Corvette windshield question
Old Jan 19, 2010 | 05:52 PM
renegade10's Avatar
renegade10
Default Corvette windshield question
I have an 06 with 15K on it. In certain sunlight the windshield looks like it's been hit with a sand blaster. Is there a fix/preventative for this problem? Thanks
Old Jan 19, 2010 | 08:56 PM
Wizekrakr's Avatar
Wizekrakr
I see the same issue with my 08. Tried a glass stripper to no avail. Hmmmmm.
Old Jan 19, 2010 | 09:13 PM
hotspur's Avatar
hotspur
My '08, too. Do you both have the head-up display? Could it be whatever the special treatment is on HUD windshields that makes the display more visible?
Old Jan 19, 2010 | 10:11 PM
AvidFan's Avatar
AvidFan
I have an 07 that has 7600 miles and is equipped with HUD and my windshield has the same appearance you describe when looking at it from the outside.
Old Jan 19, 2010 | 10:55 PM
rm50's Avatar
rm50
2020 C8 of the Year Finalist - Unmodified
My 05 with a HUD had this problem also.
Old Jan 19, 2010 | 11:07 PM
cclive's Avatar
cclive
If its not a garage queen, then this is normal.
Old Jan 19, 2010 | 11:40 PM
George Ware's Avatar
George Ware
Same here with my 08,
Yes, She is a garage queen w/13k mi.
George Ware
Old Jan 20, 2010 | 03:10 AM
ssv3's Avatar
ssv3
Same here. Mine is a garage queen though.
Old Jan 20, 2010 | 03:15 AM
Rossi6998's Avatar
Rossi6998
Don't hold me to this, but I thought I read somewhere that a "different" windshield is used so the HUD is readable. Maybe the windshield is coated with something and this is what you are seeing when the sun hits it.... ???????
Old Jan 20, 2010 | 07:19 AM
Scruff Vette's Avatar
Scruff Vette
12,000 miles on my 2006 w/HUD and it looks 100X older and more beat up than my 102,000 mile '97 Ford Taurus wagon winter beater car's windshield. Unfortuneately, I believe this is normal for Corvettes due to the windhield's extreme angle and car height. You notice it more when going directing into the sun.
Old Jan 20, 2010 | 07:22 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
They all do that. C5s too.
Old Jan 20, 2010 | 07:26 AM
GOLD72's Avatar
GOLD72
Me too. My daily driver has over 39k miles. Nature of the beast. It can't be avoided IMO.
Old Jan 20, 2010 | 10:51 AM
Wayne O's Avatar
Wayne O
CF Senior Member
The 'HUD' windshield does have specific properties but I don't believe it makes the windshield more susceptible to pitting. As mentioned, this is a common occurrence with Corvettes in general. I know C6 racers who use film 'tear-offs' to cover and protect their windshield but I don't know how practical that would be for a daily driver (not to mention it won't help an existing problem). Some optometrists sell a polishing solution to remove pits and small scratches on eye glasses. I remember one guy who was going to try this but I never heard how it turned out.
I can identify with the problem. My windshield has a couple small rock chips and is pitted severely from track use. When I replace the glass I'll start using the film tear-offs on the track.
Old Jan 20, 2010 | 11:34 AM
hotspur's Avatar
hotspur
I don't think the HUD windshield is "more susceptible to pitting." I noticed the problem with less than 7000 miles on the car.
I'm thinking there's something they do to make that windshield more reflective of the HUD than the standard windshield that just makes it appear that way. As someone wrote above, perhaps it's a coating, or a reflective layer in the glass sandwich, or something, that just gives it that appearance when the sun hits it a certain way.
Edit added: Just found this in a DuPont press release:
At the center of the HUD technology is a precisely engineered "interlayer"
of DuPont(TM) Butacite(R) PVB that acts as the screen onto which the HUD
information is projected. This interlayer is called the DuPont(TM) Wedge(TM)
because of its angular cross-section.
Laminated between two layers of glass, the Wedge(TM) is transparent to
allow distortion-free forward vision
, but also is able to reflect the HUD
projection for viewing by the driver. The virtual image appears to float in
the driver's line of sight near the front of the car, minimizing refocus time.
Virtual image location and brightness can be adjusted to the driver's
preference. Together, these features help to reduce driver distraction,
enhancing safety.
The Wedge(TM) angle is critical, and was developed through close
cooperation with the GM engineering team, windshield supplier Asahi Glass Co.
and Nippon Seiki, which supplies the HUD projector and served as package
integrator.
"This is a great example of suppliers working together to add value to the
OEM," said Jeff Dickson, general manager, sales, for Nippon Seiki
International Ltd. "As we were adding great new features, such as a wide
array of user-selectable displays, it was important that the image be as crisp
and clear as possible. The laminate is a critical factor in achieving that
goal." The Wedge(TM) is manufactured from DuPont(TM) Butacite(R) PVB polymers to exacting tolerances.
Maybe, when the sun hits the "interlayer" in a certain way, it's not so "transparent." Suggest we all stop trying to clean and scrape it away.
Old Jan 20, 2010 | 01:02 PM
FNBADAZ06's Avatar
FNBADAZ06
It's due to normal wear and tear....the car sits so low that it is suceptable to every peice of road debri known to man. I just had my windshield replaced as part of an insurance claim and it is perfectly clear.
Old Jan 20, 2010 | 01:37 PM
nmerhaut's Avatar
nmerhaut
enhancing safety.
integrator.
This is exactly what I had been thinking. Mine has looked like that from early on and my first guess was the HUD. You have to look at it at certain oblique angles or you'll miss it. Sounds as though you've hit on the answer. Bravo!
Old Jan 20, 2010 | 01:47 PM
hongkongstewy's Avatar
hongkongstewy
I had the same issue with my 05 with HUD, Insurance wouldn't cover it because sand damage is over an extended period of time...but they refered me to a glass place they looked at it to see if any repairs could be done, but they said it needed to be replace, I took it to the dealership and had it replaced under warranty...but definitely would like to know also if the HUD windshield are more sucseptible; I know they suppose to have a special coating or something on the glass...
To Corvette windshield question
Old Jan 20, 2010 | 04:54 PM
ATOMICV8's Avatar
ATOMICV8
I dont think a HUD equiped car makes any differance. Noticed
this on my car at around 5000 miles, 2008 model year. Ask dealer
about this and he said I must have followed to close to someone
who threw rocks up on the windshield , BS. I personally think it is a problem with the windshield, good to see that I am not the only one
who tailgates rock throwing vehicles.
Old Jan 20, 2010 | 05:20 PM
budgreen3564's Avatar
budgreen3564
it's that way on all cars. it is more noticeable on a steeply raked windshield
Old Jan 20, 2010 | 05:42 PM
pit-pony's Avatar
pit-pony
So, if you need the winsheild replaced you have to specify a HUD car?
Wonder if the aftermarket glass shops carry different types of windshields or if you would need an OEM only if you have HUD.
