Bluetooth?
Old Mar 17, 2010 | 12:47 PM
BriscoCounty's Avatar
BriscoCounty
Originally Posted by GCD1962
My new 2010 Ford Taurus has a sytem called Sync that has Blue tooth and many other voice control commands available. Cost is zero, no extra charges at all.
Yeah, but that's a Ford. If you want a common feature for your Corvette that is found on every other car, its going to cost you!
Old Mar 17, 2010 | 06:20 PM
BB 2005's Avatar
BB 2005
St. Jude Donor '11, '13
Default Thanks!!
Originally Posted by 65Corvette
For $40 you can pick up a BlueTooth speaker and clip it to your visor. They work great and solved the problem for me on another ride that didn't have BlueTooth.
I was just about to shell out for this when you reminded me I have one of these and it works pretty well, I just need to charge it up. Problem solved.
Old Jan 15, 2016 | 11:09 AM
2268irma's Avatar
2268irma
Default bluetooth
Originally Posted by laconiajack
Corvette didn't have bluetooth phone capability until the 2009 nodel year.
If I install a 2010 Nav unit in my 2008 will I have Bluetooth. Thanks Bob
Old Jan 15, 2016 | 04:41 PM
67-427ci's Avatar
67-427ci
Originally Posted by CSixDude
Check this out. If you can live without OnStar and voice controls for the Nav system, you can have BlueTooth via the OnStar button.
http://www.costartech.com/pb/products/bluestar.html
I installed a CoStar BlueStar unit in my 05 when I purchased it in November last year. It works great and I love the way it totally integrates with the audio system. You can do anything by voice command that your phone supports. Installation took all of 10 minutes in my car. Unplug the OnStar unit and plug in the BlueStar unit. When you get an incoming call, the radio mutes and when you end the call the radio comes on again. It is a bit expensive, but (to me) it is worth it. The guy who sells them gives great support as well. No other hardware or changes are required on your car.
Roy
just realized this is an old thread.
Old Jan 15, 2016 | 07:42 PM
GuruGuy's Avatar
GuruGuy
Originally Posted by AntneeD
anyone know anything about this unit?
sounds great....
I too have an 08 C6 and was actually surprised it did not have Blutooth. I got one of these Blue Star units and absolutely love it. You do need to give up the On Star, but that isn't a negative to me. The unit is easy to install and quick to program. I have an iPhone and can use all of its functions, including Siri.
Old Jan 15, 2016 | 10:26 PM
Dcasole's Avatar
Dcasole
Really old thread but....
I too have the Costar blue tooth unit and love it .Expensive but It's the next best thing to a factory installed system
My steering wheel controls work with it ....
Dave
Old Jun 22, 2016 | 07:33 PM
m1245k's Avatar
m1245k
Cruising
sounds great....
Put it in my wife's C6 convertable,it doesn't get any easier or better, sound quality is exceptional. I'd just like to know where those that have it are putting it. No room behind the stiff carpet.
Old Jun 22, 2016 | 09:10 PM
Dcasole's Avatar
Dcasole
I double face taped it to the factory onstar VCM which on a 2011 coupe is located above the passenger side kick panel , only place for it because you need to unplug the wires that connect to the factory onstar and connect them to the costar unit
I have since retro fitted my car with factory Bluetooth ......
Dave
Old Jun 22, 2016 | 09:54 PM
walleyejack's Avatar
walleyejack
i tossed out the pee poor factory nav and replaced with aftermarket stereo that had blueteth, nav works great, along with bt.. never looked back.
Old Jun 22, 2016 | 10:23 PM
Silver 07's Avatar
Silver 07
I purchased this one from amazon, it's a blue tooth fm transmitter works pretty well, but want to look into the Costartech device.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Jun 23, 2016 | 08:35 AM
Katie22's Avatar
Katie22
I installed the ISIMPLE isgm655 module purchased on ebay for about 130. It works really good and turns your nav radio into a Bluetooth system.
Old Jun 23, 2016 | 10:19 PM
Silver 07's Avatar
Silver 07
I think I'm going to get the iSimple ISGM655, does anyone know of a good installer in the San Diego, Ca area that I can purchase and install.
Old Jun 24, 2016 | 06:17 AM
  #33
Katie22's Avatar
Katie22
Glamis if you lived close I would install it for ya but I'm in Florida.
Old Jun 24, 2016 | 09:55 AM
  #34
Augie 79's Avatar
Augie 79
Originally Posted by PAKev
The Bluestar 2010 looks nice. Anyone know where the OnStar module is located in the convertible?
In the trunk, under the R/H storage compartment. You pop the storage compartment door off, pull back the FWD edge of the plastic storage compartment and you'll see the OnStar module. Unplug and remove the OnStar module and plug the same connector into the Bluestar module. There's a pretty good youtube video on the whole procedure. Close everything back up and you're done.
Blue tooth was the only item missing from my '08 that I wish I had. I installed the Bluestar and am very happy with it. I had a little trouble with it connecting to my iphone and posted here about it. I was told to email Chris at Bluestar, I did and he fixed my problem the next day.
Very happy with the Bluestar system.
augie
Old Jun 24, 2016 | 10:50 AM
  #35
Katie22's Avatar
Katie22
on my 2006 the onstar equipment is attached to the windshield next to the rearview mirrror.
Old Jun 24, 2016 | 11:08 AM
  #36
Silver 07's Avatar
Silver 07
Thanks, Katie22 wished I lived closer, I would take you up on that offer. I have done some radio work, but don't want to tackle this on my mint 07.
Old Jun 24, 2016 | 05:00 PM
  #37
Maites's Avatar
Maites
This is a super easy fix if you have XM in your car. You would have to stop using the XM in favor of your bluetooth though. I ended up paying for spotify so I could stream anything I want and have Bluetooth voice control. Cheap and easy install. See link.
http://www.kawal.net/bluetooth.htm
To Bluetooth?
Old Jun 24, 2016 | 05:31 PM
  #38
Dcasole's Avatar
Dcasole
That is just the antenna , the unit is either under your seat on older cars or above the kick right kick panel on newer cars and in the verts it is in the storage area in the back
Dave
Old Jun 24, 2016 | 05:32 PM
  #39
Dcasole's Avatar
Dcasole
Nope , see my previous post ....
Old Jun 24, 2016 | 07:31 PM
  #40
Katie22's Avatar
Katie22
Glamis. You can see videos on youtube on how to take apart your console. It is easy once you know how!
After you take apart the console the isimple is extremely easy to install with no modifications. You simply plug it into the back of the radio.
Katie
