getting an antenna signal to the head unit or a satellite signal to the antenna. If you have re-calibrated and have been outdoors in line of sight to a satellite for 30 plus minutes, it is likely at the antenna. It could be as simple as a connection at the back of the head unit that simply needs to be plugged back in. The slash simply means that it isn't receiving satellite data.
I am having the same issue with the GPS slash and the time not being set. Mine is total factory setup and checked the connections to the XM satellite receiver in the trunk as well. I am going to have the deal diagnose this issue and will post the results.
2007 clock failure
Uhhhh . . . help.
Uhhhh . . . help.
Canadian Dealer (Ontario) last week has told me Chev engineers are aware and working on a software update.
Update when ready is free but dealer is charging shop time.
Also told there is no update dvd navigation, anyone know where to get an update?
The last Navigation DVD update is version 10 (2016) and they are available for $12 all over ebay.
https://rover.ebay.com/rover/0/0/0?m...2F302723751161
Same thing happened to me...i tought i was alone.
Read this....i did.....not about to be solved i believe: https://www.corvetteforum.com/forums...isconnect.html
I just replaced my battery in my 09 Z06 and I have the same clock symptoms now. Has anyone discovered what the fix is for this issue? I apologize if its buried in this long thread.
1st Gear
I have a 2008 C6 with factory navigation. My battery died and when I replaced it my CLOCK disappeared from the radio face display. You can still go into the settings menu but the clock adjustments are dead. The battery dealer told me that you have to plug a MEMORY SAVER into the OBD port prior to removing the old battery to avoid this issue. I wish I would have known.
Has anyone used a memory saver and successfully saved the clock after replacing the battery?
The Dealer is aware of this issue but so far doesn't have a fix or a recall.
https://www.corvetteforum.com/forums...6-nav-fix.html
ImpartialOne (02-10-2020)
St. Jude Donor '06-13,'16-'17, '19
[QUOTE=BigBadZ;1599883169]I just replaced my battery in my 09 Z06 and I have the same clock symptoms now. Has anyone discovered what the fix is for this issue? I apologize if its buried in this long thread.[/QUOTE
This issue has been addressed. Click on the url below to get the firmware update.
Tom
https://tis2web.akamai.gm.com/radio/..._05_10_fix.zip
UNZIP THE FILE BEFORE you Burn the LOADING.KWI to a BLANK CD-R. Once this is completely burned and finished, go to your Corvette
#1 Make sure the vehicle is outside and the engine is running.
#2 On the radio display, press the Open/Close Faceplate Key
#3 Eject the map disc by pressing DVD Map Database Eject Key. Insert the Software Update Disc in the DVD Map Database Slot
The update will start automatically. You will see a progress bar on the screen. The update takes about 2 minutes. The vehicle logo will be seen once the update is completed.
Once you see the Corvette logo, remove the update disc and REINSTALL YOUR MAP DISC!
THIS IS NOT A MAP UPDATE< THIS IS ONLY FOR YOUR CLOCK BEING BLANK!
Tom
The following 2 users liked this post by TCW:
ImpartialOne (02-10-2020),
JLN81vette (02-03-2020)
